11-03-2015, 01:34 PM | #1 |
Newbie Join Date: Sep 2015 Location: Ogden
| First time Rc builder
I have a buddy who introduced me to Rc cars, talked me into a wraith. So I pulled the trigger on the kit and started building I found advice on how and what paints to spray my body with. Decided three tone would look sweet. Green, purple, black. Finished product. Then learned I needed to trim off those awesome fender flares I so painfully masked off that it now fit my chassis. Next I decided I have to pretty of a pint job to actually drive with it. So I set about building some aluminum skins made some templates out of those fancy Christmas boxes the wife has hoarded for years. Shush. Don't tell her that some are missing Did some crawling with out a body and man does it get addicting fast. Now to buy more parts, weights, tires so forth. Oh an to finish my aluminum sides I never made a hood because that just seemed to be a pain in the butt After I got my panels done. I decided to wrap them in some carbon fiber wrap I had in the garage and a little more poser pictures because those are just required. Right? I decided the body looked cool but was a waste if I didn't run it. To run it with the battery moved up to the front I wasn't about to pull tools to remove then body so I made a hood fashioned after those others have made Pardon the wire mess it's been since cleaned up a lot I also switched from a 2c lipo to a smaller 3c lipo Freeing up some room and space. Then it was out for a little Sunday photo shoot. With a slight amount of tire rub on the front head light buckets. I think I will have to mount a light bar instead of using the factory head lights I promptly found that you have to have the tire on the correct way. You know the pin in the nut so that the axle doesn't just spin inside the tire? Keeping the early morning rolling, the afternoon hours snoring, the late night hours feeling the powers. Last edited by THX_138; 11-03-2015 at 11:55 PM. Reason: image size limits 800x600 |
11-03-2015, 04:01 PM | #2 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| Re: First time Rc builder
Well done, sir. Looks like you are well on your way to getting hooked. Keep up the good work! Sent from my iPhone using Tapatalk |
11-03-2015, 07:57 PM | #3 |
Rock Stacker Join Date: Oct 2015 Location: NKY
So let me get this straight. This is your first RC and your first RC build? You are talented buddy, that thing looks good!
11-03-2015, 09:58 PM | #4 |
I still haven't invested in a personal solder station. I have bummed all that from my buddy. I guess payback for him getting me addicted to this stuff Mi also picked up my boy a traxxas rustler. It's a bit older but runs great for a 8 year old. I'll post some of it after I get it cleaned up Thanks for the positive feed back guys. I haven't got much else from this site I have also built my own stainless upper links. The steering links I bent and built also. I'll take photos tomorrow Last edited by THX_138; 11-03-2015 at 11:30 PM. |
11-04-2015, 06:15 AM | #5 |
Testing a photo for size requirements |
11-04-2015, 11:31 AM | #6 |
So reading on line I found what seemed to be a easy fix for me. Was the linked suspension. Looking and reading lead me to buy a brake line bending tool at autozone, used it ask hated it. The bends where large, unpredictable (to me anyway) and hard to reproduce. I tried my hand with my first steering link ( photo above). It looked like trash. It was to short and caused one wheel to toe in. I scrapped it I built all the upper links and rebuilt the front stealing link. My bottom links came in the kit aluminum and I will replace those if I break them the fronts I tried to mimic the factory bends. They turned out ok. With a simple vise, a bench grinder and a bit of guesstimation I think I did ok the rear links have one bend in them also. Pretty straight forward I threaded my SS on one end out on a traxxas end link then I used a screw driver to hold them square with the world. Then I kept adding pressure in the vise until it was at the same end. Marked my length needed to be cut to. Threaded the end and then repeat The new stealing link was a little more complicated I scrapped one or two trying. But in the end it turned out ok. When I pull these off to make links for my friends wraith I will take some process photos Last edited by Cavedave_185; 11-04-2015 at 11:33 AM. |
11-04-2015, 01:29 PM | #7 |
Rock Stacker Join Date: Aug 2008 Location: Kiowa
AWESOME first build! Welcome to the addicting world of R/C! |
11-04-2015, 01:57 PM | #8 |
| Re: First time Rc builder |
11-04-2015, 05:44 PM | #9 |
Newbie Join Date: Nov 2013 Location: Clearfield, UT
Sorry for getting you addicted Dave! But it was my intention! It's so nice having a buddy that is almost as addicted as I am. |
11-11-2015, 08:47 PM | #10 |
Today I got my 1/4 lead tube I guess I would call it from Amazon. Only five bucks for a 1 lb coil of it. I took my front wheels apart and wrapped the lead weight around the inner wheel What do you think Of course I wrapped it with electrical tape to hold it from moving to much then put it all back together As far as my math is correct based off them actually sending me one pound. I figure I am just shy of six ounces on the front tires. I played on my Rock on the front yard, it does reasonable I guess. But I think the main issue is these tires and possible the foam inside. Maybe trim some sections of the foam? I thought about doing some tire sipping ? What about trimming some of the lugs off of the tires? Sent from my iPhone using Tapatalk |
11-11-2015, 09:33 PM | #11 |
Newbie Join Date: Oct 2015 Location: Gwinnett
The lead in the front tires helps a lot, but you're putting a lot more stress on drivetrain parts to spin the extra weight and loosing power also. I would try to find you some brass knuckle weights. I believe Rc bros will be about your best bet. But awesome build for you first. I would have never guessed if you wouldn't have said it was your first.
11-11-2015, 10:11 PM | #12 |
I want to do the upgraded axle parts like knuckles and the c hubs then the weights. I have the upgraded inner axles. Still have stock drive shafts to give out too Sent from my iPhone using Tapatalk |
11-14-2015, 05:04 PM | #13 |
I participated in my first crawl event today out at Wendover Nevada. I think I did ok except my motor smells like death, I had a screw come loose on my rear drive shaft and my pretty paint job is pretty much toast now. I took one poser photo and DNF the course Sent from my iPhone using Tapatalk |
11-14-2015, 09:09 PM | #14 |
Great looking first build but that is way too much weight on the wheels. I try to Krupp 2.2s under 100 grams total wheel weight not counting tire and foam.
11-14-2015, 10:38 PM | #15 | |
| First time Rc builder Quote:
I think I have maybe .75 lbs total. It did really well today actually That's between both front tires too. Not in each. I need to get a scale. The spool I got only weighed one pound. I put an estimated equal amount in each tire. With some some left over Sent from my iPhone using Tapatalk Last edited by Cavedave_185; 11-14-2015 at 10:43 PM. | |
11-20-2015, 10:22 PM | #16 |
After driving in Wendover last week I wanted to go back a crawl my own path. I stripped out two servos in fifteen min!!!!!! I took a spill of five feet and stripped out the first. The spare I had was brand new!! I walked down the dirt road back to the rocks and before I could even get there I had no steering again! Solar d772? Sent from my iPhone using Tapatalk |
11-21-2015, 07:39 PM | #17 |
Pebble Pounder Join Date: Dec 2013 Location: Marion
Stinks. Keep it up though.
12-09-2015, 05:47 AM | #18 |
I took apart my servo this year combo is the problem. The brass gear was free spinning in the stainless gear. I imagine it was supposed to be a press in fit. Well it's not. So I took a long taper shop punch and moved some material so to speak. And now it's solid. I'll put these back in and give it a run through Raising boys into RealMen!! |
02-24-2016, 01:19 PM | #19 |
Installed new drive lines last night and noticed my frame is damaged. Suggestions? Fixes? Raising boys into RealMen!! |
02-24-2016, 04:38 PM | #20 | |||
| Re: First time Rc builder Quote:
X2 Quote:
New frame peices and run either the stock battery tray in back with all the screws or make some kinda of plate/braces back there to reinforce similar to stock. Running without it results in the kind of breakage you have from hard falls and tumbles. | |||
First time Rc builder - Similar Threads | ||||
First time builder and frustrated | JKWrangler | Electronics | 4 | 11-24-2017 04:08 PM |
having issues building shocks (1st time kit builder) | IPT | Axial Wraith | 20 | 05-13-2014 11:44 AM |
First time crawler builder and want to do it right | coryjones | Tamiya Clod Buster | 0 | 10-04-2010 10:56 PM |
FJ "Bushwacker" Long time builder, first time poster | adrenalinerc | 2.2 Scale Rigs | 3 | 07-20-2009 06:31 PM |
First time builder need some assistance | whitey07 | Newbie General | 1 | 01-03-2008 10:33 AM |
