01-05-2010, 10:42 PM | #61 |
Quarry Creeper Join Date: Dec 2005 Location: kerrville
First off the best truck is mostly determined by the driver.....unlike other R/C formats the performance is determined by how well you can understand the terrain your goin over and what the handleing characteristics are of your truck. So the best truck comes from matching/adjusting the handleing characteristics to the driver himself. That being said, the best truck handleing characteristcs are based on how you set-up your truck (i.e. how you tune it!!) Any knowledgable RC crawling enthusiast can take nearly any brand of vehicle and build it up into a first class truck. There is NO complete off the shelf kit that you are going to be able to buy that will be anywhere near as tuned, capable or resilient as a purpose built crawler from aftermarket parts. So if your goal is to have the "very best truck for you" then you are going to have to build it from scratch...or at the very least get a particular kit and change MOST of it as you go till you find what works for you. To get started you need to decide if you want a "scaler" or "competition " rig....as said before a scaler is an attempt to have the most realistic truck possible, think really awesome working scale model. a competition rig is purely about performance. If you want a scaler I would highly recommend starting with a Axial SCX-10 kit. It has all the basics you need to get a scale truck going and then its just a matter of $$$$$$ to start upgrading all the component parts to better, stronger stuff, purchase the scale body of your choice and to buy all kind of fancy items to make it look good. IF you want a competition level rig then it gets a bit more complicated you must decide which class of rig you want to run. 1.9 class is the mini crawler class that is like 1/18th scale....the Losi mini is currently the best option in this class...once bought simply start spending big $$$$$ to upgrade everthing into aluminum parts that you can, completely replace all the electronics, and then begin the never ending process of tuning your rig. 2.2 class is currently the most popular/competitive class....it is 1/10th scale and runs with a wheelbase up to 12.5 inches. with this class you will have to decide on running a rig with driveshafts or one that has independant motors on each axle....there are pros and cons to each, but most go with MOA rigs. If you want a shafty go with either the Losi comp crawler or any axial kit. IF you want to go MOA get either a Berg or bully kit. Once you made your purchase (doesnt matter what you decided) strip it down till your just left with the axles....this is where you will start from. (scroll down to getting started) Super class is the largest, most capable and technically challenging class both from a driving and building stand point. As such very few people have the money and skills for this class. For this class you want to use MOA axles. In all honesty there is no good kit for this class it is truely a builders class and if you cant or wont fabricate alot of stuff yourself it is a miserable undertaking as nearly everything must peiced and altered to work. You should go with either a superbully , Clod, or self fabricated axle. GETTING STARTED First and most important is to set aside a entire evening or better yet an entire weekend to simply read/research tech threads on this site!!! Rock crawling is about knowledge and properly applying it...whether its driving or in building/tuning your truck. I would at the very least go thru and read every topic in this thread--->TIPS, TRICKS, and MORE INFORMATION THAN A NEWBIE CAN HANDLE And then go read as many build threads as you can in the actual section for what ever brand truck you decided to get. pick threads that have more than just a few pages. Taking note of what parts they are using. Then order a chassis....actual make doesnt matter as long as it is something you will regularly see being used on these forums....truth is any reputable vendor on this site will have made a strong platform. Next order your electronics....you will want 300+oz torque servos, a high quality ESC that will work with brushed motors and a good TX/RX. Then order a good set of shocks that work with your type chassis and either build or buy the links if the chassis didnt come with them. You will also want to buy a good set of brushed motors if Money is no object get Hand wound motors in the 35-45t range. Once everything is assembled you will have to then drive it in order to see what you like and dislike...as you change a part or adjust the suspension from this point on only change one thing at a time so you can tell if it is an improvement or not. Rock crawling is about tuning your rig...adding weight, moving link placement, adjusting suspension and tuning tires. The best components in the world will not help if the rig is not tuned to your particular driving style. Which is why there is no such thing as a single best rig. I hope this helps....if you have any further general questions about the above then you need to repeat the first step. If you are the impatient type like most....simply get a ready to run or almost ready to run kit of your choice....by the time you get thru your first battery pack you will be addicted enough to actually enjoy reading every single "tech" thread on this site for enjoyment. And within weeks will have everything you think you need on order for the best truck!! |
01-05-2010, 11:46 PM | #62 |
Rock Stacker Join Date: Jan 2010 Location: montreal
Thank for the info about neer a week in the forum and website many rig are very interested I finaly stop on 2 losi comp worminator now the why losi comp easy to get replacement parts RTR have the dig etc. Good review and I think I can make upgrade for it visit my business www.flyrcrivesud.com worminator very nice desing and my selft as a designer this look very good the curve are nice. Only the tire in my opignon are not the best around so as a business men I have to go with the losi many will be sold that mean big $$ for after market parts my choice is made thank you all now what brushless motor give the best torque send some link |
01-06-2010, 10:53 PM | #63 |
did so research for motor and speed best out there at the moment but could be something else novak goat 18.5 Now looking for a nice tube no body any one have one good for the losi comp. I think integy make one |
01-07-2010, 07:38 AM | #64 |
Rock Crawler Join Date: Sep 2009 Location: My Old Kentucky Home....
I wouldn't waste my money on anything Integy puts out, other than a few of their tools.
01-07-2010, 03:18 PM | #65 |
Newbie Join Date: Oct 2009 Location: Tigard
Worminator looks good, but hardly anyone runs one. Probably cost..... I enjoy my shafty losi, but it money wasn't an issue????????
01-07-2010, 05:48 PM | #66 |
Newbie Join Date: Dec 2007 Location: The Woods
Sonat...Nice jeep. Looks great with the boggers. A little dirty for my taste though. I have a Cj5 too and love it. I want a cj body for my ax10 and found this one http://www3.towerhobbies.com/cgi-bin...?&I=LXUYX9&P=7 Instead of putting it on my Ax10 I built a tube chassis super that fit inside the body and used it for body panels on it. Came out pretty cool. 2.2 are fun but supers are awsume. I think building it was as fun as running it. |
01-07-2010, 09:44 PM | #67 | |
and dont go brushless,get a brushed setup. I and most everyone in our club runs a fxr,I run 45t but most guys are running 35t you can get a fxr combo for 125 maybe. | |
01-07-2010, 09:48 PM | #68 | |
my real jeep is for the trails the front and back are lock big v8 make a lots of noise I love it, it put a lots of mud in the air!!! STILL LOOKING FOR A TUBE CHASSIS A BIT OF HELP WILL BE NICE ( LOSI COMP 1/10 ) SEND SOME LINK | |
01-07-2010, 09:51 PM | #69 | |
I prefer brush-less the inside stay clean never ever again going to brush motor did a lots of racing and hate those motor to much work!! | |
01-07-2010, 10:04 PM | #70 |
tube that I have found http://www.rcpcrawlers.com/product.p...age=1&featured http://www.rcpcrawlers.com/product.p...age=1&featured http://www.rcpcrawlers.com/product.p...age=1&featured http://www.rcpcrawlers.com/product.p...age=1&featured not a tube but I know a friend that will get that one http://www.rcpcrawlers.com/product.p...2&cat=4&page=1 |
01-07-2010, 11:18 PM | #71 |
well.racing you are thrwing up dirt. not really a problem crawling. but you may find you want to go trucking in the water. and coging at low rpm is a problem I hear. if you start a poll who runs what brushed or brushless. I think the brushed would have around 75% of the votes dirt,especially oval is a different story. |
01-08-2010, 06:40 AM | #72 |
Rock Crawler Join Date: Oct 2008 Location: Florida
Have you looked at the traxxas summit? If your not competing and want to bash in the water, go fast and have a fun this thing is a beast. It is by no means a serious crawler or anything you could compete with but it is very well built and a blast to drive. Just a thaught. http://www3.towerhobbies.com/cgi-bin...&P=SM&I=LXWEN9** But like said in previous posts what are you wanting to do? There is a lot of knowledge in this forum and everyone is going to have a diff opinion on whats best. IMO I started out with a axial and now have a berg and it is a nite and day improvement. With that being said axial is a great company that has the best of both worlds of competition crawlers and scalers. The drivetrain parts and the product support from axial and all of the vendors on this site make it a great platform for someone to go any direction they want. |
01-08-2010, 07:15 PM | #73 |
maybe going for that one http://www.prolineracing.com/product...em-223-31.html it also have a lexan cover any one have more link of tube that can be buy |
01-08-2010, 07:30 PM | #74 | |
Quarry Creeper Join Date: Dec 2009 Location: Cape Cod
http://www.rpphobby.com/product_p/pro6055-00.htm I saw it at my LHS too. It looked cool but seemed too wide in the hips to do tight quarters crawling with. | |
01-08-2010, 07:37 PM | #75 |
Newbie Join Date: Jan 2009 Location: montreal,quebec
| you hate it? |
01-08-2010, 07:56 PM | #76 |
hi today I made a new thread look at it sorry bad English writhing french peoples http://www.rccrawler.com/forum/showt...42#post2214242 |
01-09-2010, 08:50 AM | #77 |
Dead link.
01-09-2010, 09:46 AM | #78 |
01-09-2010, 10:14 AM | #79 |
Newbie Join Date: Nov 2008 Location: EAST TN
Berg 2.2Mine crawls circles around the losi.
01-09-2010, 10:28 AM | #80 |
