01-05-2013, 03:01 PM | #1 |
Newbie Join Date: Dec 2012 Location: Farmington
| FXR Calibration and setting radio end point for steering servo
Issues I'm currently having with my first crawler build... 1. Using a Futaba 4PKS (programmed thanks to Harleys direction here and on YouTube) w/ R614FS receiver, I cannot get the ESC on channel 3 to calibrate. Channel 2 is no issue, but channel 3...no go. CC BEC is wired to battery wires off ESC and light is on...plugged into channel 4 Both ESC's will calibrate if/when plugged into channel 2. I can't figure out what I'm doing wrong here? I'm sure it's something simple...I'm just not that smart! lol! Second question, how do you set the steering servo end points on a 4PKS? I didn't do it, and as I was screwing around trying to figure out the esc issue, I broke/cracked one of the 4 plastic mounts on the servo...to much torque in that Hitec 7990TH...with someone like me playing with it...ouch. Thank you! |
01-05-2013, 05:50 PM | #2 |
| Re: FXR Calibration and setting radio end point for steering servo
OK, you programmed the radio....to what?? We would assume it's to a dual ESC set-up? Are you sure the 2nd ESC is to go into channel-3? I believe some Futaba radios need the 2nd ESC into channel-4. I believe the Futaba 4PL is one. Double check the programming and channel call-outs. |
01-05-2013, 06:59 PM | #3 |
I had the programming wrong on the radio...Harley hooked me up...thanks!
FXR Calibration and setting radio end point for steering servo - Similar Threads | ||||
FXR Calibration | KnoJa | Electronics | 9 | 12-26-2012 09:06 AM |
Setting steering travel on radio above 100%... good/bad? | nutsoap | Electronics | 9 | 08-24-2012 01:47 PM |
FXR calibration problems | YJJPWrangler | Electronics | 2 | 04-19-2011 10:09 PM |
Servo EPA end point adjuster / controller / limiter | wantAsummit | Electronics | 15 | 08-10-2010 03:13 PM |
Radio/ESC settings - End Point adjustments | Marcusg | Electronics | 2 | 08-17-2006 11:07 PM |
