09-11-2015, 06:24 PM | #41 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
| Re: Raptor Pre-Runner Build
This thread is worth taking a look at STANG KILLA SS learns to weld.....Thermal Arc 95S These two channels have some helpful info on tig welding, but at the end of the day you just have to get some welding time in. https://www.youtube.com/channel/UCqq...j4-UApS_m_6mPw https://www.youtube.com/user/Welddotcom |
09-11-2015, 06:25 PM | #42 | |
Rock Stacker Join Date: Nov 2014 Location: On the internet, confused.
| Re: Raptor Pre-Runner Build Quote:
I honestly don't know either of those off the top of my head. I'll check next time I go to the shop. | |
09-14-2015, 10:51 PM | #43 |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
Cant wait for more updates! Are you going to try and do a scale prerunner suspension tunning? ________________________________ Scx10 Bronco aka The Bronco |
09-15-2015, 08:43 AM | #44 | |
I sure hope that the king scale shocks perform as good as they look! The ultimate goal is to be like cyconxc on YouTube (he is also on RCC, but I forget his username). Sent from my Nexus 5 using Tapatalk | |
09-16-2015, 04:43 PM | #45 |
Thanks spookyseven for the threads! HIGH QUALITY AND FANCY PICS!!! The large orange thing cradling the rear shocks will be replaced by the bedcage. Above is approximately ride height, below shows the travel extremes. Note: these took about 20 min to fully render each image. Last edited by Raptorn; 12-25-2017 at 02:29 PM. Reason: Pics |
09-16-2015, 08:33 PM | #46 | |
Thats sick man! Cant wait to see how it preforms. I wonder if the tires are going rub on the body cause there's so much travel lol ________________________________ Scx10 Bronco aka The Bronco | |
01-16-2016, 05:57 PM | #47 |
This is back from the dead! I've made major progress in the last few weeks, so here goes. First thing was finishing the frame braces. There is a huge difference in stiffness with these on (bottom). I then made a simple jig to hold the subframe where I wanted to weld it The best part of welding is cleaning all your parts (NOT). Everything had to be soaked in rust removal liquid (because I haven't touched anything since July, or maybe last March...) And weld it all together! ^ It's amazing how small of things you can TIG weld with the right setup. My setup for tiny things: 1/16" tungsten 25-35 amps (25 for the sheet metal) 1/16" filler. I also used .041 MIG wire as filler for the sheet metal. Once I had all these and got some more practice, I was able to pound out solid quality welds, albeit slowly, because this stuff is easy to overheat. Last edited by Raptorn; 12-25-2017 at 05:49 PM. Reason: Pics |
01-16-2016, 06:08 PM | #48 |
I present the finished subframe! After fully welding and grinding smooth. This is the good part: with all my mounting surfaces in place, I can finally assemble the front suspension! After over a year of work, it finally looks like an RC car! There are only two things keeping the front from being freestanding: 1. my crappy upper shock mount, 2. I forgot to drill the lower control arms for the shock bolt. Last edited by Raptorn; 12-25-2017 at 05:51 PM. Reason: Pics |
01-16-2016, 06:23 PM | #49 |
Yes I have been waiting for this! __________________________ 1.9 ibex tuber Slash that got run over by reindeer Cheers Jacob |
01-23-2016, 09:29 PM | #50 |
| Re: Raptor Pre-Runner Build So have I! The front suspension is finished! Except the steering, but that's not important now. It's freestanding, and its bouncy! But let's back up a bit. There were two roadblocks left last time: I couldn't bolt the shock in at the top or bottom. Here is the hole in the lower control arm: Drilling through the tube was easier than I expected. And the revised upper shock mount: With the kings in, there was major binding in the control arms, so I disassembled, tweaked and reassembled the whole thing about 4 times. No pics of this because its boring. Below is a test fit of the main roll-cage jig. I will thread the vertical rods so the cage can be removed easily. Not shown is a ton of progress on the rear suspension. Also not shown is a bunch of tiny brackets to bolt the cage to the frame. They were a pain. More soon! Last edited by Raptorn; 12-25-2017 at 05:54 PM. Reason: Pics |
01-23-2016, 09:44 PM | #51 |
Wow. What was the binding issue? Are you going to tune the shocks like cynoxrc/ prerunner? __________________________ 1.9 ibex tuber Slash that got run over by reindeer Cheers Jacob |
01-23-2016, 10:39 PM | #52 | |
cyconxc is the stuff of dreams! I will try my best though... | |
01-24-2016, 08:15 AM | #53 | |
Yeah he is. Did you see his shock video on how he does it? __________________________ 1.9 ibex tuber Slash that got run over by reindeer Cheers Jacob | |
01-31-2016, 05:34 PM | #54 |
| Re: Raptor Pre-Runner Build |
01-31-2016, 06:07 PM | #55 |
With the main roll cage jig built I moved on to the rear suspension jig. The shocks fit between the 1/4 in. rods. I tried to use 1/4 tubing, but it had some funky coating that would not come off (tried wirebrush and solvent) and made it impossible to weld. Should have just used the solid rod first try. I then bent up the rear main supports and prepped each tube for welding. After an hour or so of welding, we end with this! On a side note, I was tired of holding 3mm nuts with pliers, so a quick adjustment to an old wrench (5/16 inch) did the trick. This is how the cage attaches to the frame. I'm not convinced the sheet steel will hold up though... With the rear shock mount settled, the truck can finally hold itself up! It's only missing steering and a driveshaft until it hits roller status! I later realized I installed the skid backwards Last edited by Raptorn; 12-25-2017 at 05:58 PM. Reason: Pics |
01-31-2016, 06:39 PM | #56 |
"Moar pics!" I hear you, I hear you. "Set up a photo booth!" "No crappy cell pics!" Okay, whatever you guys say. Here you go: Oh, the body also fits on now. Because of the ace jig I made, it fits well too. The only thing I'm not happy with is that I forgot to cut off the excess rod behind the cab. This means the main support is half an inch away from the cab, and it looks kinda dumb. This reminds me, the ugly stickers need to go! Last edited by Raptorn; 12-25-2017 at 06:01 PM. Reason: Pics |
02-06-2016, 12:42 PM | #57 |
Looking good man! __________________________ 1.9 ibex tuber Slash that got run over by reindeer Cheers Jacob |
02-06-2016, 06:17 PM | #58 |
| Re: Raptor Pre-Runner Build Thanks dude! Despite the record progress, there is still an enormous list of things to do.
Should be fun! |
02-07-2016, 11:11 AM | #59 | |
So still some to do. Should be done In no time __________________________ 1.9 ibex tuber Slash that got run over by reindeer R.I.P Dave Mirra Cheers Jacob | |
06-01-2016, 08:13 PM | #60 |
| Re: Raptor Pre-Runner Build Boy I wish! Not a lot has happened since the last update, but here we go. There was nothing to hold the body up, so I drilled a couple holes in the roll cage and bent up some wire into my own body clips. Then I spent some time removing those hateful stickers. I looks much cleaner without them, even with the paint I accidentally scratched off. The big news here is that the drivetrain is 100% complete! Finally got my driveshaft and spur gear, but it took a little (a lot) to make them work. To fit the 18T pinion, I had to extend the motor mount slots about two millimeters. This pushed to motor over far enough that I needed to clearance the transmission skid too. Nothing is bolt on with a custom R/C! Last edited by Raptorn; 12-25-2017 at 06:05 PM. Reason: Pics |
Raptor Pre-Runner Build - Similar Threads | ||||
New Vaterra "Raptor" Pre runner | wrightcs77 | Chit Chat | 11 | 01-30-2014 02:53 PM |
pre runner build.. | XSRCdesign | 2.2 Scale Rigs | 353 | 02-17-2010 05:16 AM |
Xtrail Pre Runner Build | Syd | Non Crawler RC's | 10 | 06-08-2009 06:15 PM |
Pre-Runner build up... | smokinubyrc | Non Crawler RC's | 36 | 02-19-2007 01:46 AM |
