Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Trim or not to trim? Before painting
Old 12-14-2013, 07:19 PM   #1
Default Trim or not to trim? Before painting
I will be painting my first body for my Axial G6 kit and was wondering should I trim the body first then paint, or vice versa. I have seen both methods and not sure what would be best. Can I get some of your opinions based on your experience painting bodys. Thanks
Hirschowl is offline   Reply With Quote
Old 12-14-2013, 07:51 PM   #2
Default Re: Trim or not to trim? Before painting
I trim first before paint so I do not take a chance messing up the paint. You can damage the paint by scratching it or even tearing the lexan while removing the excess material.
jwalker is offline   Reply With Quote
Old 12-14-2013, 08:34 PM   #3
58_Willys's Avatar
I always trim first, that way I can clean up the edges of the wheel wells and make sure any other lines are straight. I agree with jwalker about damage to the paint also.
58_Willys is offline   Reply With Quote
Old 12-14-2013, 08:45 PM   #4
I always trim out first and if the bod is for me, mark out mounting holes
Bc Paints is offline   Reply With Quote
Old 12-14-2013, 11:14 PM   #5
Trim trim trim
fr8cture is offline   Reply With Quote
Old 12-15-2013, 07:58 AM   #6
Ok I know what I will be doing first. Thanks guys for your replys.
Old 12-15-2013, 11:49 AM   #7
I trim and mount first, that way I can have it exactly where I want it.
canadianbacon is offline   Reply With Quote
Old 12-16-2013, 07:46 AM   #8
I trim mine out first and mark body mount holes with marker to drill out after painted
redneck thug is offline   Reply With Quote
Trim or not to trim? Before painting - Similar Threads
Trim Questions BillBergman RC4WD Trail Finder 2 5 01-03-2013 04:31 AM
to trim or not to trim? jimbob78 Axial SCX-10 14 07-06-2012 04:33 AM
To trim or not to trim bro_die Axial AX-10 Scorpion 18 12-30-2010 07:59 AM
i cant get the trim set bigdog5332 Electronics 1 03-20-2008 07:25 PM
fender trim nodnarb81 Paint and Body 2 02-17-2007 09:12 PM
HTML code is Off
