03-03-2012, 04:36 PM | #1 |
Newbie Join Date: Jan 2009 Location: round rock
| running water in tires with out foam. good or bad?
so i have beadlock rims & i removed the foam and added water. man that helped on crawling in a big way. we did this out 1/1 buggys so i was thinking if it worked on them then it would help on my 1/10 scale truck (honcho). do any of ya'll do this if so what do you think (helps or not) if you don't why not? |
03-03-2012, 06:57 PM | #2 |
| Re: running water in tires with out foam. good or bad?
no one out there has done this? it also adds weight to help on climbs.
03-03-2012, 07:08 PM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
Most people who use foams will cut/drill holes in their tires or rims so the tire can breathe, this allows the tire to conform to rocks and get better grip. I can see how water would add weight but you can't vent the tires so they'll conform to rocks less and might have a tendency to bounce instead of grip. I've heard of people putting metal BB's in tires instead of foams, it helps with keeping the weight low in the tire but still allows it to breathe. They also won't fall out if they're bigger than the vent holes, water would leak out if you did vent the tires. I've never heard of it but if it works for you, go for it. |
03-03-2012, 07:50 PM | #4 |
i like the idea of BB's i think i will try that.
03-03-2012, 10:03 PM | #5 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
I've used antifreeze a couple of times to get that bounce effect. Anymore I stick to either air for my scalers and foam for my crawlers. It's just easier and proven.
03-04-2012, 11:12 AM | #6 |
Pebble Pounder Join Date: Feb 2012 Location: Bedford
I dismounted mine, lined the wheel with automotive stick on wheel weights, then put the tires, and foam back on... works great. Has more weight, and still has the foam for tire support.
03-04-2012, 01:40 PM | #7 |
My only comment is.....it's fine when you have low wheelspeed....sucks when the wheels are running free. If the tire shape is less than true, the weight is off center. It won't matter if you're running water, BB's, etc. Just my take on it. Yes, it's been tried. No, I don't know how well it works. |
03-04-2012, 07:44 PM | #8 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
| Re: running water in tires with out foam. good or bad? Hit it right on the head. And not running foams makes your tires super floppy. They'll wad up in up hill climbs and roll to the rim on a side hill.
03-04-2012, 08:34 PM | #9 |
| Re: running water in tires with out foam. good or bad? my rims are true beadlocks & they seal up really well. with the tire full of water and air they don't wrap up, roll over on side hills. they bite really good on the rocks just like our real buggys do. the only problem i have is mounting them with 3/4 water. it's a real pain. i like the idea the one guy posted about using wheel weight and foam. i think i will try that.
03-04-2012, 08:55 PM | #10 |
| Re: running water in tires with out foam. good or bad? |
03-04-2012, 10:11 PM | #11 |
i guess i can do that with my beadlocks? i will have to look into this.
03-04-2012, 10:28 PM | #12 |
Not to be a prick but have you read any threads about traction or anything? The lead in the wheels is the normal way to do things. The only option that's much better is weight in the actual wheel design or knuckle weights.
04-16-2012, 03:37 PM | #13 |
Quarry Creeper Join Date: Feb 2012 Location: Fort Worth
Isn't the idea of a forum to generate NEW ideas that haven't been tried yet? If the water works well, who cares what the normal way to do things is.
04-16-2012, 03:51 PM | #14 |
Dude, just chill. First, you bumped a month old thread to start an argument, not cool. Second, yes, it is cool to come up with new things but if they worked really well then everyone would do it. There is a reason that foam tuning and weights have been around so long |
04-26-2012, 03:02 PM | #15 |
From what I've seen on the forum ScaleFreak93 it's usually you that needs to chill. I had no intention of starting an argument or getting anyone exciting. I guess the all caps "NEW" sent the wrong vibe. I just figure if the guys wants to try water, let him.
04-26-2012, 03:18 PM | #16 |
Yea, it's hard as hell to tell ones inflections through text |
04-26-2012, 04:07 PM | #17 |
I searched "water", "titles" only constrained to the "tire and wheel" section beadlocks and water weight Function of weights, water, lead, and foam? water filled tires |
04-26-2012, 04:58 PM | #18 |
Rock Stacker Join Date: May 2011 Location: tenino
if it works use it..the only problem i see is if you get a tiny hole in the tire it will deflate and now you have a flat...just my two cents.... |
04-26-2012, 05:36 PM | #19 | |
| Re: running water in tires with out foam. good or bad? Quote:
Look around a little bit and you can't help but notice that there aren't many people who use the old methods anymore. | |
05-11-2012, 03:43 PM | #20 | |
running water in tires with out foam. good or bad? - Similar Threads | ||||
Anyone running vp foam | ax10tn | Axial Wraith | 1 | 02-08-2012 08:01 AM |
running no foam? | axialnut | Newbie General | 4 | 01-06-2011 12:25 AM |
Running no foam | Smewhtguy | Tires and Wheels | 13 | 01-04-2009 06:00 PM |
do i trim the memory foam like i did the reg foam with the stock tires? | bmuenter | Tires and Wheels | 8 | 08-15-2008 08:59 PM |
Foam set-up for running mashers on mud and water? | andres-tavares | Tires and Wheels | 4 | 07-28-2007 05:13 PM |
