Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: jdawg53's GC-3
Old 10-28-2009, 08:25 PM   #21
We wanted to put out a chassis kit that has everything you need at a good price.
jdawg53 is offline   Reply With Quote
Old 10-29-2009, 06:19 AM   #22
I'm trying to get a list togehter for my wife of everything I will need to do a build using this chassi. Where can I get a set of the vertical body posts? Is there anything else I will need other then shocks to transform my stock MRC?
TAT76 is offline   Reply With Quote
Old 10-29-2009, 07:18 AM   #23
Those are just any small body post the stock losi ones will work..Yes if you have a stock mrc that is all you need ,you dont have to get the shocks but I would they are awsome
Gatekeeper is offline   Reply With Quote
Old 10-30-2009, 11:43 AM   #24
Since I am using the 1/18 bug body, I had to use a slightly longer post. It was origianally sized for a 3mm screw so I cut the bottom off and re-drilled.
J
Old 11-02-2009, 07:36 PM   #25
2 rear lockers in less than 10 minutes of running today .
More power equals more repairs I guess.
Rig is working awesome when its not broke
J
Old 11-12-2009, 06:13 AM   #26
Got the metal lockers installed so hopefully I can take this thing out and beat on it this weekend
Old 11-25-2009, 01:43 PM   #27
We just got the first shipment of Mini GC-3 kits. Back orders will probably ship some time early next week and the remaining kits will be available.
J
Old 12-09-2009, 10:39 AM   #28
Updates on you rig?
LIKES2CRAWL is offline   Reply With Quote
Old 12-18-2009, 04:08 PM   #29
Will that reedy 19t motor work with the stock esc?
http://www3.towerhobbies.com/cgi-bin...?&I=LXMUP4&P=7
I just grabbed a gc3 kit. I can't wait to try it out but my mini slider motor just let out the magic smoke
EKIM14 is offline   Reply With Quote
Old 12-18-2009, 05:47 PM   #30
It should as long as you don't go over 7.4 volts of battery. I ran the Reedy Stump puller in mine with a 2 cell Lipo and the stock ESC did fine.
Cave Dave is offline   Reply With Quote
Old 12-18-2009, 07:25 PM   #31
Great. I wanted to get this guy rolling without buying a new esc just yet. What pinion were you running?
Old 12-18-2009, 09:46 PM   #32
nice rig thows gc3 sure are good looking
rocks for brains is offline   Reply With Quote
Old 12-19-2009, 08:05 AM   #33
They work even better
Old 12-19-2009, 05:02 PM   #34
sorry if this is a stupid question but what weight shock oil would yall recommend for the vendetta shocks?
beaver720 is offline   Reply With Quote
Old 12-19-2009, 05:37 PM   #35
I think I am running 30wt
Old 12-19-2009, 08:03 PM   #36
I am running 40wt
Old 12-19-2009, 08:16 PM   #37
Wich ones did you use,I bought the losi ones and they are holding up fine but I wonder if the others have less slop.
Old 12-19-2009, 08:51 PM   #38
are they any longer lower shock sod ends?
i bought the suggested duratrax shocks and it made my ride hight a little low for what i crawl on.
love the shocks but now i sit too low, need fix it.
goobs is offline   Reply With Quote
Old 12-19-2009, 09:42 PM   #39
ok thanks, ill try 35, lol
Old 12-20-2009, 06:53 AM   #40
We are using the shock ends off of the stock Losi shocks. What are you using?
J
