Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: 370 insane
Old 01-23-2013, 08:31 AM   #1
Default 370 insane
losi insane 370 looking to get one for a crawler how is it..
Ohioskills is offline   Reply With Quote
Old 01-23-2013, 09:07 AM   #2
Default Re: 370 insane
Sort of curious myself, although, I just recently installed a 19T Stump Puller
Sh0rtBus is offline   Reply With Quote
Old 01-23-2013, 09:51 AM   #3
Check out the last page of johnnyh66's build thread..
There is a link to a sweet little motor
elsewhere is offline   Reply With Quote
Old 01-23-2013, 10:34 AM   #4
I just put one in my mini....
great tork and wheel speed so far....
13t pinion/60t spur on 4.1 mini pin tires...
roksloski is offline   Reply With Quote
Old 01-23-2013, 11:46 AM   #5
Been running one for a couple months. So far so good.
skinnyd is offline   Reply With Quote
Old 01-23-2013, 12:07 PM   #6
I enjoyed the Insane motors when I was running them...never had a problem...just gotta get your gearing right and watch the temps if you plan to run it longer than a typical course (5-7 mins)
ittybitty is offline   Reply With Quote
Old 01-24-2013, 05:16 PM   #7
Great motor im ruuning 3s and a mamba sidewinder pro works great
mini4wd is offline   Reply With Quote
Old 01-27-2013, 05:58 PM   #8
is it ok with the stock ESC and the losi lipo?
kyle@DI is offline   Reply With Quote
Old 01-27-2013, 06:28 PM   #9
yea its fine on a lipo and stock esc...motor is pretty sick definitely alot more wheel speed but if you order the motor order a couple extra set of tranny gears to youll need them! -
resetpunk is offline   Reply With Quote
Old 01-27-2013, 07:22 PM   #10
any advice on the gearing aswell?
Old 01-27-2013, 07:25 PM   #11
im running stock 60t spur and stock 13t pinion
Old 01-27-2013, 11:35 PM   #12
I've just began to test mine and I'm at 12t pinion on a 60t spur. Motor is barely luke warm after several 30 min consecutive test runs...but it was only 40* out.
Sent from my iPhone using autocorrect
happymachinist is offline   Reply With Quote
Old 01-28-2013, 06:19 AM   #13
Stock esc and lipo should be fine. That's what I'm running still.
Old 01-28-2013, 07:46 AM   #14
i ordered one with 10t pinion and a 62t spur but no lipo
Old 01-28-2013, 11:52 AM   #15
I run one, great little motor.
rangercat23 is offline   Reply With Quote
Old 01-28-2013, 05:10 PM   #16
some friends and i run them, work great with 12t pinion and 62t spur and still has plenty wheel speed. my son is also running a losi slider motor with 10t pinion and 62t spur and works nice too.
motoj550 is offline   Reply With Quote
Old 02-01-2013, 10:38 AM   #17
what is the smaller screw hole size I went to fastenal to get 2 to fit and they couldn't help
Old 02-01-2013, 10:41 AM   #18
What can someone do to keep the heat down?
rnemovr is offline   Reply With Quote
Old 02-04-2013, 05:39 AM   #19
M2.5 x 0.45 I believe...I can't remember how long for the stock motor plate I do know they are short little buggers I had to grind mine down
Gear down. I'm running 12/60 with good temps so far.
370 insane - Similar Threads
insane 370 motor safe for stock esc 89lxmorepower Losi Mini-Rock Crawler 9 11-28-2011 10:59 PM
Insane 370 motor swap..anybody? Mr. Ed Losi Mini-Rock Crawler 26 11-28-2011 10:56 PM
Sidewinder Micro and Insane 370 jkwrangler08 Losi Mini-Rock Crawler 10 09-03-2009 01:35 PM
Losi Insane 370 overheating stock ESC jkwrangler08 Losi Mini-Rock Crawler 8 08-31-2009 02:59 PM
