12-07-2008, 10:05 AM | #61 | |
Quarry Creeper Join Date: Aug 2008 Location: Yes yes, it is.
What did you decide to do for tires and a swaybar? I bet you could make your Rims baloon with your new motor. | |
12-07-2008, 11:32 AM | #62 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
I am undecided on these two, a set of slicks , new for only $24. delivered or a set of used Proline road rage on ebay . The slicks would only work for the street but with as big of a motor I'm going with it might end up a drift only tires and no hard pack dirt, which is why I like the Road rage tires. Both the same Height 110mm 4 3/8 and 43mm wide slicks slightly wider proline. |
12-07-2008, 03:51 PM | #63 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
here's what I was talking about with the wheel collars on the sway bar. |
12-07-2008, 04:21 PM | #64 |
thanks Slobin I see that now. mine pivot just like yours That's a OFNA Jammin buggy, NICE ! I was wondering if I should use OFNA DIffs and a XRAY Diff as the Tranny like this |
12-07-2008, 04:25 PM | #65 |
my pic is of a mugen seiki mbx5t lol, you see what i was saying about being able to slide them in or out to adjust stiffness with just loosening a set screw, a little more versatility without having to swap to a stiffer sway bar. none the less its a sweet build and looks like it will be fun |
12-08-2008, 09:11 AM | #66 | |
RCC Addict Join Date: Jun 2008 Location: Fresno
12-08-2008, 01:44 PM | #67 | ||
Yea I keep forgetting that design is adjustable, Thanks I like that. No doubt this build will be on the tight budget until I get a job Then the reall Good stuff will be bolted in. Like a Neu 1515 Motor MGM high grade ESC 1/8 scale buggy diffs Xray center maybe a 10s Lipo but now I am just anxious to drive it. Quote:
I asked the guy he said they griped really well on his gas 4wd. so I passed on them. For the Hard pack I'll buy some off road tires like these proline knuckles 4.4" x 1.6" Last edited by toy4crawlin; 12-15-2008 at 02:43 PM. | ||
12-09-2008, 08:57 AM | #68 |
just a quick question what size tires would be needed on this? asking because if you could find somthing w/ the lug pattern of the proline switch it maybe you ticket i know when i use these on my slash i hook up really well on dirt and asphalt but when ever i want to kick the rear end around i lay off the throttle a bit then give it a quick squeeze. (*both dirt and asphault) |
12-09-2008, 09:41 AM | #69 | |
Now the only problem is I need a 14 or 17 hex Does your sidewall flex, could be great for jumps, not sure for rally sliding on hard pack ...? I need a tire that is 110mm to 122mm or 4 3/8 to 4 3/4" tall so far the 1/8 buggy wheels fit budget and are only slightly smaller than 1/5. 1/8 lighter also Last edited by toy4crawlin; 12-09-2008 at 09:47 AM. | |
12-10-2008, 05:19 PM | #70 | |
12-11-2008, 01:44 AM | #71 |
12-11-2008, 02:32 PM | #72 | |
Quarry Creeper Join Date: Jun 2006 Location: Aurora, CO
12-11-2008, 07:24 PM | #73 |
12-12-2008, 02:22 AM | #74 |
Newbie Join Date: Aug 2008 Location: in ur hard-drive
2 things u could just cut out the 12mm and toss in a 17mm and just put some of it in ur moth and start taring pices off it then show it to ur theacher and most the time they will think ur do did it it worked for me 6 times so far this year |
12-13-2008, 06:48 PM | #75 | |
toy4crawlin, did you find any rims? | |
12-14-2008, 05:20 PM | #76 |
I was thinking of cutting off the tread on the stock emaxx tires to make them slicks But I think I will settle for some tires that my hobby shop found, but the Rims are Ugly a$$ Dish rims SO I'm waiting on just the tires to come in, I cannot remember the name but nothing I have heard of before 1 3/4 wide 4 3/8" tall found some better looking rims but they are yellow and HS could not find anything except white and yellow, so it looks like I will be sanding and Painting them Gun metal Made up a front bumper Been busy Repairing the body and front valence Riddled in cracks Waiting for glue to dry, Shoe goo Is awesome ! went to sign shop to have my race name made to put on the windshield time for some body mounts |
12-14-2008, 05:33 PM | #77 |
12-15-2008, 02:25 PM | #78 |
IF anyon is looking to turn thier Emaxx or whatever into a big version there is a lot of resources Just found this: Emmax to 5th scale Baja Last edited by toy4crawlin; 12-15-2008 at 02:43 PM. |
12-21-2008, 06:57 PM | #79 | |
12-27-2008, 08:06 PM | #80 |
Does it run yet? |
