Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: tips on cutting odd shaped decals?
Old 08-15-2019, 11:18 AM   #1
Default tips on cutting odd shaped decals?
EVERY search I do yields tutorials on cutting square decals of different sizes, not shapes...
How does everyone cut larger decals (i.e. for side of truck) where letters and/or shapes run off the main body of the decal leaving large areas of clear decal with no colored edges? (which would create the "shadow" from the thickness of the decal sheet)
Do you cut up to the shape no matter how thin it gets?
VR6 BeelzeDub is offline   Reply With Quote
Old 08-15-2019, 12:58 PM   #2
Depends on my mood . Bright light, laid out on glass, I buy my #11 blades in bulk for a reason. I found a clear plastic angle protractor works great for cuts
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 08-15-2019, 01:50 PM   #3
Default Re: tips on cutting odd shaped decals?
I didn’t think about cutting on a glass surface... I’ve been using a cutting mat and light pressure barely scored the decal sheet. So all I was doing was throwing out blades and pulling my decals at the same time.
Do you cut out any borderless clear part of the decal sheet? Meaning where it’s not surrounded by graphics?
Old 08-15-2019, 03:46 PM   #4
I usually try to cut right and tight.
If I can. Some decals or stickers are next to impossible to cut neatly.
Those I will try to make look like a sticker with an even clear border.
I’ve removed more than I’ve kept over the years
Hang up and Drive
tips on cutting odd shaped decals? - Similar Threads
Any tips for cutting door jam lines in mask? moyoman202 Paint and Body 12 05-04-2018 07:53 PM
any tips on cutting the body 1santaever RC4WD Trail Finder 2 11 03-08-2015 09:34 PM
Tips for applying Creeper decals / newbieCrawler123 Venom Creeper 4 02-06-2012 03:23 PM
tips for cutting foams minor_threat Tires and Wheels 34 02-15-2009 02:55 PM
Tips for cutting tires andres-tavares Tires and Wheels 19 11-07-2007 09:43 PM
