Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: My 6th Scale M151A2 Jeep Mutt
Old 05-02-2016, 11:15 PM   #1
Default My 6th Scale M151A2 Jeep Mutt
I got my second 6th scale
Its from 21st Century Toys
And I really like it
Its pretty bad ass
I parted out my second Wraith for the axles and skid plate
I like how I could use 1.9'' Rock Beasts or 2.2'' Rock Lizards or 2.2'' Badlands
They are the shortest 2.2'' plus I got 5 Rock Lizards so I could have a spare
Its 10'' wide by 19 1/8'' inches long
With a 14 1/4'' to 14 1/2'' wheel base depending where
You measure from or maybe its I'm just tired
Not sure if its possible to remove the hood
Cause it looks its all one piece
I need to look at motor forward plates or mounts
kgb424 is offline   Reply With Quote
Old 05-02-2016, 11:23 PM   #2
Default Re: My Jeep Mutt
Here is some more pics
Of how far I got today
I removed the front and rear axles and Dremel-ed the plastic smoove
Hoping I can get some ideas from other 6th scale builders
Please comment and share your ideas
I figured out the chassis rails for my 6th scale Humvee
Which has a totally different under carriage than the Jeep Mutt
Old 05-02-2016, 11:48 PM   #3
So if I use a motor forward plate with transmission mount ??
Does that mean I also have to use a transfer case ??
Or maybe mount the motor and transmission centered in the chassis
Like a TF2 or similar design of transmission
And then cut out the bottom of the engine bay out
So the body drops down over it maybe
There ideas bouncing around in my head but nothing clicks
Old 05-03-2016, 03:08 AM   #4
Default Re: My 6th Scale M151A2 Jeep Mutt
just needs a M416 tote
TacoCrawler is offline   Reply With Quote
Old 05-03-2016, 10:51 AM   #5
Does any body here no how to stretch
The wheel base on a Axial EXO
Cause it looks about a 1/2'' or more short
Not sure if I want to cut the chassis plate
Old 05-04-2016, 06:40 PM   #6
I going to see if I can find a used RC4WD R2 single speed transmission that the motor mounts too
And read on the R2 you can change the output ratio by changing pinion gear sizes
If I use a 17 tooth pinion it gives you a 4:1 ratio
So if I use the R2 transmission
I will need a transfer case
but how do choose the out put ratio
I looked on line and there is
2.18:1
.75:1
1.45:1
1.47:1
1:1
I'm leaning towards the 1:1 ratio one
Correct ??
Old 05-04-2016, 07:40 PM   #7
Yeah Baby
Lock and load
Rock and Roll
I got my action figures
I also got some ammo boxes
I could mount ammo box so the M60 looks like its belt feed
And put a couple ammo boxes in the bed
Old 05-04-2016, 08:37 PM   #8
As much as it sickens me to think this aloud, the limited space under the model would almost work well with a MOA style of drive train. It would save the model from being hacked up to fit motor/trans/drive lines.
BigSki is offline   Reply With Quote
Old 05-04-2016, 08:53 PM   #9
I found a used R2 Transmission cheap
I never dealt with motor on axles
Who makes them or whats a brand name so
So I can look at them
Old 05-04-2016, 09:10 PM   #10
I spent 2 hrs looking through the archives for the 1/6 Mutt build I had seen once before, only to find something that wasn't even a MUTT. The build I had seen, showed that the builder was able to use an SCX10 trans/motor assembly that fit up into the tunnel without cutting into the body. Best I can say, is try it. If it works, it works, if not figure out a Plan B.
Mike Flea is offline   Reply With Quote
Old 05-04-2016, 09:55 PM   #11
Thanks Mike
I looked too but only found one started build and very little pictures
I mocked it up with a spare set of SCX10 axles cause I been wanting a too try one
I'm going to use the SCX10 axles and make a 1.9' Wraith when I get around to making some new links
The Jeep and the Humvee are both too wide for the SCX10 axles even with the XR mod
I also have a GCM chassis with Toyota axles and leaf springs and they are not wide enough
I have seen a couple Willy's builds with the Toyota axles and leaf springs and they look good and scale
I Then tried the EXO chassis and its short and not liking how the body sits on top of the EXO chassis
I will use AR60 axles and if the guy with the R2 gets back to me
I also found a 1:1 transfer case its about the same size as the GCM 1:1 transfer case
And is very reasonably price too
need to figure out some thing
I seen Scalelover made a chassis and showed it with a Jeep body
And it looked very similiar too the underside of Mutt
I'm going to hit him up
Old 05-05-2016, 12:31 AM   #12
Yeah Baby
I pulled the GCM motor forward plate and the GCM 1:1 transfer case
Out of my 4 Ten Chassis
And the transfer case fits snugly either way you flip it and mounted some how
And the motor forward plate could fit up inside the body
I'm going to look for aluminum plate
And fabricate my own motor plate
And maybe order another SCX10 transmission
I may still need to cut the hood
Old 05-05-2016, 12:58 AM   #13
It should not be that hard
To make motor plate
The hardest parts I see is cutting the slot for adjustment of the gear mesh
It needs to done cleanly and be squarely
And drilling and tapping holes in the side to hold 3 mm cap screws
It could be a pain in the ass with a cordless drill
I don't have a drill press
I could trim out the area of the body
Where the motor and transmission are sitting in the earlier pictures
And put the motor plate in the chassis so the body drops over it
Old 05-05-2016, 03:20 AM   #14
^ doll play ...having fun with your phobia ?
you've probably already scheduled for sex change surgery,
b muh guess
looks like a probable drive syst.
but doesn't the mtr/gearbox need mount on
the opposing side of the surface inside the engine bay ?
or is the hood too shallow to mount it to that surface ?
spill it... plus more pictures detailing
oh and not all claimed 1/6 scale toy vehicles are accurate
to the playscale GI Joe or similar 12" doll's.
IMO even some of the 1/6 Willy's I've seen look a tad too small
for a std 12" doll.
But there are some that look slightly bigger, close enough.
Likely some mfgr's get it closer.
Even RC scaling isn't anywhere near to being accurate..
so it mostly what's pleasurable to each builder's/user's eye.
doesn't matter if I think it looks stupid !? Lol
ie: 8:34 - https://youtu.be/m8LqEv66gI4
dolls r 4 wussy's, dolls r 4 wussy's, dolls r 4 wussy's, dolls r 4 wussy's
(remember) yer too masculine to be playing with dolls !?
calling them action figures only strokes yer phobic ego
btw the red headed joe looks more to scale in that hummer thang.
Old 05-05-2016, 10:13 AM   #15
Your Funny Taco
I love the 6th bikes
That Harley and Indian
Were Bad ass
I seen a nice XR600 Desert Racer and a XR400 that was painted for military
And I also found another set of AR60 axle trusses that I could of sent you
I also found this its almost a complete SCX10 transmission
If I remember that the transmission with the stripped 2 mm screws on the output shafts and they are the old style with out the thru hole for pin on the Wild Boar drive shafts
And I found these HPI Diffs from a Mini Desert truck don't know why I'm keeping them
Old 05-05-2016, 02:53 PM   #16
I can't find any 3/16'' X 2'' x 3'' aluminum flat stock
I have to order it and the shipping is XXXXXXXX crazy
Not paying it, the piece I need is a like $5.00 to $6.00
But the shipping is $15 to $18 dollars screw that
And I'm better off buying another SXC10 transmission then replace the parts in the one I found
And the guy with the R2 has not gotten back to me
The R2 may be the answer
Old 05-05-2016, 10:05 PM   #17
Yeah baby
Anybody got a shoe horn
I don't need to cut a stinking hood
I used brute force and seperared the floor pan from the body
And it has room for the motor and transmission
I mocked up the tranny and motor going both ways
And it lines up better with the spur gear facing the fire wall
I cut out the tunnel all the way thru
Going to need some custom drive shafts
I figured how to add a little more horsepower and a little pick up
I been keeping this Blower for awhile
I kinda like it , it looks bad ass
Old 05-05-2016, 10:44 PM   #18
Here is some pictures of the floor pan
And what it looks like under the body
Old 05-06-2016, 09:41 PM   #19
It rained here today
So I was bored and wanted to see if I could
Make the SCX10 axles wide enough to fit the Jeep Mutt body
I had to use my Hutchison Beadlocks cause they are the only
1.9'' wheels I got that take SLW hubs
So I reversed the wheels and used the long plastic hub
That comes with Axial IFD 2.2'' wheels
Not sure how long the hub is
But it does work to space the axle enough to fit
Not sure I like it cause I don't trust the plastic hubs with the pin slots in them
Still would not run hub that wide
I'm going to look online
Old 05-06-2016, 09:56 PM   #20
I might have to use the AR60 axles
And go with 1.9'' wheels cause I like the look
And I can use the spare tire mount
A 2.2'' is too big not sure I want to mount a 2.2'' spare in the bed
Cause it takes up too much room
I got my vintage gas can with the single handle
And the gas can cap comes off
Need to make a gas can holder that mounts to the bumper loop
Like the scale Willy's have
You know you have to much stuff
If you can scratch build a complete set of stock Wraith shocks
And set them at 100mm and the springs have a yellow color band
I have no idea where the yellow banded springs came from
Cause the other 3 sets of Wraith shocks had the red color band
I have too much shit
My 6th Scale M151A2 Jeep Mutt - Similar Threads
Mutt - ClassiCutCustoms Dreufic Videos! 6 03-11-2015 04:55 PM
the mutt lifted_xj Axial AX-10 Scorpion 6 01-03-2011 01:51 PM
my mutt! krono7s General Crawlers 5 10-06-2010 06:22 PM
The 1/6 MUTT Flying Dutchman Large Scale Rigs 24 05-10-2010 02:35 PM
