08-14-2019, 09:56 PM | #1 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| Question about torque twist???
Does the motor affect torque twist(the way it's facing)? The right front tire is the one to left up on torque twist, correct? Again, thanks to y'all for the help/understanding ! |
08-14-2019, 10:10 PM | #2 |
| Re: Question about torque twist???
the motor will have some affect but mostly its the direction of the motor that decides what side of the wheel lifts also link geomitry can have some afect on tire lift aswell so say for exsample ar60 axles you can flip the ring gear and reverse the motor and the opisite side will lift or not lift depending on suspention geomitry
08-15-2019, 12:01 AM | #3 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Torque twist is a function of drive shaft rotation & torque reaction due to gear reduction in the axle. Motor location can minimise some of it's effect by placing mass on the chassis over the tire thats trying to lift, Likewise with an axle with offset pumpkin, moving the pumpkin to the side trying to lift can use its mass to try counter the twist other wise the rotational direction or way the motor is facing has zero effect on torque twist. Which side lifts is determined solely by which side of the rear diff the ring gear is on & hence which way the rear drive shaft turns, ring gear on left, left front lifts |
08-15-2019, 11:40 AM | #4 | |
| Re: Question about torque twist??? Quote:
08-16-2019, 08:21 AM | #5 |
| Re: Question about torque twist??? wow thats some awsome detail on that model lol
Question about torque twist??? - Similar Threads | ||||
ECX Temper Torque Twist Mod - Reduce torque twist | driftomaniacs | Scale Videos! | 0 | 05-14-2016 04:39 PM |
torque twist question | mark32 | Axial SCX-10 | 13 | 04-11-2013 04:03 PM |
Another torque twist question | bro_die | Axial SCX-10 | 10 | 05-20-2011 10:32 AM |
Torque Twist question | pbarsamian | Newbie General | 4 | 02-22-2010 09:46 PM |
Torque twist question | sim | General Crawlers | 7 | 09-17-2005 08:16 AM |
