Go Back   RCCrawler Forums > Miscellaneous > Non Crawler RC's
Thread: My new TT02 Chassis kit
Old 11-06-2017, 12:20 PM   #101
Default Re: My new TT02 Chassis kit
i think you're cooking with fire now!!!
Shinchu is offline   Reply With Quote
Old 11-06-2017, 12:42 PM   #102
Yeah Baby
Alrighty then I found a set of aluminum Air Craft Push rods that have 3mm threads and are 34mm long and have a hole in the center and have a 5mm diameter, so I can drill and tap a 3mm hole cause there wide enough and they are aluminum
I ordered a set of them from a hobby store in Florida, there is no picture cause there site wouldn't let me right click to save a pic,
But you get the idea, and its on once again, you just got to be smarter than what your working on that and a lot self medicating
kgb424 is offline   Reply With Quote
Old 11-06-2017, 12:57 PM   #103
glad to see you aren't givng up! i was concerned for a bit there. wish i could show you some of my progress but I'm on hold until i get the new house all moved in and settled.
add all the new awesome vintage ford truck body stuff from proline and traxxas and my mind is spinning trying to decide what exactly I'm going to do.
on top of all that I'm tempted to sell the yeti if i don't build a vintage trophy truck out of it... which is very tempting also.
might even move my dad's tribute truck to the new RGT bowler chassis (already 11 inch wb and they have rear leafs for it) and use the ascender for a 70's chevy pickup "king of hammers" retro style truck.
after the holidays i should have some progress.
anyway... glad to see you motivated again!
Old 11-06-2017, 07:42 PM   #104
Yeah Baby
I tested out a theory, I had and it worked like it was supposed too, that why I drilled the plastic knuckles first in case it didn't work
Took the stock plastic steering knuckles and drilled a new hole closer to the knuckle and center of the arm
And that shorten the length of the tie rod needed, so I shortened the tie-rods by turning the turnbuckles in, when I get the 20mm ones I ordered I will trim them if needed
Cause am I very close, it just needs tweaking after I make the adjustable steering bridge, I will fine tune and adjust everything
But for right now, its close enough, until I figure out how to drill the aluminum knuckles so the holes are dead on, Cause on one of the plastic knuckles, the hole was off and I had file the hole bigger to get the ball centered in the arm
I don't want to do that with aluminum ones I want the holes centered and both knuckles the same
Getting closer to dialing it in
Old 11-08-2017, 09:58 PM   #105
I got the Traxxas tie rods and use some 3mm rod ends with steel pivot balls, I also trimmed off one of the holes on the knuckles, I made some adjustments, its even closer now, still needs adjustment
The turnbuckle for the steering bridge is close, need to check the tracking again
Old 11-08-2017, 11:45 PM   #106
Hey ShinChu
Can you recommend some drift tires and wheels and compounds for asphalt and concrete
With some narrow manufactured drift wheels, I can adjust the camber so the chassis slides easier
Cause the drift wheels I made out of plastic pipe are unbalanced and cause vibrations and are just not true
Manufactured tires and wheels would be balanced and have no vibrations
Old 11-09-2017, 08:40 PM   #107
Yeah baby
I got my aluminum turnbuckles today, and I drilled and tapped a 3mm hole in the existing hole and used steel pivot balls
I will have to power up the servo and center it and see what happens, I know I might need a high speed servo, instead of the standard servo I got now
Its close still needs some tweaking like when it comes back to center
Old 11-10-2017, 07:39 PM   #108
Originally Posted by kgb424 View Post
Hey ShinChu
Hey bud! Lookin good!!!!
Pretty much any hard compound drift tire will be fine, match it up to any 26mm touring wheels and you are all set.
Or just plop down $20 on some pre mounted... anything!
Just try some. They are cheap enough i have literally dozens of wheels and tires. Part of the fun! Go on rcmart or heck even the bay, pull the trigger on the first thing that looks good to you, will be better than pvc or abs.
Setup is really looking killer man! So glad you got i t figured out! Cant wait to see some vids!!! Oh and if going rwd a gyro is a must or you will get frustrated really, really quick cuz it will spin out faster than you can counter.
You are now on the golden road of success brother!!! Congrats!
Old 11-10-2017, 08:05 PM   #109
Well shit happens and it smacked pretty hard and it broke the passenger side steering knuckle, it sheared off right at the lower A arm
I didn't use the drift wheels I made cause they are unbalanced and cause vibrations and the wheels wobble a little
Used a set of touring car tires and it still crashed and burned in less than 10 minutes needs a Gyro to help
Now I have to get the aluminum steering knuckles drilled and the holes have to be dead on and the same for both knuckles so they adjust evenly
The plastics knuckles the holes were not the same and it wouldn't adjust evenly
I looked online and all of the multiple holed knuckles have been discontinued or out of stock
So I have too drill the knuckles, wondering if after today's carnage
If I shouldn't get 2 sets drilled out and have a spare set
Maybe I will ordered another set of aluminum knuckles
Old 11-11-2017, 02:49 AM   #110
I found and bought the version 2 wide angle steering arms, they are shaped just the Eagle Racing arms, also bought this aluminum collar set
Seen online where someone made a bracket that uses the existing holes in the knuckle and moves the tie rod hole closer to the knuckle
With out drilling a hole in the knuckle, I got pic of the mount he made, its not a very good one but you can see how the tie rod is closer to the knuckle
I think the hole is over the side so he could use a nut and ball stud, I will use a thick piece of aluminum plate and tap the hole,
So my bracket will be shaped differently
Oh Shit, I just looked and the wide angle steering arms and the collars are from Eagle Racing in Japan
Still can't find multiple hole knuckles like the Eagle Racing one is the picture
Old 11-11-2017, 09:28 PM   #111
I took pictures of the bracket that the guy made using his U-tube video and I was right he is using a ball stud and nut and the length of the turnbuckles he is using is why his mount plate is curved
Those are the same Yeah Racing aluminum knuckles I have
Old 11-12-2017, 12:42 AM   #112
And so it begins
Its easier for me too make identical plates and then it is too drill the knuckles evenly, I can drill the both plates at the same time together so the identical, I hope
I used a old Sharpe and laid the knuckles on a piece of 1/8'' aluminum plate and scribed the shape of the knuckles
And I rounded the end, so the plates fits tight against the knuckles, need to buy some 3mm flat head screws for the 2 holes in the knuckles
The 1/8'' plate is thick enough, so there are plenty of threads for tie rod to mount to in the plate with a 3mm button head screw
Old 11-12-2017, 06:33 PM   #113
I got my knuckle plates made, I shaped them the same as knuckles, going to hold off on the tie rod holes, I want to try out the Eagle Racing Version 2 wide angle steering arms
And then will drill the holes for the tie rods in both plates
Old 11-12-2017, 08:13 PM   #114
I think that guy made the brackets L shaped to reduce "over throw". Even real drift cars that have angle kits can actually get stuck if too much angle. This is reduced by making knuckle mods so the rod ends dont go past the point of no return.
I wish i could find vids of how angle kits work. I mean i know i could find them but i wish i knew exactly where to point you. Lots of geometry in movement here. Gets tricky.
Look for vids like pbm angle kit or drift steering mods explained...
Arggg man i cant wait to get going on my cars so we can both learn from each other!
Old 11-12-2017, 09:40 PM   #115
Hey Shinchu
If you look at his pics, you can see he is using 2 different sized rod ends, which make the turn buckles longer
And the fact he also used a ball stud and nut, but it could also be the angle thing, I had problems until I shorten the tie rod and moved the hole closer too the knuckle
I bought the Eagle Racing V2 wide angle steering arms, I found online Eagle Racing parts and not sure if the they fit a stock TT02, cause all of the Eagle conversions have Carbon Fiber chassis
And the upper and lower A arms are different between the Chassis kits, and need different spacers too make them work
I found the Eagle Knuckles that have a ball stud on top and bottom and multiple mounting holes for the tie rods
You don't see a normal TT02 with the Eagle knuckles and lower and upper A arms, cause of the different Eagle chassis
With the motor in the front or the other one that has the Gyro in the front and then RWD has different parts
The Yeah Racing Drift Conversion looks like it uses the stock plastic chassis tub and has wide angle arms steering arms with a adjustable steering bridge
The knuckles have 3 holes and one close to the knuckle, same with the Eagle Racing they have a holes close to the knuckles
So I'm on to something with a hole close to the knuckle, so matching plates was the way to go
Old 11-13-2017, 07:28 AM   #116
Eagle conversion called FRD has new lower and maybe upper arms for sure. However, if you can get those, they mount to an aluminum copy of the tt02 front diff housing or bulkhead. So... they should bolt up. Thats how they call it a tt02 kit, based off all measurements and specs of tt02.
I was looking for an eagle frd kit but for the price... jeez might as well just get an mst and be done lol i dont like the sakura because belts and funky motor position.
Anyway yeah you are getting damn close with geometry. Your determination is inspiring!
Oh and i have seen plates for the knuckles that look like your lower shock mounts. Cant rememnber where... might have been part of tt01 angle kit? Not eagle... tenergy? Integy? Dont have time to google... moving is a pita!!!!
Old 11-13-2017, 02:51 PM   #117
Hey ShinChu
I googled Eagle Racing in English and Broadtech.hk came up and I found the V2 wide angle steering arms and the collars I bought, to test the service and shipping time from Japan
Feel free to look thru the Eagle Racing parts there is 12 pages of TT01 and 32 pages of TT02
all versions of the TT02 chassis are there the 4WD versions, the 2 wheel drive versions, motor up front versions
Check it out, I was looking at the RWD and the RWD V2 but not sure
Want to see how much the Yeah Racing is before I bought the Eagle Racing setup
And not the complete chassis conversion just the A arms and knuckles and rear hubs
That seems like the way to go
Until you look at the pictures and see how every thing mounts
Old 11-20-2017, 07:41 PM   #118
I got my Eagle Racing parts and they sent me a 2018 catalog and there is some really nice stuff in it, but its not in English, so you have to go to the Eagle Racing website
It took me awhile to find and were expensive, but I found the original vintage Tamiya Decal sheets for the Alfa Romeo 156 Selenia body that is on my TA02
Old 11-21-2017, 12:20 AM   #119
I got the new steering bridge and the new wide angle arms put together and wow the Eagle Racing setup is so much smoother than Ebay wide angle arms
Still not right when the axles are centered, I now have to make some Ackerman angles to mount the tie rods to the knuckles
Kind of like the other guy made
Old 11-21-2017, 09:52 AM   #120
I used a step screw and temporary fixed the plastic knuckle, and I adjusted the steering bridge and was able to get the wheels straight at the center position
Used the plastic knuckles to see if the hole closer to the knuckle still worked and it works like it should
So now I need to figure out where to drill the knuckle plates, so I can attach the tie rods on the aluminum knuckles
My new TT02 Chassis kit - Similar Threads
Any other TT02 here calcagno45 Non Crawler RC's 67 11-06-2017 11:41 AM
rally bug bit me...now i have a tt02 smokinloon Rally 4 08-08-2015 10:26 AM
My Tamiya TT02 Type S/BMW Build OkinawaCrawler Non Crawler RC's 0 05-03-2015 02:59 AM
Tamiya M03 M05 M06 TT01 TT02 HPI WR8 1:10 scale M-chassis shoot out at Punggol East H boolean21 Scale Videos! 0 08-15-2014 10:14 PM
