01-12-2022, 08:56 AM | #1 |
Newbie Join Date: May 2020 Location: Saco
| Body post hole question.
I have a body with pre drilled holes in it. The holes are undersize right now. The location is pretty close to what I need, but off just a bit. What is the best way to enlarge the wholes and offset them to where I need them? Thanks |
01-12-2022, 09:05 AM | #2 |
| Re: Body post hole question.
I use a Dremel with a cone stone bit to make body post holes in my bodies. Makes a perfect circle everytime and the size of hole can be adjusted by how deep the stone is pushed into the body.
01-12-2022, 09:34 AM | #3 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
I bought a body reamer some time ago on a sale, and am glad I did.
01-12-2022, 10:30 AM | #4 |
I wanna be Dave Join Date: Sep 2019 Location: US
I second the body reamer. Honestly, it's the best (and should be 'only') till did the job. The Dremel is one of my "go-to" tools in RC...but, if should definitely not be used for this, as it can enlarge the hole too quickly, causing the hole to be too large. When creating, or enlarging, holes for body mounting, you want to take things as slooooow as possible. ~ More peace, love, laughter, & kindness would make the world a MUCH better place |
01-12-2022, 10:34 AM | #5 |
If I use a body reamer or a cone dremel tool it will just make the whole bigger. I need to shift the hole a bit and make it bigger. |
01-12-2022, 11:13 AM | #6 | |
| Re: Body post hole question. Quote:
~ More peace, love, laughter, & kindness would make the world a MUCH better place | |
01-12-2022, 04:44 PM | #7 |
Quarry Creeper Join Date: Nov 2020 Location: Greece
I'd tamper with the body post instead of the lexan if I were you. Even if you manage to do a perfect job, it will look odd with the enlarged holes. Just get the proper body posts and make them sit on the chassis.
02-06-2022, 09:04 AM | #8 |
Newbie Join Date: Jul 2013 Location: Skook
All of them are off a little? Cut the mount off the body mount and screw a new body mount in front or behind of the existing one.
Body post hole question. - Similar Threads | ||||
Body post question for body swapping a Gatekeeper | Goro Majima | Element RC 1/10 Enduro Trail Truck Sendero | 9 | 01-13-2022 11:59 PM |
weld-on #16 - Post hole filling? | itr1275 | Paint and Body | 12 | 12-13-2020 05:24 AM |
Tekin 55t HD mounting hole question | TDanny | Electronics | 4 | 01-25-2019 02:22 PM |
SSD 1.9" STEEL D HOLE WHEELS question | desertdude | Tires and Wheels | 16 | 02-18-2016 03:30 PM |
Breather hole question | desertdude | Axial Yeti | 6 | 03-27-2015 10:29 AM |
