04-01-2018, 05:00 PM | #1 |
Newbie Join Date: Mar 2018 Location: AU
| Newbie Battery Question
Hi guys i am new to the crawling side of the hobby, i coming from the on road racing side and was looking for your guys recommendations. I have ordered a scx10 ii kit and along with a hobbywing quicrun 1080 esc and a 35t brushed motor. I was wondering what most of you would run for a lipo either 2 or 3 cell. Cheers Luke |
04-01-2018, 05:59 PM | #2 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Re: Newbie Battery Question
Once you go 3S you never go back XD Sent from my Nexus 5 using Tapatalk |
04-01-2018, 06:12 PM | #3 |
I'll agree with the above statement wholeheartedly... The "trial" 2S I bought for my Ascender is just sitting there, waiting for me to pick up a cheap onroad kit or something... You can always gear down a tad if it's too fast, but you risk issues with your entire electronics system if you gear up because it's too slow on 2S. As they say - Volt up, gear down! |
04-01-2018, 07:10 PM | #4 |
Thanks for the replys guys, 3s it is
04-02-2018, 01:44 PM | #5 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
I always run a 3s with 35t motors, been doing it for years now. I use the smaller 3s packs to keep the weight down. I was running Venom #1577 packs, but have been running these #25077 packs since thats what my LHS has been carrying. These are 30c which is plenty and have a couple different connectors in the package. (XT60 , EC3 & Deans) |
04-02-2018, 08:30 PM | #6 |
That is the same battery I use as well. I get about an hour to hour and a half of trail running per pack in my stockish Honcho. Stock electronics... Btw xt 60 connectors the hw 1080 come with are great. |
04-04-2018, 05:48 AM | #7 |
| Re: Newbie Battery Question I agree, I am running a WP 1080 in my OG SCX10 , I'm starting to like the XT60's a lot.
04-04-2018, 06:55 AM | #8 |
Pebble Pounder Join Date: Feb 2016 Location: Manchester, NH
| Re: Newbie Battery Question |
04-04-2018, 07:03 AM | #9 |
Rock Stacker Join Date: Mar 2018 Location: Northern Ohio
I am running a dynamite 2s 5000 HVlipo shorty in my ascender. I have zero complaints. I can literally run 3-4 hours on it. I don't feel that a single speed crawler needs anything more. A 2-speed might like more. Crawling on the course is more of a strategy and picking the best line for the capabilities of your truck. I leave the brushless crazy 6-8s stuff alone. I was originally gonna buy two batteries with my rig, but the LHS put me in a better charger instead. If you have other rigs and would have to buy new packs I can see where that would kinda suck. Also bear in mind that a stock Ascender is intended to carry a shorty so I was kinda limited as to what I bought.
04-04-2018, 08:44 AM | #10 | |
| Re: Newbie Battery Question Quote:
Volt up Gear Down | |
04-04-2018, 09:19 AM | #11 | |
I was going to get a second battery, but I am going to see what kind of mileage I get out of this one. | |
04-04-2018, 10:18 AM | #12 | |
| Re: Newbie Battery Question I still run 2S for the most part after all of these years. Quote:
I prefer a higher C rating. Always have and always will. But a comparable battery on HobbyKing is $14. https://hobbyking.com/en_us/zippy-fl...-3s1p-30c.html And yes, XT60 connectors are great. | |
04-04-2018, 05:45 PM | #13 |
30c is more than fine for a crawler with a brushed motor. I used to run Turnigy packs all the time, but had a couple puff, then I started using the Venom #1577 packs, they are like $19. Haven't had any trouble with any Venom pack yet. ( I run some of their hard case 2s packs too). Oh....and venom basically will just replace any pack you ever have a problem with, probably hands down the best lipo warranty out there. Heck....$28 ain't to bad for instant gratification....lol Besides.....the 1s packs I use for oval racing cost $70 Last edited by HDMM; 04-04-2018 at 05:51 PM. |
04-05-2018, 06:34 AM | #14 | |
As far as puffing, that happens with all brands depending on age and care of the battery. I've never had a Turnigy battery, or any other battery for that matter, puff prematurely. | |
04-05-2018, 06:48 AM | #15 | |
Another thing I've noticed, because they will check pack voltages a lot racing, is that my Hitec charger tends to over charge the packs a bit, I've tried to set the terminal voltage cutoff, but to no avail on the Hitec. I finally broke down and bought a iCharger 406 Duo because we charge at 20 - 30 amps for oval. That thing is so precise, set TVC and it's good. I'm sure over charging the cells time after time can't be a good thing. | |
04-05-2018, 06:58 AM | #16 | |
Hitec didn't even respond to you? | |
04-05-2018, 07:00 AM | #17 |
Nope and thats the second Hitec charger I've had do that.
04-05-2018, 07:50 AM | #18 |
04-05-2018, 08:02 AM | #19 |
Doesn't hurt I guess, atleast you will know what kind of voltage your packs are coming off at.
04-07-2018, 02:44 AM | #20 |
Ive ended up ordering two 2200mah 3s 30c turnigy batteries as they were cheap at $17 and have the right dimensions to fit well. Thanks for all the advice, i have a hobbywing 1080 esc and a 35t brushed motor to go into the kit will the kit gearing be close for this combo. cheers Luke |
Newbie Battery Question - Similar Threads | ||||
newbie battery question | exokiler | Axial Yeti XL | 4 | 01-15-2015 06:09 PM |
newbie battery question | aprobert1981 | Newbie General | 7 | 03-16-2010 12:30 AM |
Newbie Battery Question Again | xanti | Electronics | 6 | 04-03-2009 09:08 AM |
newbie battery question | evaderman | Newbie General | 4 | 06-19-2008 11:31 AM |
Newbie Battery charger question | Sean | Electronics | 0 | 10-18-2005 09:21 AM |
