05-07-2015, 03:13 PM | #181 | |
RCC Addict Join Date: Jan 2009 Location: Bend
| Re: 89redranger's MRC Pro build/rebuild for 2014 Quote:
I'm quickly learning though, that I am too damned blind and lack proper tools for messing with axle shafts. I'll let Erik do the next set. It's just a shame that I already cut one of the brand new XR unis I had been saving when I should have used an old one for testing and mockup. To top it off, I cut the tangs on this one a bit too far on the loose side. Oh well, what's $40? | |
10-30-2015, 01:37 PM | #182 |
Winter time is coming. About the only time I actually get to build. Starting early this year and determined to get this car back up and running for another member of the family to take over. Starting slow with cleaning things up from sitting, I tore into the MIPs that had started to look like crap. Replaced the worn rusty and crusty stock MIP pins with tighter fitting and harder 0.062" music wire, stripped the black oxide off everywhere that is visible and lightly polished the black oxide at all the contact points (male and female ends of the CVDs themselves, as well as the hex shaped sliders) without removing it to smooth them up. The result..? They look bitchin, they're WAAAAY smoother, and they are also tighter. Sadly, that's all for now... Ignore the fingerprints, swirl marks, leftover polishing compound, and buffer fuzz. They will be cleaned very well, lightly oiled with gun oil to keep the rust away, and the joints will be lubed with liquid graphite before use. Last edited by 89redranger; 10-30-2015 at 02:37 PM. |
89redranger's MRC Pro build/rebuild for 2014 - Similar Threads | ||||
My MRC PRO Build! | kwonchoba | Losi Mini-Rock Crawler | 54 | 05-27-2014 07:15 PM |
The Violators 2014 and beyond rebuild...... | The Violator | EnRoute Berg | 51 | 10-08-2013 07:23 PM |
89redranger's MRC Pro Spring Rebuild | 89redranger | Losi Mini-Rock Crawler | 15 | 08-31-2012 10:26 PM |
mrc pro build - again | bikeboy | Losi Mini-Rock Crawler | 7 | 09-03-2011 08:39 AM |
Nluv's 1.9 DarkSoul MRC Build/Rebuild | Brandon | Losi Mini-Rock Crawler | 41 | 06-01-2009 12:50 AM |
