Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: HELP want to run 3s but no BEC HELP
Old 09-20-2014, 09:41 PM   #1
Default HELP want to run 3s but no BEC HELP
one little question maybe somebody could help me I got an scx10 with stock AE2 n 20t wraith motor with 87/14 on 2s n I love it enough of torque n wheel speed for me but im trying to see on maybe running a 3s but don't want to run a BEC I got two other esc that i can choose from a mamba pro n a sidewinder SV3 n want to run a different motor on 3s will I still need a BEC with this other systems
mannyb1982 is offline   Reply With Quote
Old 09-20-2014, 11:01 PM   #2
Default Re: HELP want to run 3s but no BEC HELP
For sure if you want max power out of servo! If it is a high torque check voltage ratings usually 7.4v is needed...stick csn even be a lil stronger with BEC! I run one on every rig I got no matter what
sic1to is offline   Reply With Quote
Old 09-21-2014, 06:43 AM   #3
I second that!
mudbeast2 is offline   Reply With Quote
Old 09-21-2014, 09:52 AM   #4
3rd that.
Bec in every one of my rigs also.
stelerzman is offline   Reply With Quote
Old 09-21-2014, 12:00 PM   #5
Jus
On an esc rated for 3s you could likely get by without, depending on the servo you use. Or you might end up with brownouts while driving which isn't good. Only esc I consistently run on 3s without a BEC is the Holmes brxl. That's on light 1.9 rigs.
Jus is offline   Reply With Quote
Old 09-21-2014, 12:22 PM   #6
Just get a bec and get it over with...
Meatwad is offline   Reply With Quote
Old 09-21-2014, 01:49 PM   #7
+1
A CC BEC is reasonably inexpensive.
Sent from my modded TI-83 plus.
2-shot is offline   Reply With Quote
Old 09-22-2014, 12:23 AM   #8
CC BEC is great if you need some other voltage than 5.0V or 6.0V.
For me 6.0V is okay, so I use Turnigy BECs that cost a fraction of the CC BEC and works just fine.
It takes a really high power servo to draw more than 5A while stuck and fighting to move.
During normal operation there's something wrong if the average consumption is more than 1A.
Olle P is offline   Reply With Quote
HELP want to run 3s but no BEC HELP - Similar Threads
Do I need to run a BEC? arbitris Electronics 9 12-10-2013 10:03 AM
What bec voltage do you run? JohnRobHolmes Electronics 42 12-09-2013 01:07 AM
XR-10 Run Times and BEC? sanman357 Newbie General 3 09-14-2010 04:18 PM
do i need a bec to run this servo? Gear.Head Newbie General 7 04-29-2010 10:48 PM
should i run a bec? ultimate_monkey Newbie General 11 04-18-2010 11:55 AM
