01-21-2015, 07:26 PM | #1 |
Newbie Join Date: Dec 2011 Location: shelby, ohio
| Thread size for MRC Pro??
Does anyone know what the thread and pitch size is for the shock mounting screws. I measured it and it read 1.9mm(.075in). So it is in between a number 1.8mm and a 2mm screw, and if its US it is in between a #1 and a #2 screw. I also counted the threads and it came out to 64 threads per inch, which converts to .4 pitch in metric. I looked at all the Screw kits and none that I have found specify what comes in the package. All im trying to do is replace some the the screws on my MRC Pro to socket head cap screws so I don't strip any more bolt heads out. If anyone can help me out point me in the right direction it would be greatly appreciated. |
01-21-2015, 07:49 PM | #2 |
Rock Crawler Join Date: Oct 2009 Location: RC Blackhole
| Re: Thread size for MRC Pro??
all external threads major diameter are a little under the nominal call out. you have the right numbers they are M2 x .4. mcmaster carr has long ones to do the shock outboarding. only place i found them.
01-21-2015, 08:18 PM | #3 |
Ok, thanks for the quick response!!! Thats the first definitive answer I have gotten since I started searching. |
01-22-2015, 12:57 PM | #4 |
Rock Crawler Join Date: Jan 2006 Location: Phoenix
here is a good place for the smaller metric hardware Micro Fasteners |
01-22-2015, 07:02 PM | #5 |
Awesome I will have to order some more screws from micro fasteners next time. Too bad I already ordered some m2 x 12mm off of ebay. Metric Socket Head Cap Screw Stainless M2X12 mm Pkg of 25 RC Cars Trucks | eBay |
01-22-2015, 10:02 PM | #6 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
The most common sizes I have found in RC are: M2 on "mini" cars. Sometimes maybe M1 if it is a super tiny car M3 on most 1/10 crawlers for hardware. It is the one you will want to stock the most of. M4 is used for wheel hub nuts and on links but that is really about it. Keeping a tap/appropriate drill/clearance drill size and some screws in the most common sizes tends to get you out of a bind really fast and can be helpful if things just aren't working. Sometimes you can find "screw grab bags" but make sure they are good quality or you will be regretting that "sale on screws" very fast! |
Thread size for MRC Pro?? - Similar Threads | ||||
What size all thread? | EvanSouders | Axial SCX-10 | 8 | 08-20-2012 10:20 AM |
Omega's MRC Pro (x2) build thread | Omega-Tron | Losi Mini-Rock Crawler | 8 | 08-09-2011 06:12 PM |
MRC Pro Chassis Screw Size | Slaughter | Losi Mini-Rock Crawler | 16 | 07-23-2011 07:19 PM |
MRC Pro Roller Tow Mater Build Thread | skullking | Losi Mini-Rock Crawler | 10 | 07-12-2011 09:46 PM |
