07-03-2015, 07:52 PM | #1 |
Newbie Join Date: Jul 2015 Location: Rhode Island
| Axial AE-5 problems
Hello All, I am new to crawlers and finished building a Wraith kit. I was doing some test runs with the electronics before I start buttoning things up but I ran into a problem. When I hit the throttle on the Wraith after 15-20 seconds the brakes kick on. I know the AE-5 has a drag brake but I am still on the throttle when this happens. It hits so hard that it endo's if I am on pavement. This happens at high and low speeds and will even happen if I pick it up off the ground. It's like the throttle cuts out and the brakes kick in after a few seconds. I did some testing of the ground I applied some light throttle and flipped the wheels back and forth. When the throttle cut out I did not lose steering. It doesn't look like the AE-5 has much in the way of programming options. Does anyone have any ideas what could cause this? Any help is greatly appreciated. I am running the AE-5 with an HPI Firebolt 15t, 20t pinion and a 10a castle BEC. |
07-03-2015, 11:12 PM | #2 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
| Re: Axial AE-5 problems
What kind of batteries are you running? Sounds like it could be the lipo cut off kicking in.
07-03-2015, 11:31 PM | #3 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
If you dig on the forum a bit there are a few pages that talk about that exact problem. If I find the link I'll post it. I had the same problem I'm trying to remember what fixed it. If my memory serves me I had a metal shaving in the space where the lipo nihm 50 100 pins are, my servo failed the same time.
07-03-2015, 11:48 PM | #4 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
I'm prepared to be corrected but, a 15t brushed with a 20 pinion is so over geared I'll be surprised if the motor last more than 1 battery pack. I wouldn't be surprised to find your overloading the esc & its resetting/momentarily shutting off. |
07-04-2015, 12:11 AM | #5 |
That could be it. I think the ae5 has a 20t limit also.
07-04-2015, 12:57 AM | #6 |
Quarry Creeper Join Date: May 2015 Location: RRW
12T on 2S, 18T on 3S.http://docs.axialracing.com/instruct...Drag_Brake.pdf |
07-04-2015, 05:56 AM | #7 | |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| Axial AE-5 problems Quote:
I agree. 4:1 is tall for a Wraith, esp. with a 15t. Try disconnecting the motor from the tranny and see if it runs longer than 15-20 seconds. If it does, then try reinstalling but geared down to 5:1 and see if that works. If it doesn't work when the motor is disconnected, I'd guess faulty ESC or radio/receiver as next most likely culprit. | |
07-04-2015, 08:54 AM | #8 |
Thanks for all the replies. I am running a Zippy 2s battery. When I disengaged the motor I was getting the same instant stoppage. The motor was completely cool so it wasn't overheating yet. |
07-04-2015, 09:04 AM | #9 |
I pulled the motor and electronics. I pulled out the pins for the lips and drag brake setting, I didn't see anything in there. I reinstalled the electronics and recalibrated the esc per the instructions and now it is running correctly. I will drop a few teeth on the pinion just to be safe. I have another question, this one about the Holmes hobbies motors. I read through several of Harley's threads and he suggested the crawlmaster or tourquemaster if you want to run in water or mud, which I do. While I was browsing the site I saw the trail master motors, since I plan on trailing I was looking at it and noticed it said not to use it in water or mud and to get a cheap throwaway motor for water and mud. While I was talking to someone on another site they suggested the disposable motor route also. Am I really better off avoiding Holmes hobbies motors if I want to run in water or mud? I live in the northeast so we don't get the cool mud other parts of the country gets, it's most just wet topsoil pretending to be mud... |
07-04-2015, 10:46 AM | #10 |
Clean fresh creek water doesn't bother a brushed motor much, get which ever your happy with. Mud & sand chew threw the brushes & comm and will need to be flushed out. The motor will have a very limited life, this is where the cheap disposables come in. Personally I love me some Holmes crawlmasters but I stay the hell away from mud & water, not my thing, can't be bothered with the mess & junked parts. |
07-05-2015, 08:24 PM | #11 |
Pebble Pounder Join Date: Feb 2015 Location: Mount Morris
i dont have any experience with them but i have heard that sensord brushless motors are completely sealed and are a good option for mud, sand, and water. maybe someone that has one could chime in and tell us?
07-05-2015, 09:19 PM | #12 |
| Re: Axial AE-5 problems not all sensored brushless motors are sealed completely....but can be waterproofed to be reliable in water and mud along with waterproofing the ESC
07-05-2015, 10:26 PM | #13 |
I run a sensored brushless Dynamite fuze combo on My blizzard and I use conformal coatings on the motor sensor bord and I haven't had any problems. The blizzard gets lots of snow in it and I drive it on trail runs in mud and water with no issues. I also have gotten my Holmes hobbies motors muddy without any issues thus far. But you should know I clean and oil /grease my rc stuff if they get wet asap.
Axial AE-5 problems - Similar Threads | ||||
Axial esc problems | Bermbuster210 | Electronics | 12 | 01-01-2013 02:10 PM |
Problems problems problems hope it's worth it in the end | TJcreeperJEEP | Venom Creeper | 9 | 12-22-2009 04:54 PM |
Axial Scx10 problems... | Veilside159 | Axial SCX-10 | 30 | 12-09-2009 02:12 PM |
Axial beadlock Problems... | biggin69 | Axial AX-10 Scorpion | 3 | 07-26-2008 06:57 PM |
Axial SHOCK problems | quads4_life | Axial AX-10 Scorpion | 34 | 09-12-2007 10:40 PM |
