Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: SCX24 Flat Skid Project
Old 03-05-2022, 11:50 AM   #1
JC3
Default SCX24 Flat Skid Project
Designed and printed, what might be the first, flat skid for the SCX24.
Apparently, there is a kit called the Killr Chassis that comes with a flat skid but I do believe that that skid is just for their chassis. I could be wrong and have asked somebody to verify that. My skid uses the stock SCX24 mounting holes, except of course, for the upper links.
*Update: I confirmed with someone who bought the Killr Chassis that their skid does not fit stock SCX24 rails and that the holes are different.
Short video here:
https://youtu.be/4EANFDLBbJk
Last edited by JC3; 03-06-2022 at 09:34 PM. Reason: grammar correction and update info.
JC3 is offline   Reply With Quote
Old 03-05-2022, 01:26 PM   #2
JC3
Default Re: SCX24 Flat Skid Project
Final version, printed at full strength, cleaned up, and ready for install.
Old 03-08-2022, 03:14 PM   #3
JC3
Happy to say that the 050 motor clears the upper links just fine. However, just like before with the stock skid, the motor hits the upper links at full compression.
Old 03-11-2022, 05:13 AM   #4
Curved higher clearance links would be the solusion. Surprisingly such links are not on the market.
Ynad is offline   Reply With Quote
Old 03-11-2022, 07:49 AM   #5
JC3
Not in this case. The links hit at the back of the motor, so the only solution is a set of custom bent links that bend around the end of the motor. I made a set for my Warthog build.
Old 03-11-2022, 11:09 AM   #6
I see. Just a thought. Would off set link end help? If the link mounting point off the line of the link could it be possible? I was thinking about this problem with the 050 motor. Don't have the 3d printing abilities so can't experiment. Best idea I came up with is a notched tube link but that just a couple of millimeters of clearance.
Right now I've got some shapeways high clearance links they are slimmer and are enough for my use.
Sent from my LG-V521 using Tapatalk
Old 03-11-2022, 02:13 PM   #7
JC3
Yes, moving it off the line of the link is what I did. The arrow points to the motor and the bend in the links.
SCX24 Flat Skid Project - Similar Threads
INTHEWORKS RC Flat skid! Neezy916 Axial Capra 1 07-29-2020 10:06 PM
Anyone Use Vader Products Flat Skid? jwag1973 Axial SCX-10 5 06-15-2020 04:29 AM
Flat skid for the Capra? TheLetterJ Axial Capra 28 10-16-2019 02:24 AM
Flat skid for dummies Otto Man General Crawlers 2 01-14-2006 07:19 PM
