Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Total Zero!!!!
Old 12-01-2016, 10:57 PM   #21
snapon boy's Avatar
Default Re: Total Zero!!!!
I got a few sets of those couple of weeks ago and they are super strong and light.
149 r/c worx's Team Driver
snapon boy is offline   Reply With Quote
Old 12-01-2016, 11:00 PM   #22
I've been beating the piss out of the SDI shafts on my sporty since I built it with no issues! They are great shafts!!
blandon is offline   Reply With Quote
Old 12-01-2016, 11:01 PM   #23
snapon boy's Avatar
Have you had any trouble with the set screws backing out?
Old 12-01-2016, 11:03 PM   #24
No, I use blue loctite on them and check them regularly, never had a problem with set screws.
Old 12-02-2016, 05:51 AM   #25
I've been running the same one, on the rear of my sporty, for over a year.
Not too many set screw issues, but... Make sure ya give the screw on coupler, the slide pin retainer cup thingy, a dab of blue loc, as well..
I had to finish a comp with a body pin, holding my drive shaft together! Lol..
winnerone23 is offline   Reply With Quote
Old 12-02-2016, 11:32 AM   #26
Same happened to me
I like the shafts but I had 2 sets bend the shaft and flatten the pin that started binding the sliding motion
One thing I use is dry grafite lube for all my joints and cvd
You can get them at auto parts stores or online they are aerosol but dry and leave a film of grafite on the parts and they do not attract dirt
Down fall it's like using spray paint it goes everywhere and is black in color
stankulas is offline   Reply With Quote
Old 12-02-2016, 01:18 PM   #27
[QUOTE=stankulas;5598338]Same happened to me
Stop using 4s!!!!!!!!!!!
Old 12-02-2016, 04:22 PM   #28
I'm using the Dravtech front and rear axle housings for the mini. I've got the Wraith rear axle shafts cut to length and the flats are ground on the ends for a nice snug fit into the metal lockers. Ready to button up the rear axle now and move on to the front. .
Old 12-02-2016, 11:15 PM   #29
Rear axle all assembled. I love the design of this rear axle, goes together nicely, is butter smooth when all together and I love this rear weight system! One axle down and one to go!! .
Old 12-02-2016, 11:19 PM   #30
So on to the front axle. I went with Dravtech's knuckle/weight system and Chubs. For front axle shafts I went with Dlux's FBA shafts, bombproof and great steering angle.
Old 12-05-2016, 07:25 AM   #31
I'm using the Traxxas 7079 pinion gear to overdrive the front and picked up some shims to get the gear mesh perfect. FBA axles are cut to length and ends are ground to fit the locker so now I can grease everything up and finish up the front axle. .
Old 12-05-2016, 08:05 AM   #32
Front axle complete!! . . . .
Old 12-05-2016, 10:54 AM   #33
Dayum brutha!!! Your killing it!
Old 12-05-2016, 11:59 AM   #34
Time for links and shocks! I cut 10mm off these SCX10 Icon shock bodies and picked up some Losi shafts that are already 35mm long so no need to cut and re-thread shafts. I'm gonna try out some of the Krazed Builds shock pistons that I picked up from Robbob. . .
Old 12-05-2016, 12:15 PM   #35
Tie rod is made and it's a slider, except for the shocks that I'll be assembling tonight. Even with the steering at full tilt left or right, the FBA axles still turn smooth! . . .
Old 12-05-2016, 12:20 PM   #36
One of the coolest little features on this axle is the pocket that is built in to the Dravtech axle housing and Chub which allows you to get every drop of available steering. .
Old 12-05-2016, 04:38 PM   #37
Ssshhhhhh.. don't tell anyone this!
If you run the button head, on the bottom, you can get Even More steering!!! ;) (If you can)
Old 12-05-2016, 05:17 PM   #38
I think I may just have to try that!!!
Old 12-06-2016, 11:40 AM   #39
Shocks are done and the suspension on the truck feels nice and smooth!! The 35mm Losi shafts worked out perfect. . .
Old 12-06-2016, 01:57 PM   #40
you guys and your mini's.......
Super is where its at!
Cool build for sure.. Dravtech has got some serious stuff on lock!
EDIT: but ya know what at least its something completely different than any other class (IE 2.2s vs 2.2p.... practically the same imo)
Curcal is offline   Reply With Quote
Total Zero!!!! - Similar Threads
Total amateur in need of help! totalamature Tamiya CR-01 11 11-18-2012 07:37 PM
Total Frustration!!!! blckgnx Newbie General 15 06-03-2011 09:47 AM
Total Weight Cycleeric EnRoute Berg 14 04-20-2011 08:48 PM
Ok Total newb ? Goose Newbie General 10 02-12-2009 06:05 AM
