03-31-2013, 05:59 PM | #1 |
Pebble Pounder Join Date: Jan 2008 Location: New Bedford MA. USA
| Dual motor question
I had to reverse the wiring on the rear motor on my clod to get both axles spinning in the same direction but the rear wheels are much slower how do i fix this.
03-31-2013, 06:44 PM | #2 |
| Re: Dual motor question
Best guess (assuming both motors are on a single ESC and the motors are "identical") is that the rear motor is timed...but now in the wrong way since it's rotation is reversed.
03-31-2013, 07:13 PM | #3 |
Do i have to turn the endbell 180 degrees or just slightly ?
03-31-2013, 08:51 PM | #4 |
Quarry Creeper Join Date: Dec 2012 Location: Spokane Valley
I'd set them both to 0 then take your rear motor and set it at 180. Then plug it in without the rear motor wires being backwards.
04-01-2013, 02:34 PM | #5 |
I sorted it out. I found out you have to turn the endbell in the opposite direction from the rotating direction. Another question without making another thread , Is there anyway to control clodstall ? I think i like it when crawling. helps me get over ledges better but i'd like to be able to dial it in better. There are times when i feel like a little more wheelspin up front without having the rear wheels turning would help me. |
04-01-2013, 03:29 PM | #6 | |
| Re: Dual motor question Quote:
Others run a different pinion front vs. rear... Best is to run dual ESC's & a radio that does dual ESC mixing. I've done all, dual ESC's + mixing is the best. All can work to some degree. | |
Dual motor question - Similar Threads | ||||
Dual Motor Question | klampykixx | Electronics | 15 | 02-11-2013 02:48 PM |
Dual motor question | Katon | Electronics | 7 | 12-25-2009 07:56 AM |
Dual motor question | LeDevil | HPI Wheely King | 5 | 11-03-2009 12:08 PM |
dual motor question | U4EAH | Newbie General | 3 | 02-23-2008 10:00 AM |
dual motor question | triaxmaster | Electronics | 9 | 03-13-2005 08:18 PM |
