01-02-2014, 07:45 PM | #1 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
| T3rry's "Losi? What Losi?" Build
ok, so here's my new rebuild, first off, let me say i am no champ, i dont understand all the link geometry and stuff, i just like to build my truck and drive it like the clunker it is... now that that's out of the way... I'll start with the title, Losi? What Losi? Basiacally the only thing this truck will have in it when it's done that is losi is, the rear axle asselmbly, and the fromt diff gears, everything else will be non-Losi, that's why the name The first thing i'll be starting with is my FRANKENAXLE!! this i already ahve built on my current truck, so i wont go over it too much, but most people know what it is, if not, here's the original link: clicky here Next up is a hand cut chassis, this sis my own custom brew, again, i'm no geometry pro, don't know the first thing about it, so don't be too critical.. designed it up on my pc, then cut it out in vinyl and hacked it out of 1.16 G10 with my dremel. Next up i ordered one of Hulksta's Skinny transmissions: Here! Fabbed up my own plate from 1/8 G10 to mount up a mini motor. I'll likely have to cur down his Ti shaft to shorten it for the mini, but i'll figure that out as we go. and right now i am attempting to mount the works in to the chassis size plates... i think am going to drill through the side of the side plates and actually mount the trans on the side of the chassis so i don't have to try to fab up a skid... can just use some 1/16 delrin, ziptie or bolt it to the cross brace spacers for a skid plate. that's why i didn't cut the middle out of the lower chassis pieces yet. I always hated the motor sticking out the side... this is only 45mm wide, a lot wider than the average mini, but it's fully enclosed. So that's where i am right this minute, took a break to type up this thread... will keep updating as i progress. OK, got a bit more done, Transmission is mounted on the chassis side plate And i got the cab drilled out and some spacers built for the cab and chassis, here's how she sits right now... sime to start the fun part... links... i hate links. Here's a comparison of weight from the MERV transmissioned previosu chassis, to the new, new is about 20g more, i do still need to clean out some material on the chassis plates, but i also need to add a skid, so this should be close to the actual weight... the HH400 i have on order would add like 80g to this, so i am not sure it's worth it... that's a ton of weight up high for this little guy. Couple more pics, she's almost there, just need driveshafts (i think i am going with axial WB8 shafts) some body panels, a skid plate, and a motor (in the mail) the motor in there is garbage, just for mock up. And it's RTR, just waiting on some CF rod to re-make the rear uppers, and some scx10 shocks i got from a guy online which i hope to shorten and use on here... also need to pick up some solder today so i can solder on a battery connector, other than that, she's RTR. Here it is guys, the first look at my recently rebuilt 1.9 crawler, this truck started it's life as a losi mini rock crawler, pro kit... but there isn't much of that left at this point... Hulksta ax10 transmission, FRANKENAXLE frontend, axial and MIP driveshafts, xr10 stuff... custom chassis... only thing left stock is the front pumpkin and the rear axle! Check it! Ok, so the first run video has been up or a day now, time to tell you what you're looking at! . . Last edited by T3rry; 01-16-2014 at 10:22 AM. |
01-02-2014, 08:52 PM | #2 |
| Re: T3rry's "Losi? What Losi?" Build
You Crazy some of a bitch! Love it already... Big gear tranny box.. why not a bigger motor? Maybe a old school 454(400) puller or a new school HH 400 puller!? Hmmmm... Great! Thanks alot! I already did up a xr mini axle.. now this.. ugh! |
01-02-2014, 09:19 PM | #3 |
| Re: T3rry's "Losi? What Losi?" Build haha i actually have a new 400 on order, just not sure if i need it, that's a lot of weight up high, but i think it'd fit pretty well with my current setup if i did decide to run it.
01-02-2014, 11:44 PM | #4 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
Awesome stuff! I'll be running in the 1 part losi class this season as well. Looks sick so far!! I may pm you about your opinion of that trans and stuffing it into my chaotic mini pro. The motor sticking out bothers me as well!!
01-03-2014, 12:16 AM | #5 |
RCC Addict Join Date: Jan 2009 Location: Bend
Damn Terry, slow it down a little. I was just talking to you about this this morning! Awesome work, can't wait to see the results!
01-03-2014, 01:19 PM | #6 |
| Re: T3rry's "Losi? What Losi?" Build |
01-03-2014, 07:16 PM | #7 |
Ok, o can't take it anymore.. is it just the pics of ur axle or.. why are ur chubs an knucks upside down? Also, I just got a set of the 1.9 cobra's like urs.. how do you like them and how do they compare to the rovers? I'm also awaiting some 1.9 gold doo's! |
01-03-2014, 10:44 PM | #8 | |
| Re: T3rry's "Losi? What Losi?" Build Quote:
i love these cobras, i made em myself, and they seem to do what a lot of other tires wont do... i'm sold on them. | |
01-04-2014, 08:04 AM | #9 |
RCC Addict Join Date: May 2013 Location: York, PA
What's the purpose of the motor spacer? Looks like your pinion is hanging on by a thread. 45mm is a bit wide, but actually slimmer overall compared to stock motor tranny (about 55mm). The extra width may allow you to inboard all your uppers and keep it super smooth outside. Not a bad trade. Bad ass as usual......nice work. |
01-04-2014, 08:16 AM | #10 |
Rock Crawler Join Date: Feb 2013 Location: york
Now that's some nice custom dude way to go I'm inspired to actually get to the lab right now and get some bench time in on my mini
01-04-2014, 09:49 AM | #11 | |
01-04-2014, 12:21 PM | #12 |
updated the OP with the cab installed.
01-05-2014, 10:03 PM | #13 |
almost rtr!
01-05-2014, 10:57 PM | #14 |
| Re: T3rry's "Losi? What Losi?" Build also, looking at it now, i don't think i can put arms on them, my CF wheels would not clear the arms... unless i clearanced the arms,.
01-09-2014, 09:16 AM | #15 |
Pretty much complete, just have the Ti shaft with a buddy to get shortened and crossdrilled again, then i have to wait on my motor from ebay, just one of those xtreme motors... it's all i can find, i do have a HH400 puller on the way too, but i am not sure it'll fit well... and it would be an additional 100g up high, not sure that's a good idea on a 1100-1200 g truck, 1/10 of it's weight that high sounds bad to me... we'll see how the little motor goes. anybody have a reasonable source for m3 aluminum hardware? preferably pretty? (anodized) (i tried fastener express, they decided they wanted to jack up the shipping price after my order was already complete and paid... then 4chobbysupply had no stock, while their site said they did have stock... just looking for a bunch as long as i can get, i can always cut them down) |
01-10-2014, 02:51 PM | #16 |
Quarry Creeper Join Date: Oct 2012 Location: Sweden
Fastener express got the screws you are looking for! Atleast for us here in sweden! Last edited by BliB; 01-10-2014 at 02:59 PM. |
01-14-2014, 07:22 AM | #17 |
updated the OP with some RTR Pics!
01-15-2014, 10:07 PM | #18 |
Here it is guys, the first look at my recently rebuilt 1.9 crawler, this truck started it's life as a losi mini rock crawler, pro kit... but there isn't much of that left at this point... Hulksta ax10 transmission, FRANKENAXLE frontend, axial and MIP driveshafts, xr10 stuff... custom chassis... only thing left stock is the front pumpkin and the rear axle! Check it! Last edited by T3rry; 01-16-2014 at 10:22 AM. |
01-16-2014, 10:22 AM | #19 |
ASnd an overview vid Ok, so the first run video has been up or a day now, time to tell you what you're looking at! |
T3rry's "Losi? What Losi?" Build - Similar Threads | ||||
Losi MOA budget "re"build | GRIMGREG | Team Losi Comp Crawler | 1 | 01-19-2014 12:06 PM |
T3rry's 5th D SuckerPunch "evolution" thread | T3rry | Axial AX-10 Scorpion | 11 | 10-09-2013 08:34 PM |
Go from Losi "Rock Claws" w/ memory foams to HB "Rovers" (pink) w/ Proline Dual Stage | luvmycompax10 | Tires and Wheels | 4 | 01-11-2012 04:13 PM |
Monsterman's Losi Micro Crawler Scale Build "Project Scout:" | monsterman | Losi Micro-Rock Crawler | 9 | 01-27-2011 07:58 PM |
