05-10-2007, 08:37 AM | #81 | |
http://www.projecttwin.com/files/WKtemplates/ Thanks JIA this should help clean out my mailbox now. Thanks for all the intrest people! I know other people have offered to host them before, but I am to the point now where it is hard to keep up with everyone. Also, ALL of the templates are in that file: Servo mount, BTA servo mount, Clocked Motor plate. | |
05-10-2007, 09:37 AM | #82 |
Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
Thats really cool, I think I'm going to pick me up a WK 4x4.
09-11-2007, 04:46 PM | #83 |
Pebble Pounder Join Date: Mar 2005 Location: Kelowna, B.C., Canada
Heres my version of your template. Thats for going to the trouble of designing it. Last edited by outcastrc; 09-11-2007 at 04:53 PM. |
09-11-2007, 09:53 PM | #84 |
Quarry Creeper Join Date: Aug 2005 Location: Spokane
Here is the mount I made with very limited tools here at Kunsan. I plan on fabbing up a new one when I get back home to LV. Thanks for the template! What I started with Finished and mounted in a K2-3S Chassis. |
09-11-2007, 10:15 PM | #85 |
Pebble Pounder Join Date: Apr 2004 Location: Sydney, Australia
These mounts look great but am I am missing something... Why don't you turn the motor mount slots thru 90 degrees to 1. get the mounting bolt out from behind the spur gear and 2. get a more positive adjustment onto the spur? If you are hitting the tranny case, just grind a little off it. Cheers, JK |
09-11-2007, 10:40 PM | #86 |
Quarry Creeper Join Date: Apr 2005 Location: South Jersey (Cherry Hill area)
well here is my WK motor plate it was set up for a CrawlMaster... but shown with an E-flite 450 |
09-11-2007, 10:55 PM | #87 | |
09-12-2007, 10:43 AM | #88 |
OutcastRC and Doodoob, both your mounts look good! |
09-14-2007, 10:34 AM | #89 |
Rock Crawler Join Date: May 2007 Location: Corona, CA
I just finished my setup and i could not get my gears to mesh and im using the stock gearing is that my problem. I can post pics if needed.
09-14-2007, 10:39 AM | #90 |
Stock gearing I believe should work. On mine I could run a 96t spur and a 18t pinion. However I still changed it to 32p 72t spur and a 9t pinion. Much easier to get it to mesh especialy if you run a lathe motor.
09-14-2007, 11:51 AM | #91 |
| Looks like there are some problems with JIA site right now. If anyone needs the WK plans feel free to send me a PM or an E-mail. |
09-14-2007, 11:53 AM | #92 |
yes im running a lathe motor is that why its not meshing right. What it better about switching to 32 pitch
09-14-2007, 06:11 PM | #93 |
Its a larger diameter spur gear. So you shouldnt have to get the motor as close tothe tranny to get the gears to mesh. I went this route at the advice of others and it works well. Do a search in the forum and you will see a bunch of people running them.
09-25-2007, 02:11 PM | #94 |
Quarry Creeper Join Date: Dec 2006 Location: Corbin KY
harley i sent you a pm but didnt get a reply i was wondering if i could get a copy of the template thanks alot for making this
09-25-2007, 03:05 PM | #95 |
Rock Crawler Join Date: Aug 2006 Location: nc
09-25-2007, 03:12 PM | #96 |
JIA shut down his site, so the link is no good now (as of the last time I checked anyways). I usually can get around to PM's just takes so long to go through all of them. The reason I didn't respond to yours was it didn't have an e-mail address in it. I was going to go to your profile and look for it but didn't have time at the moment. Just make sure to include your e-mail address in your PM or actually e-mail me. |
09-25-2007, 03:47 PM | #97 |
10-21-2007, 10:21 AM | #98 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
| Stock Motor Mount Clocked
For my version of clocking the motor mount I just turned the stock one like 120 degrees until one of the screw holes lined up with the other next to it. Broke out the dremel and went to town on making it fit. I'm running a GD 600 so it made it easier to get clearance on the side of the transmission. Since the only thing that comes in contact with the transmission case is a medium size gear. So with this I was able to put the output and the motor much closer together for better driveline angles. And not to mention the motor isnt hanging half way out of the chassis. Its not real pretty but its very functional. Here is the ground up motor plate in the stock position Here it is clocked 120* Here is the side of the case where I had to clearance a little bit to get ther right mesh with running a 96t and a 12t. Here it is installed on my Widow Chassis I ended up making two brackets on the front to hold it and a zip tie on the rear to hold the motor down to a screw on the chassis. So my gearing is a 12t to a 45t to a 12t to a 96t - total reduction before transmission and axles - 30:1 |
10-13-2008, 11:07 AM | #99 |
Pebble Pounder Join Date: Sep 2008 Location: usa
wow you guys all make this look so scarry to try cause you cant go back if you dont like it
10-17-2008, 06:50 PM | #100 |
Rock Crawler Join Date: Aug 2008 Location: maple ridge
Weird. I dont' own an RC but my buddy needed a plate liek this made so i got out the calipers and solidworks and in 10 min had the design. I just got 12 cut. |
