01-15-2012, 02:19 PM | #1 |
Pebble Pounder Join Date: Jul 2011 Location: Birmingham
| Motor Burned Out
Ok, so obviously I can't "put the smoke back in" but the motor burned out. I just put on 2.2 mudsslingers with a 27T motor and it burned out in less than 2 minutes. I'm also running a 3s (never had a problem with the 1.9 with this motor) and traxxas xl 5 esc. Any suggestions before I burn out another motor?? I did have a 55T in earlier today and it didn't burn out when I did my first test drive |
01-15-2012, 02:38 PM | #2 |
| Re: Motor Burned Out
Depending on the rig, a 27T is rather "hot" (AKA, fast) for a crawler. A 35T or higher is usually more suited for crawling. What rig do you have? Do you comp or run for fun?? A "hot" motor has little torque, thus is tries to keep things going by volts/amps, thus heat, thus, "letting out the magic smoke". |
01-15-2012, 02:47 PM | #3 | |
| Re: Motor Burned Out Quote:
I'm just a fun runner! Everything is up and running good now. Thanks for the help!! | |
01-15-2012, 02:54 PM | #4 | |
You can go "real cheap" for a sealed motor for ~$10, mid-range machinewound for $20-$30, or good handwound for $45+. | |
Motor Burned Out - Similar Threads | ||||
Axial 27t motor burned out | TRDGUYSCX10 | Axial SCX-10 | 4 | 07-18-2011 11:29 PM |
Anyone else get Burned Out once in a while? | Krakker | Chit Chat | 35 | 03-25-2011 09:13 AM |
burned motor or ESC??? HELP PLEASE | raolguio | Electronics | 9 | 02-16-2011 07:10 PM |
how to tell if a brushless motor is burned? | honchoscaler | Electronics | 0 | 12-19-2010 01:39 PM |
Who has burned out the stock motor by flipping the tranny? | Psycho-Savvy | Losi Mini-Rock Crawler | 10 | 02-09-2010 04:52 PM |
