Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: New Axial scx 24 deadbolt
Old 05-16-2019, 09:19 AM   #1
Default New Axial scx 24 deadbolt
Here ya go Axial Racing fans, they have just dropped the 1/24th scaled SCX24 Deadbolt. The SCX24 is Axial Racing’s first foray into the 24th scaled market, have a look at big squid rc
Stangman66$ is offline   Reply With Quote
Old 05-16-2019, 09:30 AM   #2
Default Re: New Axial scx 24 deadbolt
SWEET!!!
BIGW0RM is offline   Reply With Quote
Old 05-16-2019, 10:18 AM   #3
My Cr-24 from Banggood JUST shipped. Aww well, I guess I'll have to get both.
shimey is offline   Reply With Quote
Old 05-16-2019, 12:49 PM   #4
I just order both colors....
t9dragon is offline   Reply With Quote
Old 05-16-2019, 02:42 PM   #5
Right! Just ordered a CR24 last week. Doh!
JeepinOR is offline   Reply With Quote
Old 05-16-2019, 10:44 PM   #6
I like the new Deadbolt, but I'm a bit worried about those tiny plastic balls. The coilovers look great. The body is sweet as well. It has nice wheels and tires, and I'm quite interested in that Dynamite 88T motor for my ECX Barrage (unless that's what it already has).
It has a 2-in-1 ESC and RX. I'm sure that's the first to go, but everything else looks fantastic!
Xrayray is offline   Reply With Quote
Old 05-17-2019, 04:30 PM   #7
In case you didn't see, the scx24 uses a 3 wire servo, so replacing the esc and receiver should be as easy as it can get
BashNSlash is offline   Reply With Quote
Old 05-17-2019, 08:49 PM   #8
The upcoming HobbyPlus electronics upgrade kit will also have an 88t 030 motor, I wonder if it's the same motor
Sent from my LGMP450 using Tapatalk
spoo76 is offline   Reply With Quote
Old 05-17-2019, 10:07 PM   #9
Yeah I did, that's pretty cool
Old 05-17-2019, 10:08 PM   #10
How does a 030 compare to a 050?
Old 05-17-2019, 10:32 PM   #11
030 is what comes in the RC4WD, Ambush, CR-24, and similar to the Losi motors.
050 is a longer can version used in the Barrage/RGT/FTX
Old 05-17-2019, 11:57 PM   #12
The sales release info says it’s a 180 motor.
Old 05-18-2019, 12:57 AM   #13
I saw that and that's what I initially said, however that information isn't repeated and the picture shows what looks like a typical 030
Old 05-20-2019, 03:22 PM   #14
I preordered one. I'll post when it gets here.
I've been wanting to see Axial get into 1/24s for a long time.
I have a ProLine Ambush and its cool but discontinued and no aftermarket. I am hoping that with Axial getting into this market maybe this size will get more popular and some decent aftermarket will pop up.
fortysixandtwo is offline   Reply With Quote
Old 05-20-2019, 06:07 PM   #15
Hopefully it's a 180. If not we'll slap a 050 in it.
Here is a close up of the motor. I thought it lookeds like a mini z motor at first look. But now that Ive googled both the FF-030 and the mini Z motor. I think your right. It looks like a typical FF-030 now.
The notches in the back of the can give it away. = (
Mini Z motor:
RC4WD FF-030:
Here is what the manual says is the replacement motor. Which now that Ive taken a closer look at. Looks exactly like a FF-030 can too.
Well whatever it is. Well see when it hits! But you are probably right on the money Spoo76.
Old 05-20-2019, 06:11 PM   #16
https://youtu.be/H_DbIfV-QTg?t=473 7:54 in the Harley Designs PLBTF video has some SCX24 crawling action. Looks nice and controllable. Is that slowed down at all or real time?
jessedacri is offline   Reply With Quote
Old 05-20-2019, 06:23 PM   #17
It didnt look THAT slow to me. But anything with worm gears typically is much easier to control throttle wise. Im sure it drives slower than most the others just because of the worm gears.
Cant go wrong with the WORM.
Old 05-20-2019, 06:53 PM   #18
You can usually tell the 030 from the 130 or 180 by the shape of the can even if you can't determine the size.
It looks like a crawls as good as any other worm gear crawler like the Losi or ambush, however this will have a longer wheelbase than either with bigger tires.
Old 05-21-2019, 10:34 AM   #19
Found this in the manual...
"SCX24 030-Motor with Pinion (DYNS1217)"
I am curious to know if this 88T 030 is stronger than all the other 030 motors typically found in micros.
If not, I will slap a 050 motor in mine like I did the RC4WD mini.
Old 05-21-2019, 01:08 PM   #20
Well we know it's 88t so assuming the same style armature the magnet strength is something to consider, I know the RC4WD motor 030 has more turns, however it doesn't have work gears so the 88t may be a decent match. Swapping to a 050 could be better if it had more magnets or the right wind, you can get away with a few less turns on longer can motors
New Axial scx 24 deadbolt - Similar Threads
SCX 10.2 Jeep XJ Body on SCX 10 Deadbolt? sacsmitty Axial SCX-10 5 08-15-2018 12:16 PM
My new Axial SCX-10 Deadbolt KA7EII Axial SCX-10 4 05-21-2016 09:24 PM
New scx 10 deadbolt BigCountry11 Axial SCX-10 8 07-25-2014 10:00 AM
