06-04-2015, 09:02 PM | #1 |
Pebble Pounder Join Date: Apr 2013 Location: SoCal
| MRC scale build motor heat issue
Hello, I'm looking to turn my mrc into a scale trail rig. I but the 400kv motor and esc out of my mini eight in the mrc. After running around the garage for a few minutes the motor is super hot. I just purchased the mad max transmission out of there mini rock cralwer say a vid of it driving at speed with no problem. Any ideas on what to do to the tranny to reduce hear? I'm running a 64 spur, and a 16 pinion on 2s lipo. Also any good chassis out there? Thanks for the help |
06-05-2015, 04:49 AM | #2 |
Rock Stacker Join Date: Apr 2008 Location: France
| Re: MRC scale build motor heat issue
Hey, For electronics: I guess you mean 4500 kv BL motor from mini8. This motor have a hight RPM for scale / crawling. Even if you use a 11t pinion on motor, i m not sur you will reduce ratio enough. Maybe you should try a higher torque motor (lower kv), you will increase run time and decrease warm. After that, you could use 1.55" rims / tires... another option is to put an aluminium heat sink. |
06-05-2015, 04:54 AM | #3 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Yes you may need both. Also. Check for binding of wheels drive shafts etc you could have a bad bearings some where. Also you will want a sensored brushless combo.
06-07-2015, 09:38 AM | #4 |
I checked the axles and the transmission no binding that I can find. Do you have any motor suggestions, I saw on here something about a helicopter motor, I have burned up the stock losi motor twice, and I installed the atomic fireball 18 turn brushed motor with stock esc. The motor and esc got hot after two minutes of driving around the living room.
06-07-2015, 11:58 AM | #5 | |
| Re: MRC scale build motor heat issue Quote:
Have you tried to use a 11t or 12t pinion motor ? - check this thread for motors: Motors - esc for brushed / brushless: castle micro sidewinder | |
06-09-2015, 10:45 AM | #6 |
I installed the exceed max stone transmission. You have to use the skid that comes with the transmission. The out put shafts are bigger so I drilled the ones for the stock MRC out to fit. The Crawler is much faster no heat issues with the motor now. Now all I need is for tcs chassis to get off out of stock.
06-19-2015, 12:03 PM | #7 |
does anyone know of another scale chassis except the tcs l-trail. It has been on back order forever.
MRC scale build motor heat issue - Similar Threads | ||||
MRC Motor Issue | OTHGbronco82 | Electronics | 5 | 02-05-2014 09:29 PM |
Hitec 7980 heat issue | KnoJa | Electronics | 8 | 04-10-2012 12:06 PM |
MambaMax heat sink issue.... | Scattman | Electronics | 19 | 06-14-2010 10:29 PM |
