10-12-2014, 03:48 PM | #1 |
Pebble Pounder Join Date: Nov 2008 Location: Littleton
| Wheel wideners with the pin drive?
Are there any around, or is this a "wanted" section item now?
10-12-2014, 04:08 PM | #2 |
RCC Addict Join Date: Jan 2009 Location: Bend
| Re: Wheel wideners with the pin drive? |
10-12-2014, 04:12 PM | #3 |
Sorry, here are the actual pages for each style. With short barrel nuts for Trekker- http://www.ebay.com/itm/251675388422 With long barrel nuts for the original Micro Crawler- http://www.ebay.com/itm/251650822885 |
10-12-2014, 04:16 PM | #4 |
Pebble Pounder Join Date: Apr 2012 Location: Herndon
Billet Works Design Sent from my ME173X using Tapatalk |
10-12-2014, 06:24 PM | #5 |
No luck on any of the above for pin drive. (not hex drive)
10-13-2014, 12:38 PM | #6 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
what is your end goal? for those prices id hit up one of the RIM makers here and get a set of rims from them... they do the offset u need and same price.
10-14-2014, 09:29 AM | #7 | |
| Re: Wheel wideners with the pin drive? Quote:
Plus, I just scored a 1/20 Lindberg Hilux body for $6.50. Looks like it might be missing a few pieces but the cab and the bed are accounted for. That might be a better body to cut up, pinch and bob to clear the MiClaws. I may try some plastic wheels some time, but I like every gram of weight I can get down low. | |
10-14-2014, 11:35 AM | #8 |
My mistake, I wasn't really catching what you were saying about pin drive wideners. I think you are looking for the BWD wideners. As far as the Mil Stone wideners, they are a tad expensive, but very nice. Ran them on my last couple micro builds. The extra 9 grams per corner really helps, the barrel nuts are very high quality, and they do provide quite a bit of extra width. As much as I dislike wideners, they're probably the only ones I'll run. As with all wideners though, they do add to the scrub radius, put quite a bit of load on bearings and shafts because of the increase in leverage that the tire/wheel combo has over the axle, and they do require a little more steering effort to do the same job. As RootBreaker said, check out some of the wheels from the various vendors here on the site. DANALLY and Fungi both have wheels available in different offsets. Then all you're left with is loading some weight in them and mounting up your favorite rubber. |
10-14-2014, 12:01 PM | #9 |
10-15-2014, 12:39 AM | #10 |
Rock Stacker Join Date: Jul 2013 Location: Forest
10-15-2014, 01:30 PM | #11 |
BWD will get them back in and you can slap those suckers on then. I waited a couple months for BWD to get the barrel nuts in when I was looking for them. The BWD units are nice though. I had some plastic units from another source and they got loose after some use. Sent from my ME173X using Tapatalk |
Wheel wideners with the pin drive? - Similar Threads | ||||
pin to pin wheel widner | johnnyh66 | Tires and Wheels | 8 | 06-01-2011 10:25 AM |
drive pin | 87silverado | Redcat Crawlers | 2 | 12-23-2010 03:29 AM |
Axle drive pin options? | mdowney | Losi Mini-Rock Crawler | 3 | 11-02-2010 05:13 AM |
Lost Pin from Drive Shaft | domer | Losi Mini-Rock Crawler | 13 | 11-13-2009 07:57 PM |
Drive pin replacements? | teamtom | Tamiya Clod Buster | 8 | 09-01-2007 12:26 PM |
