Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: pinion gears
Old 01-26-2012, 10:41 AM   #1
ax10tn's Avatar
Default pinion gears
i was wondering about doing the the 32p gear swap but wondering if it is a good upgrade from the 48p gears im running a 17.5t novak ballistic brushless with mamba max pro and a 2 cell lipo all stock gear from the tranny to the axle gearing. if i should do the upgrade where do i get a good set at?
ax10tn is offline   Reply With Quote
Old 01-26-2012, 04:26 PM   #2
Default Re: pinion gears
well for 1 what is it going in? but running only a 17.5t on 2s the 48p will be fine. if you were running 3s you would still be fine if the gear mesh is good, if you were to use 4s on that motor i could see 32p but otherwise there is no need.
benoj is offline   Reply With Quote
pinion gears - Similar Threads
Pinion Gears T/C Hunter Team Losi Comp Crawler 14 12-16-2010 10:33 AM
Pinion Gears ducatiman General Crawlers 5 07-08-2009 07:06 AM
Questions about spur gears and pinion gears... Chadworkz General Crawlers 6 12-03-2008 02:04 PM
pinion gears daleo8803 General Crawlers 1 09-30-2008 07:21 PM
Pinion Gears 3.3 Over EnRoute Berg 5 08-27-2008 09:41 PM
