05-13-2012, 05:48 PM | #41 |
Rock Stacker Join Date: Jan 2012 Location: Land O' Lakes
| Re: RC4WD "Beast" reconstruction to Man 6X6 Hybrid w/triple steer Primer flat blue, like a couple of those European 1:1 rigs I saw in the youtube vids. Like its been sitting outside for 50 years.
05-13-2012, 05:49 PM | #42 |
| Re: RC4WD "Beast" reconstruction to Man 6X6 Hybrid w/triple steer |
05-13-2012, 06:01 PM | #43 | |
Quarry Creeper Join Date: Dec 2011 Location: Flat Hills of Florida
| Re: RC4WD "Beast" reconstruction to Man 6X6 Hybrid w/triple steer Quote:
I like that idea, a really dirty washed out blue. Beleive me I've seen hundreds of videos of the European trials and a lot of them are painted bright colors so I'm perplexed what to do. I started fitting the body and have a little ways to go yet but have to build the bumper and roll cage befor I paint so I have some time. BTW, IDK if the video of the winch worked for you and others but it didn't for me when I tried it so I downloaded the video on YT and replaced the link. | |
05-14-2012, 03:53 PM | #44 |
Change of plans possibly ? Thinking of yanking the 2sp tranny out and installing a R2 trans with a Tekin 1400kv 1/8scale buggy motor and run it sensored on 2s. That motor is 4 pole and will have lots of grunt. Then I'll throw the 2spd in my 1.9 Scaler build ?? |
05-14-2012, 05:58 PM | #45 |
Rock Crawler Join Date: Aug 2011 Location: Baton Rouge
How is the strength on the spool itself? You help keep my brain on constant think mode with all that brass work!
05-14-2012, 06:18 PM | #46 |
The center of the spool that the line will be wrapping around is doubled up tubing 3/16" inside a 1/4" piece then using (4) 2mm screws fastened to the alum servo horn. I "hope" it'll be plenty strong but I will test prior to install once I figure out what I'm using for winch line ? May just test with some Power-Pro.... I figure if the spool want's to bend or tweak under heavy load I can always build something to support the end of the spool much like a reg winch is, trying for simplicity for now. |
05-14-2012, 07:11 PM | #47 | ||
I have an idea for a support for the other end of the winch spool, should be able to incorporate a bearing as well. I also will make a housing to completely cover the servo/spool assembly to make it have a level of realism. | ||
05-14-2012, 08:47 PM | #48 |
Word!!!!!
05-15-2012, 03:14 PM | #49 |
First Test Today ! Took a while to get the steering perfectly centered x3, can still use some fine tuning but was anxious to run. I ran nearly a whole 5000mah 2s pack just hacking around and I'v def decided to step up the power and voltage. I ordered the Tekin 4 pole 1400kv 1/8 scale buggy motor and will prob run it on 3s for the power and efficentcy. If a tire or two gets kinda wedged theres no way 2s is gonna get this pig out of trouble especially if trying to help other's out of a jam. Steering worked typical for the lenth of the thing but that 3rd axle really brought the thing to life, has fantastically small truning radius. Very breif video, sorry for shaky and spotty focus. Was trying to hold the DX7 TX and the camera while driving. The Beast Mann/Hybrid 6X6 Steering Test - YouTube . Last edited by BONDONUTZ; 05-15-2012 at 03:16 PM. |
05-15-2012, 03:28 PM | #50 |
Rock Crawler Join Date: May 2012 Location: Upland
looks really cool! have to sub this thread to watch!
05-15-2012, 05:34 PM | #51 |
Pebble Pounder Join Date: Jan 2009 Location: Bucktown
I like to use 100 LB. test spider wire fishing line for my winch line, works good for my 20+ lb. Rigs
05-15-2012, 08:47 PM | #52 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Very cool rig! Looks to be running great! I'll be curious to see it on 3s with the 1400kv. Shouldn't have any problems mounting that motor right? Can't wait to see it with the body on |
05-16-2012, 02:32 PM | #53 |
I managed to disassemble the Mann body today, wasn't that hard since the joker that put it together did a piss poor job. The Hot knife greatly simplified the job, best 10.00 I spent in a a loooong time. I've already removed a lot of material from the floor pan so it pretty much can be resting on the chassis plate to get the COG low as possible. |
05-18-2012, 07:11 PM | #54 |
Updates updates updates!
05-18-2012, 07:39 PM | #55 |
Rock Stacker Join Date: May 2008 Location: Des Moines
i'm going to keep an eye on this one, I'm totally fascinated with multi axle rigs. keep up the good work!
05-18-2012, 08:48 PM | #56 |
At least someone is paying attention, thanks guys ! I've ben tinkering with the floor pan and pretty much rebuilt the entire thing. I added a 7"x3.5"x3/16" sheet of Kydex and extended the fenders wells where needed, it's solid as a rock now. Working with the plastic is entirely new to me and I must say I enjoy it very much, On a whim I made the needed door hinges and found the plastic is really nice to work with even making small pieces. It's pretty late right now and I'm beat, I'l post a few progress pictures Sat when I get home from work after I slam a few beers. |
05-19-2012, 10:51 AM | #57 |
I'm reassembling the cab so it sit's roughly 15mm lower onto the cab floor to help lower COG. The cab floor will be mounted directly to the chassis plate and will include some rubber isolators as well. |
05-21-2012, 03:09 AM | #58 |
Rock Crawler Join Date: Jun 2007 Location: Working in my dream RC workshop and remodeling my entire home.
Awesome work, man! Gotta subscribe to this for sure!!
05-21-2012, 12:58 PM | #59 |
Last week was uber busy for me, I was in charge of the hobby shop while the boss and son went to the Keys for 10days, lucky bastards. Anyway, for holding down the fort etc the boss gave me some lipos and paid for the Tekin motor I asked him to order me this morning. Paying for the motor was def a awesome gesture but IDK about these lipos. They've ben hanging on the peg for at least 4yrs that I can recall. Apogee made a AWESOME pack back in the day but since sitting for so long it's questionable they're any good. I'll check the indiviual cell voltage and go from there ? Redline T8 1400kv TT23542Y4S-6S140018.5mm 1/8scale buggy motor, sensored |
05-21-2012, 02:44 PM | #60 |
Just watched the video and cant wait to see the next one with the body on it!
RC4WD Beast 6x6 Reconstruction, Crawler/Recovery truck "Heavy Mental" - Similar Threads | ||||
Official Reveiw,,,Pit Bulls "Rock Beast" 2.2 Prototype | dezmoon | Tires and Wheels | 389 | 05-04-2011 09:32 PM |
RC4WD "Beast" 6X6 survive Foff??? | LumTheMad | Formula Offroad | 8 | 03-29-2011 10:07 AM |
Project "TimberWolf" 1.9" Scale Yota Hybrid | 51WillysJeep | 1.9 Scale Rigs | 53 | 08-14-2008 06:43 PM |
