Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: My first attempt at trying "marbleized" painting
Old 08-14-2013, 02:53 AM   #1
Default My first attempt at trying "marbleized" painting
Tried to paint my Wraith body in a marbleized scheme.... I'm not 100% satisfied with the results. Has anyone else painted their bodies in this manner that would be willing to share some needed tips?? Next try, will be with scrap Lexan, not my actual body!
aqwik69 is offline   Reply With Quote
Old 08-14-2013, 04:33 PM   #2
Default Re: My first attempt at trying "marbleized" painting
I have heard of being able to use Saran Wrap to achieve a marblized appearance but I have not tried the technique myself.
Crimson Rock Crawler is offline   Reply With Quote
Old 08-14-2013, 06:03 PM   #3
I did use saran wrap...I think where my mistake were, is that it has to be done in reverse order since being painted from the inside out. The rest of my body looks BAD lol...trial and error.
Old 08-15-2013, 02:35 AM   #4
just an old wal mart bag will work, if using rattlecan, spray on a lil heavy, dab, dont lay plastic on then pull off, if the paint starts to dry before you a happy with result just spray a lil more on, if using airbrush paint you can simply pour some in paper plate and kinda dab it on, its such a simple technique. just remember your main color will be the first color you apply. hope this helps
ochevys54 is offline   Reply With Quote
Old 08-15-2013, 02:40 AM   #5
another tip, cut a 2 litre bottle in half lenghtwise for practice or testing colors
Old 08-15-2013, 02:47 AM   #6
heres a shot of my wifes bug. it was the first marble paintjob I did.
Old 08-15-2013, 07:12 AM   #7
Thanks ochevys!
Old 08-15-2013, 07:20 AM   #8
When I have done marbleizing on 1:1 cars I used Walmart bags.
Calderwood is offline   Reply With Quote
Old 08-27-2013, 09:21 AM   #9
I am happy with the final results. Now that I have the technique down, I will try others in different colors. Thanks for the excellent tips
Old 08-27-2013, 11:54 AM   #10
looks good
Old 08-27-2013, 03:04 PM   #11
So is there a write up on how to do this, are you guys just using the plastic crumpled up and dabbing the wet paint, then putting on another coat over top. thanks
Fiftygrit is offline   Reply With Quote
Old 08-27-2013, 03:44 PM   #12
Step 1) painted inside of body with 2 light coats of transparent candy blue pactra spray paint, letting first coat dry for 30min, second coat semi dry for 10min.
Step 2) put my hand inside a Walmart plastic bag, sprayed outside of bag with silver pactra spray paint, dabbed the inside of body multiple times (had to recoat plastic bag a couple few times)
Step 3) after letting silver dry for 30min, I sprayed entire inside with outlaw black pactra spray paint. Finished
Old 08-27-2013, 06:56 PM   #13
Looks like you've mastered the technique !!!! Very well done !!!
Old 08-27-2013, 08:47 PM   #14
Thanks!
Originally Posted by ssdub33 View Post
All I can say is wow that looks incredible gonna have to try it now
Make sure you show us your results
Old 08-27-2013, 11:35 PM   #15
Thanks for the tips bud, now all I need is another body to try this, cheer`s
Old 08-28-2013, 06:52 AM   #16
Well.... Before I was given the idea above about using the inside of a 2 liter bottle, I looked up how to remove paint. DOT 4 synthetic brake fluid! $5 and it works!
Old 08-28-2013, 08:42 PM   #17
So when doing a hardbodyn you lay down the main color then use the bag w the paint on it and dab or spray on the body and dab?
jcsaxial is offline   Reply With Quote
Old 08-28-2013, 09:45 PM   #18
You spray on the BAG and dab....if you were to spray on the BODY and dab, your trying to REMOVE paint rather than add, I think adding dabs is easier than removing it. SPRAY BAG AND DAB BODY. Thats how I did it.
Old 08-29-2013, 07:10 AM   #19
Cool thanks! Ive got some styrene ill test on.
Old 10-28-2013, 06:35 PM   #20
Looks GREAT! Really like the marble effect. I may try it on my next scaler body.
njohns14 is offline   Reply With Quote
My first attempt at trying "marbleized" painting - Similar Threads
Water Skip "Attempt" MnRockCrawler Formula Offroad 23 04-18-2011 07:00 AM
Painting A "worn Looking Body" twisted Paint and Body 4 05-08-2007 11:49 AM
My first attempt at a "Stick Chassis" new2crawl General Crawlers 15 02-25-2006 12:57 AM
