09-15-2010, 09:32 PM | #21 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Pilmat, are you run a 1s lipo. If so what mah's and how long of a run time.
09-15-2010, 09:51 PM | #22 | |
Rock Stacker Join Date: Aug 2010 Location: Montreal
When I went for the 1S, I was interested in a small package with reduced wheel speed. The big concern was servo performance, but I have been really impressed at how well the 65HB throws the heavy wheels around. Later, Phil. | |
09-15-2010, 09:57 PM | #23 |
Nice. I was looking at 1s lipo's, but want some wheel speed for bumping the back tires over under cuts. I'll let you know I'm running the DP chassis and I will have the miniQLO tires with a 4.75" WB, so I guess idk if the 1s will have the punch I need. Because the QLO's are about 2.16" tall, much bigger then the claws.
09-15-2010, 10:21 PM | #24 | |
RCC Addict Join Date: Jun 2007 Location: MESA
09-15-2010, 11:20 PM | #25 |
Rock Crawler Join Date: Mar 2008 Location: Grand Rapids
| i think Jeepkid is planning on going with an outrunner motor though so im thinkin it'll still have bump at that point what do you guys think
09-16-2010, 07:21 AM | #26 | |
As for going to 2S, I think the stock ESC will have too much of an abrupt response curve with that much voltage. The first step is quite high (initial drive) and the drive frequency could be higher too. I would really consider changing the ESC if I needed 2S, which also means changing the receiver... Side note to the ESC is that the forward and reverse are NOT the same. The reverse has a higher initial drive and even seems to have a higher top speed (this was noted somewhere in this forum and I confirmed it on my initial runs). Check that you are using the lowest initial drive for forward to get the best crawl control, then reverse your throttle channel if it is in reverse (you will hen have to swap the motor wires too to get the rig to go the right way). Phil. | |
09-16-2010, 10:05 AM | #27 |
heres a wierd thought what about having 2 1c batts with a switch controlled by a third channel to make it 2c for bursts i mean if you see what some of these guys are doing to these it doesnt seem too crazy right?
09-16-2010, 10:06 AM | #28 |
oh btw Jeepkid quit thread jacking lol
09-16-2010, 12:49 PM | #29 |
I think Im getting 2 2s and 2 1s lipos. Different voltage for different terrain.Oh murderface I'm not thread jacking at all, I just dont have all day to post on threads and have lots of ?'s. So, HAHA
09-16-2010, 01:11 PM | #30 |
It's all good fun guys, but stop bantering on a build thread! LOL Back on course: ran 1 pack through a stock truck converted with a Pinch chassis. It was only a simple basement obstacle course, but I must say that it looks really promising. When I say the truck is stock, it still has foam in the tires and ZERO weight anywhere (it's a kid's truck, but I felt so bad watching him struggle, I did the conversion for him). The ESC space is too narrow and the shocks needed to spaced with a 0.030" washer on the chassis and axle (otherwise the shock binds before it bottoms), but the rest is very well designed. I love the elastic clips built into the shock mounts. I will finish a conversion on one of my rigs and report back with full details and pics. Later, Phil. |
09-16-2010, 01:44 PM | #31 |
pilmat love your wright up and solutions to issuse with these after market chassis. Keep up the good work I will stay tuned for more wright up greatness.
09-18-2010, 09:05 AM | #32 |
let me know how that pinch chasis works out my son wants one for his 3rd b day so i really need to be sure its durable. im a little leary of him runnin the dp cuz of the really thin torsion bars
11-27-2010, 09:40 PM | #33 |
Quarry Creeper Join Date: Jul 2008 Location: Reno
Great write up! ..any updates?
11-29-2010, 11:47 AM | #34 |
Sorry guys, I've been completely swamped with slot car racing! I will definitely be back testing and developing soon, but not likely before the holidays. @Murderface, the Pinch chassis is quite sturdy and should not be a problem for anyone. I have installed it on a truck that gets treated quite roughly by the owner (10 year old) and the only damage he has managed was ripping a tire off the rim, but no chassis damage. That said the DP is great in that it lowers the moving part count. Either way, you will not be disappointed. Cheers, Phil. |
11-29-2010, 02:20 PM | #35 |
i broke 4 dps already since that post and im loving the pinch
11-29-2010, 06:17 PM | #36 |
Phil, Looking forward to more testing from you. Very informative and nicely done! |
11-29-2010, 07:13 PM | #37 |
[QUOTE=pilmat;2638770]Something I have not played with at all is gearing. I am running the stock setup which is the smallest pinion. Have you tried the biggest pinion with 1S? This will surely increase the wheel speed, but I don't know if it would be enough. Sorry I didn't reply...lost track of the post. I really think the 1s on the largest pinion would loose too much low end grunt. I love the 2s on a Sidewinder micro esc. I tuned the curve and got great results. The biggest problem is when u go with a different esc package...u run out of space to put it all. So far there is no perfect combo that i have seen or tried and I have tried almost everything. They are either controllable with no wheel speed or not controllable on the low end. And i didn't even mention run time issues with all of the choices. Murderface offered up a question about splitting 2 batteries and running a 3rd channel to cycle between low end control on the 1s and then wheel speed with 2s. LOVE the idea...TRIED IT! It works great but again u run into where to put it all. One other thing is that I did a dig and now I'm hooked. I need the 3rd channel for the dig and can't fit in any more for a voltage split like Murderface mentioned. GGGRRRRRR!!!!! |
11-30-2010, 11:19 AM | #38 | |
BTW Pilmat, great informative thread, I've referred back to it several times over the past month! Last edited by johnnyh66; 11-30-2010 at 11:22 AM. | |
12-03-2010, 06:37 PM | #39 |
Rock Stacker Join Date: Nov 2010 Location: concord
| wow
man thats bad ass i need to put up picks of my track in the back of my house i wana billed a micro track hella bad great job on the track looks like hella fun. Quote: |
07-21-2011, 08:17 AM | #40 |
Rock Stacker Join Date: Dec 2008 Location: Ahwatukee, AZ.
Love this thread.. Pilmat is an amazingly technical and detailed writer... makes everything SO easy to understand. Great work!
