01-01-2018, 11:52 AM | #181 | |
I wanna be Dave Join Date: Dec 2016 Location: san diego
| Re: My new TT02 Chassis kit Quote:
Let me know how they work and... well send me the link i will probably just get like 3 or 4 myself, those are cheaper than nimh packs! I actually have a 3s lipo that fits the tt01 and tc3, but thats waaaaay too much juice for a couple of brushed drifters lol Nice find on those 2s lipos! I will run them in my sons barrage too! | |
01-01-2018, 08:47 PM | #182 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
Hey Shinchu I only have 2 3s Lipo's and they are 5000Mah so they are pretty thick, they fit in my SCX10 and my Team Associated 4x4 Pro SC Truck, with the SCX10, I'm not used to the speed and the amount of wheel spin, and if it can handle 3s My Pro SC Truck would rip on 3S and be fine, I haven't tried 3s cause I just replaced the fan on the ESC cause on 2s, it ran a little warm but that was because the old fan wasn't spinning constantly and would stop spinning I want to try it on 2s and see if its cooler and then try 3s later and see what the temps are, it might help, if I add some air flow and ventilation to the body also, its another unfinished side project Last edited by kgb424; 01-01-2018 at 09:02 PM. |
01-02-2018, 09:26 AM | #183 |
"roll down" the windows ;) that's what i did on my first AE86 body for my nitro RS4. nice and cool when going sideways. i only plan on going 2s for my drifters. it doesn't take much power for skids. |
01-02-2018, 09:13 PM | #184 |
It only took me maybe a hour to hour and half, to remove both rear leaf springs on my Toyota truck, the hardest part was breaking the bolts loose, once I broke everything loose, the springs came out easy, you can see there flat in the middle and some of the leafs are bent Last edited by kgb424; 01-02-2018 at 09:18 PM. |
01-03-2018, 10:28 AM | #185 |
do you have replacements? or you find a place that will re-bend?
01-03-2018, 02:19 PM | #186 |
Leaf springs FTW! |
01-04-2018, 02:38 PM | #187 |
Here is the real deal I called SD Truck Springs and Michigan Truck Springs the only 2 places, I could find that sells OEM Toyota Leaf Springs, other than the Dealer and there not available and when you call both places and ask where there Springs are manufactured The answer was, I don't know, cause we buy them buy the pallet, and the pallets come XXXXXXX China or Mexico or Canada, then asked if they could get a set from Mexico and was told they pull from what pallet and no guaranty of what country there from XXXX that I'm supposed to pay them close to $400 and they don't know shit I took my original Toyota Springs that is a better quality of steel than new OEM Bullshit they tried to sell me They have been re-arced back to OEM specs and they added a leaf, so now I need longer U-bolts The place that re-arced my Springs are making me 4 1/2 x 2 5/8 x 6 3/4 square bend U-bolts for $10 a U- bolts There $18 a piece at Napa and they have to be ordered, they make them and can ship then to me U can see there no longer flat in the middle and can see they added a leaf Ordered the U-bolts today and the shackle bushing are coming from Rock auto So now just got to wait for my parts Last edited by kgb424; 01-04-2018 at 09:57 PM. |
01-04-2018, 02:44 PM | #188 |
I ordered a $100 worth of TT02 parts, I got to wait until the 9th of January, cause there closed until then to order parts from Eagle Racing, and get the shock towers and upper front turn buckles and a set of aluminum bodied shocks for RWD drift TT02
01-04-2018, 03:19 PM | #189 |
The Spring place called me back and for $12.53 a U-bolt, I went 9/16 x 2 1/2 x 7 1/2 my choices in 9/16'' is 6 1/2 or 7 1/2, I don't think 6 1/2 is long enough and will have to cut the 7 1/2 ones down but will do it so they still thread
01-04-2018, 09:54 PM | #190 |
Jato, myself, and most importantly, your porch frog all approve of this!
01-04-2018, 09:59 PM | #191 |
If you think you could be like Homer Simpson and licking toads again, nope its happening with them 2
01-04-2018, 10:25 PM | #192 |
Ahaha what?! Lick homer simpsons toes?!!? I still need to find a post office and ship out your goodies... |
01-07-2018, 03:57 AM | #193 |
I feel bad, my neighbor let me, us his Ascender and it broke something in the rear axles cause, it now clicks and makes a popping noise when rolled forward, doesn't click in reverse but one wheel keeps spinning after you let off the throttle Thinking the rear diff or locker broke and offered to pay for the parts since, I was using it when it broke, and was told don't worry about it, next time I'm bringing one of my own Crawlers He let me use his Ascender cause I never used one, I like my SCX10 better |
01-08-2018, 08:41 AM | #194 |
yeah sounds like diff output or a axle shaft. i never drove an SCX10... or an ascender for that matter lol mine isn't done yet. spur gear should show up today from RPP though! maiden voyage TONIGHT!!!! |
01-08-2018, 09:29 AM | #195 |
Do you have a link to the battery you found? This is the one I'm using for round stick packs to fit in Tamiyas: https://hobbyking.com/en_us/turnigy-...tick-pack.html There's also this one, but I prefer the one above because I like high C ratings: https://hobbyking.com/en_us/nano-tec...-hardcase.html |
01-08-2018, 11:20 AM | #196 |
Sorry I don't have a link for the 3000 MAH Turnigy Lipo, I need a special sized Lipo for my TA04 S and found the 3000 MAH one I like the TA04 S, its a nice RC but not a big fan of the front belt running thru the battery tray, cause if you use the wrong sized battery, the belt could cut into the battery and cause a big problem Tested the 04 with a small 1300 MAH 2S lipo, that I taped to the tray, it's pretty sweet with the 13 turn brushed motor, just want a decent run time Last edited by kgb424; 01-08-2018 at 11:27 AM. |
01-09-2018, 01:44 AM | #197 |
I got my new shackle bushings and my new longer u-bolts and they will need to be cut down, so I bought 2 4 1/2'' cut off wheels the 1/16th thick ones for my grinder, the new nuts are bigger than the old 19mm ones, Now I need a 1/2 drive 22mm deep impact socket,my local Home Depot has 2 in stock and there less than $6.00, I will go get one tomorrow, if it lasts long enough to tighten and torque 8 u-bolts nuts, I'm good Last edited by kgb424; 01-09-2018 at 01:49 AM. |
01-09-2018, 08:35 AM | #198 |
should be fine, I've had good luck with HD's husky tools. i hope this fixes your vibration issues!!! Jato thanks for the battery links! |
01-09-2018, 06:57 PM | #199 |
The nightmare is almost over Going to mount the springs, then jack the rear end up too the springs and then check the pinion angle before I mount the u-bolts So that way with the u-bolts uncut, I can add a 2 degree shim if needed cause you need longer u-bolts to add shims too correct the pinion angle If I'm lucky, the re-arced springs should correct the pinion angle with out shims and have stopped the soft and sagging leaf springs that was part of the problem Just waiting for a warm day, so don't have to heat the garage Last edited by kgb424; 12-11-2018 at 12:53 AM. |
01-14-2018, 06:08 PM | #200 |
Yeah Baby Re-Arced leaf springs and new 7 1/2 U-bolts and were back in the game !! You just can't keep a good Yoter down !! |
My new TT02 Chassis kit - Similar Threads | ||||
Any other TT02 here | calcagno45 | Non Crawler RC's | 67 | 11-06-2017 11:41 AM |
rally bug bit me...now i have a tt02 | smokinloon | Rally | 4 | 08-08-2015 10:26 AM |
My Tamiya TT02 Type S/BMW Build | OkinawaCrawler | Non Crawler RC's | 0 | 05-03-2015 02:59 AM |
Tamiya M03 M05 M06 TT01 TT02 HPI WR8 1:10 scale M-chassis shoot out at Punggol East H | boolean21 | Scale Videos! | 0 | 08-15-2014 10:14 PM |
