11-02-2016, 11:42 PM | #61 |
| re: It just got real
I actually like the simplicity of the triangle shaped hanger at the left P#59 looks most similar to my M100's leaf spring hangers why don't you buy some or call them for the width measurements ? |
11-02-2016, 11:51 PM | #62 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
Hey Taco I found the dimensions for the hangers you like And the dimensions for all of the ones that come in the combo pack not sure what measurement units they are in, are they MM's or Cm's or decimal inches If you use the photo viewer that comes with Windows you can zoom in and see and read dimensions clearly on the Combo picture I need some for link mounts for the Hasbro Willy's And some for spring mounts for my trailers Last edited by kgb424; 12-11-2018 at 01:21 AM. |
11-03-2016, 04:54 PM | #63 |
All of those link mounts are used on the Tamiya Big Rig RC models, they just aren't easy to find in stock anywhere.
11-03-2016, 06:12 PM | #64 |
What are the dimensions in mm's or cm's or decimal inches
11-03-2016, 08:32 PM | #65 |
With the hangers shown above, once you reinforce the stock plastic by filling in the frame areas, you'll be able to screw those hangers right to the body, that's one option. Here's the what RC4WD is offering, they are for the Trail Finder and High Lift, and it would appear to me that they require a frame to be mounted to, Part #Z-S0064 set of 4 leafspring shackles and mounts, $40. They also come in black. |
11-03-2016, 10:15 PM | #66 |
I would like to buy some of the RCP Crawler style hangers or the similiar style ones from the posted link to use with the Willy's plastic frame after I reinforce it, there is a lot builds using the RCP hangers and know that they will work as link mounts For the trailers, in the first picture are the stock height spring mounts from my GCM 4 ten chassis, that I replaced with the lifted spring mounts, they kinda look the RC4WD ones Mike posted In the second picture are some Tamiya Bruiser spring hangers and 2 different types of shackles the one set of shackles look just like the RC4WD ones Mike posted When I built my GCM chassis, I bought extra leaf springs and the hangers and shackles together cheap I need to reinforce the trailer first and see if any of the ones have will work, if not I might buy some of the triangle ones Taco likes Just too use with the trailers Last edited by kgb424; 12-11-2018 at 01:21 AM. |
11-05-2016, 01:52 AM | #67 | |
| re: It just got real Quote:
It looks like the hangers can be adjusted for width by simply spacing them wider. Might need use longer bolts to make wider... but that may not be too difficult. I may have to look into those more closely. Last edited by TacoCrawler; 11-05-2016 at 01:54 AM. | |
11-05-2016, 02:05 AM | #68 |
I just went to RC4WD and looked at the mounts that Mike posted there almost $50 with shipping to my house I'm going cheap and buy 2 sets of these at $8.00 for 4 hangers and cut them so they have only, one hole on the rounded tab side, cause the triangle ones have 2 holes, but I would have to drill a hole in the middle and it would weaken them or would not look good offsetted to me So with one hole, I can use square metal stock in the trailers hollow area to stiffen the frame Then drill and tap the holes for the mounts screws with the bit and 3.5 mm tap I got I could also drill and tap holes in the side spaced opposite of each other to help the epoxy hold the square stock in place Last edited by kgb424; 12-11-2018 at 01:17 AM. |
11-10-2016, 10:16 PM | #69 |
Now for something completely different I have this Toyota body for my 1/16th Exceed, that will never happen, so I'm going to take the blower and instead of hinging the hood, I'm thinking about going old school And cutting the hood and use pins or magnets, so its like a panel with blower attached to the hood, you lift it off instead it beaning hinged and I like the blower, will need some 1/6th scale Nitrous Bottles Yeah baby customization in effect Last edited by kgb424; 12-11-2018 at 01:18 AM. |
11-10-2016, 10:20 PM | #70 |
no hinge the hood and quit being a dufus |
11-10-2016, 10:44 PM | #71 |
I found this picture of CO2 pellet cartridges The one on the left is a 12 grams and the one on the right is 8 grams The smaller one would make a nice Nitrous Bottle with some black wire for the hose and the bigger one could be used for a welding tank or use both for a set and get some red and green wire for the hoses And they are close enough to 1/6th scale That the Taco, won't get his UndeRoos in a bunch right back at yeah Last edited by kgb424; 12-11-2018 at 01:18 AM. |
11-10-2016, 11:25 PM | #72 |
Maybe I'm wrong on the scale, cause the cartridges look to big now I just bought this 6th scale 21st Century Welding Torch and Tanks, that originally came with a 21st Century 6th Scale Tank set, that the Tank Crews would use to make repairs Its going to look good in the back of the Jeep, I will take out the back seat and make a mount for bottles where the seat was And will convert them to Nitrous bottles, to go with the blower and paint "Go Baby Go" on them, Bad Ass right there And use the torch handle with some red and green wires and a big and a small cartridge and make them a Welding Set, too use in one of the trailers Will look Bad Ass, with 2 bottles mounted and strapped and a Torch handle and Hose coiled up, need to make or find some gauges or regulators For the Nitrous Bottles and for the Welding Tanks Yeah Baby the Creative Juices are flowing Last edited by kgb424; 12-11-2018 at 01:18 AM. |
11-13-2016, 07:32 PM | #73 |
I helped my friend add this 6'' aluminium flashing to his roof to keep the rainwater off his fascia board And I got to keep the rest, I'm going to make some out of it, maybe make corner panels for the Hasbro Last edited by kgb424; 12-11-2018 at 01:17 AM. |
11-17-2016, 01:56 AM | #74 |
I put my Wraith back together and used different rod ends And it now has a 12 1/2'' wheelbase and looks better to me And I scrapped my second Honcho for parts and going to use the SCX10 Transmission with metal gears and 100 mm Wraith shocks And links and maybe the Mamba Max pro ESC and Brush less motor or a 35 turn Brushed motor and a EA2 ESC in the Hasbro Jeep Last edited by kgb424; 12-11-2018 at 01:21 AM. |
11-17-2016, 07:47 AM | #75 | |
Wraith factory established wheel base is 13.9" And so... in looking at your picture posted... with the front axle extended (forward) The WB has to be longer... not shorter. Maybe it's typo and you meant 14.5" WB ? or do you mean a wider track width ? factory width is 11.02" (so the increase to 12.5" would make some sense) yer a confusing individual Last edited by TacoCrawler; 11-17-2016 at 07:50 AM. | |
11-17-2016, 09:15 AM | #76 |
No, No, and No Once again its the Taco Vender who is confused When I built my Wraith kits, I never used the stock plastic lower or upper links from the kit I bought the after market, upper and lower aluminum links from Axial, the upper and lowers are both 87.5 mm and depending on which rod ends you use And with the long curved Axial rod ends the wheel base is the 13.9'' if not more, cause it had a 14.5'' wheelbase and did not like the look of it Again, I used the shorter curved Axial rod ends and it shortened the wheelbase to 12 1/2'' that's shortened Stock the front was extended father out, I switched rod ends and it shortened the wheelbase and move both axles inward I like how it looks with shorter wheelbase with the Spawn Body, with the Original body panels you could lengthen the wheelbase and it looks good, the Spawn body looks better with a short wheelbase Mr. Dumas do you understand now, is it clear to you Some peoples kids, send them to school and they shit in the Sandbox Almond Roca anyone ?? Last edited by kgb424; 12-11-2018 at 01:17 AM. |
11-17-2016, 12:14 PM | #77 |
Yeah Baby I got my 1/6th scale torch and welding tanks and it looks, a little small sitting in the bed of trailers, so the C02 cartridge welding tanks,need to happen for the trailers Using them as Nitrous bottles and in between the seat mounts and under the seat Need to trim the seat a little and use spacers to raise it up a little so the bottles fit under the seat so I don't have to re-do the whole bed by cutting out the seat mounts I like it, it's going to look bad ass and something different The Marx trailer is first and then the Hasbro trailer, the tanks look small to me Last edited by kgb424; 12-11-2018 at 01:17 AM. |
11-17-2016, 12:51 PM | #78 |
| re: It just got real No but it's not my junk so I probably don't really GAS ----------------- Are those tanks you're using for welding tanks actually SCUBA tanks for the diver GI Joe ? No I'm not reading back 'cause I probably couldn't understand yer gibberish anyways Just answer yes or no |
11-17-2016, 02:49 PM | #79 |
No They are a set of welding tanks with a torch You can see the torch in the 4th picture They were part of a 21st Century 6th scale tank set, for tank crews to make repairs Mr Dumas better change the magnifaction on your glasses and put fresh batteries in your hearing aids I will be honest, I have been dipping into your arthritis and your glaucoma medicine and its good shit man Do you know the street value, I do Last edited by kgb424; 11-17-2016 at 09:45 PM. |
11-17-2016, 05:59 PM | #80 | ||
| re: It just got real I knew you couldn't resist and answer with just a single word Quote:
Or you'll never get those mix settings right and end up blowing yerself up Then, paint one tank Lt green (oxyg) and one rust red (acetl). Then maybe they'll sorta replicate a cutting torch. Probably better come up with some micro brazing rods as well. Unless yer just gonna cut shit apart and to hell with welding it back together. Lol I'd rather have an on board plasma cutter and MIG welder... 'cuz the year is now 2016 Quote:
After the 1st of Janurary it'll be for sale / purchased most anywhere. Walmart don't sell guns... but they'll sell you some cannibus. Sounds less appealing now... 'cuz now I gotta figure out another way of being criminally mischievious Oh wait... I still own guns... that'll have me being labled as a criminal. Guess I'll be fine. I just saw on the news that one out of seven Americans are using and abusing Opiod prescriptions. So that means nobody will be sober any longer. One could only hope they'll all calm down and stop killing each other !? Legalizing cannibus doesn't really matter any longer anyways. Opiods, booze and cannibus... that's the combo that fixes anything. Or has folk not giving a chit. Here's hoping they all add some bleach to their concoction. Guess I might as well be a part of society's grand scheme. 'cuz whom doesn't want to fit in... might as well be dysfunctional too. Besides... the liberals are gonna tell me it's good for me anyways. And that I'm bi-polar or have another mental disorder requiring meds... just like their wonderful children whom are perfect little angels. so what could go wrong ? Last edited by TacoCrawler; 11-17-2016 at 06:02 PM. | ||
It just got real - Similar Threads | ||||
Give me real reviews, from real owners, exceed mad torque 6x6 | Misfit650 | Multi Axle Rigs | 10 | 12-29-2015 11:47 PM |
Is this for real? | caymin last | Chit Chat | 3 | 12-19-2014 08:15 AM |
Is this real? | jason | Chit Chat | 18 | 12-22-2010 11:54 AM |
