Go Back   RCCrawler Forums > Vendors > Locked Up RC
Thread: Locked Up RC Straight Axles - OT Shafts
Old 04-22-2014, 08:51 PM   #61
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Default Re: Locked Up RC Straight Axles - OT Shafts
They "should" fit VP housings however ... we designed they for the nylon Axial housings and made them a hair longer than Axial shafts to remove the play back there. because of this, I have had a few guys with VP housings have very tight fits or no fits.
We are currently revising the design, again ... and the new design will be more VP friendly.
Locked Up is offline   Reply With Quote
Old 04-22-2014, 08:54 PM   #62
Locked Up's Avatar
Originally Posted by winnerone23 View Post
Ready and patiently waiting a ar60 set of rear axle..
V2 beef and maybe even 5mm threads (but that can wait)..
Breaking always happens for me, from the bearing out but mainly from pin area to the threaded area..
Soon .... soon ....
Old 05-04-2014, 02:54 PM   #63
Any idea when the shafts will be back in stock? Thanks.
obebaldone1 is offline   Reply With Quote
Old 05-04-2014, 08:40 PM   #64
Locked Up's Avatar
Couple of weeks.
Working on a few new things at the moment.
Old 05-04-2014, 09:24 PM   #65
I want shafts also, along with a spool and waiting to order at the same time
Postclanker is offline   Reply With Quote
Old 05-11-2014, 07:25 PM   #66
Count me in for a set of shafts for a ar60 when soon soon gets here lol
littletoyboy is offline   Reply With Quote
Old 10-25-2014, 10:41 PM   #67
Your OT shafts for SCX10/AX10 has been out of stock for long time, when will they be in stock?
I want to order them with couple F1 spools.
Mudsy is offline   Reply With Quote
Old 10-25-2014, 11:14 PM   #68
Locked Up's Avatar
Soon!
They are being redesigned to break a little differently.
Original and V2 max load would break at the tang or in the stub when pushed beyond their limits. I wanted to ensure breakage in the center portion so that nobody gets tangs stuck in their spools or looses a wheel on course if they snap one.
So far I'm happy with the testing so I expect to move them to mass soon.
Sorry for the delay!!
Old 11-12-2015, 04:54 PM   #69
ANy information when they will be back?
PSH72 is offline   Reply With Quote
Old 11-13-2015, 08:06 AM   #70
Locked Up's Avatar
I guess we forgot to update this thread with the last batch!
The last batch sold out and after the redesign we had to change steel suppliers, then heat shops.
It's been a "fun" process, but the end result will be well worth it.
I'm hoping the next wave will hit before Christmas but can't promise that.
Old 01-16-2016, 09:25 AM   #71
Locked Up's Avatar
New version in stock now!
Old 02-11-2016, 01:59 PM   #72
Will the V3 version of OT Shafts work with the new FI spool? or I need to grind?
I am replacing a wobbly set of stock Axial straight shafts and dont want to end up with the same issue if I grind up too much of this. Let me know ASAP.
natskiboy is offline   Reply With Quote
Old 02-11-2016, 02:28 PM   #73
I have your FI spool in my Yeti along with Axial's AR60 full width kit and love it, nice and tight. Do you plan on making shafts for the full width AR60 kit?
CamaroTom is offline   Reply With Quote
Old 02-12-2016, 09:18 AM   #74
Locked Up's Avatar
Not everyone uses our locker so we make the OT shafts to a standard size.
For any given FI spool (they have not been changed BTW)... with all shafts, OT included, the expected fit is super tight.
Old 02-12-2016, 09:20 AM   #75
Locked Up's Avatar
We are working on something for AR60s.
Not sure about the full width kit yet though.
Old 06-18-2018, 05:39 PM   #76
Any idea if/when these will be back in stock?
alpine4x4 is offline   Reply With Quote
Locked Up RC Straight Axles - OT Shafts - Similar Threads
RC Axle Master's Straight 4340 Chromoly Straight Axles Cruzin Illusion EnRoute Berg 48 08-29-2009 06:07 PM
New Berg Straight Rear Straight Axles Survey LetsHandleit EnRoute Berg 31 07-30-2009 07:58 PM
Straight Axle Shafts NICKC Tamiya TLT Crawlers 1 02-11-2008 04:41 PM
You may edit your posts
