Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Suspension / Shocks question
Old 06-08-2017, 10:44 AM   #1
Default Suspension / Shocks question
I'm in the process of mounting a steel tubular Wraith body on on a Scorpion chassis.
There is currently over 2" clearance between the top of the tire and the body and I'd like to reduce that to about 1.25". Also, the existing springs are too stiff and are fully extended with the body in place. My first thought was to replace the existing, 120mm shocks with 100mm, but now I'm thinking I might lower the body by change the springs to introduce 3/4" of droop. I don't even know where to begin figuring out if I need 2 springs on each shock and what sizes to get. Anybody got any suggestions or web sites that can help me out?
Attaboy
attaboy is offline   Reply With Quote
Old 06-08-2017, 11:24 AM   #2
Natedog's Avatar
Default Re: Suspension / Shocks question
Drop the cage down lower on the frame, get some shorter shocks say around 100-90mm eye to eye is probably good range but you'll have to mock it up after lowering the cage and see what looks right. Shocks should sit about mid-travel or slightly lower at ride height imo.
Suspension / Shocks question - Similar Threads
Suspension flex/shocks jeeptec Axial SCX10 II 24 11-25-2016 05:31 PM
Shocks and Suspension Crawlster Newbie General 1 03-26-2010 08:52 AM
Is there a shocks/suspension thread?? Tmods Newbie General 5 01-22-2010 07:01 AM
suspension problem shocks desertfox62 Axial AX-10 Scorpion 7 01-16-2009 02:52 PM
