08-15-2012, 06:15 PM | #1 |
Newbie Join Date: Jun 2012 Location: agassiz
| Steering links rubbing HELP!
Hey all noob question I installed vp c-hubs and knuckels today. But when I got it all Together the servo horn and ball end rub on the lower steering Link. Steering link is crtc hd oem replacement servo horn is a Roboteck alum high torque. Can I rotate my c-hubs forward So they clear. Thanks |
08-15-2012, 06:43 PM | #2 |
What kind of crawler do you have?
08-15-2012, 06:51 PM | #3 |
| Re: Steering links rubbing HELP!
I have a wraith
08-15-2012, 09:32 PM | #4 |
Rock Crawler Join Date: Jan 2012 Location: Hudsonville, MI
Do you have your steering link mounted under your ackerman plates, and your drag link mounted above your ackerman plate? Attachment 206285 Might be hard to tell from the pic, but you can see how my steering link is mounted under the ackerman plate, and the drag link is on top. You can see the red ackerman plate between them. Sent from my iPhone using Tapatalk. Last edited by 2-shot; 07-28-2015 at 04:06 PM. |
08-16-2012, 11:06 AM | #5 |
No I don't the steering like I have is the same as the Oem one where the drag link is fixed to the steering link. I'm guessing I'm going to need a two peace system. |
08-17-2012, 12:34 PM | #6 |
If you could post a picture of your Wraith so we can see what is going on, it would make it easier for us to help you.
Steering links rubbing HELP! - Similar Threads | ||||
rubbing lower links? | BELADOG | Axial Wraith | 50 | 03-19-2012 08:51 PM |
Tires Rubbing on Links solved! | oahuzuki | Losi Micro-Rock Crawler | 0 | 11-17-2011 03:06 AM |
Tries Rubbing on front links? | Stephen25 | Axial AX-10 Scorpion | 5 | 06-28-2009 07:28 PM |
Tires rubbing lower links | JLP75766 | Axial AX-10 Scorpion | 11 | 09-09-2007 01:51 PM |
Rubbing issue with Junfac links | GraTou | Tamiya TLT Crawlers | 11 | 12-14-2006 06:26 PM |
