12-29-2021, 07:58 AM | #1 |
Newbie Join Date: Oct 2021 Location: San Francisco
| Diff Output & Transmission Angles
Still scratching my head on my first ground up build. I feel like every little step forward only brings about a lot of questions. I'm using a 2.low on a v3 GSpeed with TRX4 portals. At rest (full droop?), how much should I worry about making the trans output and the diff output parallel. The 2.low outputs are quite high compared to the stock TRX4 single speed transmission outputs. Sent from my SM-G973U1 using Tapatalk |
12-29-2021, 10:39 AM | #2 |
Pebble Pounder Join Date: Sep 2021 Location: Canada
| Re: Diff Output & Transmission Angles
They dont need to be at the same elevation, just same angle compared to level
12-29-2021, 10:49 AM | #3 |
| Re: Diff Output & Transmission Angles |
Diff Output & Transmission Angles - Similar Threads | ||||
Front diff output shaft rubbers? | motopreserve | Axial Yeti | 2 | 12-08-2014 01:51 PM |
transmission output question | JDIRCC | Axial SCX-10 | 8 | 07-13-2014 01:15 PM |
Transmission output sheared | lifttec999 | Axial AX-10 Scorpion | 2 | 08-05-2008 09:18 PM |
Rear Transmission output | glondark | Axial AX-10 Scorpion | 1 | 03-23-2008 04:52 PM |
Where To Get The Transmission Output Yolks? | patatron | HPI Wheely King | 1 | 05-04-2007 01:23 PM |
