02-06-2012, 04:22 PM | #1 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| 1st step into quadheli's and F.P.V.
ill share my experience with you guys as i travel into the world of fpv and quadheli's/multicopters. ive always been a huge fan of fpv flying.. at the last fun fly we had locally,my friend matt took me for a ride in his cub airplane, fpv w headtracking..so cool. and well..i was hooked! soooo.. ordered a couple of quadheli frame kits (vc-450 and x525v3) and my fpv equipment. cant wait to get airborne and do some fpv flying! hope to do filming of our crawler comps and gtg's and some filming of my beautiful home state of arkansas. ill even take someone for a ride in fpv.. parts should be in next week or so....cant wait!! .. |
02-06-2012, 05:15 PM | #2 |
Rock Crawler Join Date: May 2005 Location: Fort Wayne
| Re: 1st step into quadheli's and F.P.V.
Sounds like fun! Pardon my ignorance but what is FPV? Can't wait to see what you come up with!
02-06-2012, 05:28 PM | #3 |
FPV = First Person View; flying a heli/plane via remote video feed. Did you order the quadcopter frames from hobbyking? I was looking at those. But I'm pretty clueless on where to go from there. |
02-06-2012, 05:36 PM | #4 | ||
| Re: 1st step into quadheli's and F.P.V. Quote:
and the vc-450 from Frame Kits all my parts are coming from hobbyking.com and bevrc.com here's a few videos that inspired me to take the plunge. same heli same fpv setup.. bmx track..FPV - BMX track - YouTube coastal flight..FPV - coastal flight - YouTube beach..FPV - beach - YouTube ground station fpv setup...http://www.youtube.com/watch?v=_fQyx...wF4bp_zjN6AWHp im "landshark501" a few forums.. OpenPilot Forums Multi Rotor Helis - RC Groups Multi Rotor Helicopters - HeliFreak Last edited by ROLANDROCKSHOP; 02-06-2012 at 05:43 PM. | ||
02-08-2012, 07:18 AM | #5 |
heres my parts list for my FPV ground station.. dell laptop backpack .. eagle eyes diversity station eagle eyes lcd power panel display.. jetview sd dvr WDR700 High Resolution OSD Color Camera 550 Lines NTSC 1.3G 800mW video tx 2- 1.3G RX for FPV Low pass Filter LPF1200/LPF1400 1.2/1.3GHz Patch antenna ..white box.. fat shark fpv goggles ordered!! .. power cable: 1 input 2 outputs 3s lipo 3000mah for power .... Last edited by ROLANDROCKSHOP; 02-21-2012 at 11:43 AM. |
02-08-2012, 07:19 AM | #6 |
parts list for the x525v3 build X525 V3 folding frame - KK multiCoptor Controller with USB programmer - XXD 2218 1000KV motors - 3.17mm Shaft adaptor - GWS 3-blade Propeller - Hobbywing 20A ESC's 3s lipo 2650-2800mah step by step build pics.. x 525 v3 quadheli build pictures by jah6580 - Photobucket ....i did have the top/bottom plates on reversed of what they should be the 525 plate is the bottom plate... ..... Last edited by ROLANDROCKSHOP; 02-14-2012 at 11:18 AM. |
02-08-2012, 07:20 AM | #7 |
parts list for the vc-450 build.. vc-450 blue frame 8in and 10in props green color hobbyking ss 20a esc's 1200kv motors trying to find a openpilot coptercontrol board 3s lipo 2650-2800mah 30c .... Last edited by ROLANDROCKSHOP; 02-10-2012 at 09:10 AM. |
02-10-2012, 09:10 AM | #8 |
let the games begin!!
02-10-2012, 11:15 AM | #9 | ||||||||||||||||||||
finished!!
motor mounts are off..may order another set of motors.. now to wait on the rest to get here.. Last edited by ROLANDROCKSHOP; 02-24-2012 at 06:31 AM. | ||||||||||||||||||||
02-10-2012, 12:33 PM | #10 |
Pebble Pounder Join Date: Sep 2011 Location: edgewater
i really like this and could use it for some things i shoot . what is the total cost to get started or atleast a close ball park please
02-10-2012, 01:03 PM | #11 |
VERY interested! thank you for posting the step by step build! are those spacers steel or aluminum? looking forward to learning more about the main control board too. |
02-10-2012, 02:49 PM | #12 | ||
4-motors,4 esc's,control board,airframe..@$300-500 you will need at least a 6ch radio @$200 good fpv equip @$400-700 Quote:
the best control board out now is the Openpilot copter control ..cc board. @$80-100 which NO one has instock. from what ive been reading its the chizzznit over all others. all the other boards you have to flash this and flash that.. make special connectors so that your only touching certain pins on the board when flashing it. man im excited to get it airborne and punch out to 400ft in 5sec!! what a ride!! | ||
02-10-2012, 06:58 PM | #13 |
im starting to save my pennies as of now i so want this i do alot with racecars and stuntbikes this would be epic to use and ive been wanting a heli so this is perfect. on the fpv can you give some more info on it as well also what kind of camera are you using go pro? |
02-12-2012, 06:57 AM | #14 | |
900w/1.3ghz/2.4ghz/5.8ghz my friends explained it to me like this.. the 900w gets you longer range but a chance of interference with cell phones and what not.. 2.4ghz you have to be careful of others using rc radio's/other fpv equipment.. 5.8ghz gives you shorter range with less chance of interference as to why im sticking with the 1.3ghz..its less used freq and im not going over 1-3 miles anyway. some of the high powered 500w systems can and have went 30-50 miles away from them flying delta wing airplanes. post#5 list of fpv equipment.. backpack eagle eyes diversity station sd dvr WDR700 High Resolution OSD Color Camera 550 Lines NTSC(fpv camera) 1.3G 800mW 1.3G RX for FPV Low pass Filter LPF1200/LPF1400 power cable: 1 input 2 outputs 1.2/1.3GHz Patch antenna 3s lipo 3000mah for power fat shark fpv goggles go pro hero hd camera for filming. ill be doing a step by step setup video when i get all my stuff in and get running right. ill pass it along to you guys to learn from in your fpv experience. heres a guy/videos explaining what it all does...checkout all his videos. Bevrc 1.3G LR FPV System Review - YouTube this guy gives a breif run down on how it works..just to give you the jist of it. Getting Started in FPV - YouTube | |
02-12-2012, 02:58 PM | #15 |
thats awesome im goin to keep my eye on this i want one so bad even thinking about picking up a smaller one just to practice my flying while i save also dont mind me im not that tech savy so i might ask alot of questions |
02-13-2012, 06:38 AM | #16 | |
i bought one to practice with as well while i wait for my parts and equip to show. started in + mode and just swapped to the x mode yesterday.. soooo much fun when you get the hang of it.. almost like flying an rc airplane. no problem man,im a newbie to this as well so ill be learning just ahead of you..and passing along the info to you and whoever else is intrested. | |
02-13-2012, 06:50 AM | #17 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
| Re: 1st step into quadheli's and F.P.V. |
02-13-2012, 07:01 AM | #18 | |
its one tuff lil sob aint it? of course it doesnt weigh anything hardly.. my dog was chasing it around yesterday in the backyard at my gf's house..lil fat bastard almost got it a few times.. | |
02-13-2012, 09:11 AM | #19 |
Where can u get it ?
02-13-2012, 12:07 PM | #20 | |
Horizon hobby should have them in stock. I picked mine up at my local hobby shop. | |
1st step into quadheli's and F.P.V. - Similar Threads | ||||
Tire Chains 101!!!! step by step. Picture Heavy!! | foratm | Tools, and Procedures | 18 | 12-05-2012 03:02 PM |
I need a step by step for Turning a 6 Cell stickpack into Saddlepacks. | TedBull | Electronics | 5 | 10-24-2010 09:31 PM |
Making the green go away - step by step de-anodizing an AX10 for beginners. | O.C.D. | Axial AX-10 Scorpion | 54 | 03-07-2010 10:15 PM |
how to use a full size servo for dig! step by step | 2500hdon37s | Team Losi Comp Crawler | 5 | 09-01-2009 05:43 PM |
Easy step by step install of Scorpion tires/wheels. | O.C.D. | Axial AX-10 Scorpion | 22 | 05-09-2008 04:38 PM |
