12-03-2015, 06:31 PM | #1 |
Pebble Pounder Join Date: Mar 2013 Location: ringgold
| To change or not to change??????
Hey guys first time posting my mini so I'll give a quick run down of what I've got so far. It started as a mrc rtr when I got used. I've since changed a lot. Mrc pro chassis vaterra aluminum shocks limited 10 mm all the way around. Pink mini t springs up front and the redish Browns in the rear and 35wt oil Out boarded the shocks Vaterra high clearance rear links Proline beadlocks with rovers Over drive mod in the front Clocked the chubs back Savox sc-0252 1/10 servo And running lipo So now my question is I have another set of bent links should I run them up front also or leave the stock mrc pro links? Also what would be some other good mods to do. Sent from ... Wait where am I ???? Last edited by scxscaler; 12-03-2015 at 07:34 PM. |
12-27-2015, 06:50 PM | #2 |
Rock Stacker Join Date: Sep 2005 Location: prescott
| Re: To change or not to change??????
I run straight links up front stays off the drive shaft.Looks like you could use some cvds would give a little more steering.
To change or not to change?????? - Similar Threads | ||||
If I change motors do I have to change my ESC? | Coltan | Newbie General | 1 | 04-03-2012 02:04 PM |
do I have to change ? | DirtMan1989 | Axial SCX-10 | 12 | 02-26-2012 03:00 AM |
Change for a 50 | venom-crawler | 1.9 Scale Rigs | 11 | 05-13-2010 07:54 PM |
