01-02-2009, 09:34 AM | #81 | |
Rock Stacker Join Date: Jun 2006 Location: Harlem
Try a set of 2.8 Losi speed T tires on the stock traxxas e/t maxx wheels. maxx wheels are 3.3. A guy came in the local Hobbytown and put a set of stock maxx wheels with the speed T street tires on his slayer. looked like it had a set of 28 dub wheels on it with low profile tires. tires can be stretched on but takes a little work. | |
01-06-2009, 04:29 PM | #82 |
Quarry Creeper Join Date: Aug 2008 Location: Yes yes, it is.
Does it stand on its own now?
02-26-2009, 10:27 PM | #83 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
Hey guys, sorry it's been a long time but IT RUNS ! I found a cool set of tires on ebay (Sportwerks hot laps Auto cross) In my Effort to support my Local Hobby Shop I drove there to order them, I asked them to order them early December. The shop forgot the order did not get them till late January Again I found cool wheels on ebay and asked the shop to find me some . The hobby shop only carried bright yellow and white 1/8 scale wheels and could not find the black spoked. The Owner gave a Rude comment that I cant be pleased. Instead of him telling me that I should go to his other Shop 20 minutes away which has a HUGE variety of wheels and I should look there. Well I went and Found Exactly the wheels I have been wanting at his Other shop, what a jerk With that poor service I would have saved a lot of gas and time and a few bucks cheaper buying them on Ebay instead. I dont have the money right now for big 6S Lipo batteries to run the huge Brushless 2100k motor so I dropped in the fastest brushed motor I had 10x1 and 7 cells nimh. The car only goes about 25mph. but was cool to see the big thing go. It had heavy body roll without the sway bar so I added it back in and made a huge improvement. It was very cool to drive and cant wait to drop in a Thunder power Extreme 22.1 volt Lipo 5000 . I have seen on youtube a Revo go 61mph with on board GPS. So getting this beast to 50 shouldn't be a problem with a upgraded drivetrain. The shock towers will be made and Drilled so that when going Offroad and jumping All I have to change is the 4 nuts for the upper shock placement. Still needs some shock and spring tweaking . HELP Please . Need help on PAINT I want to remove some of the Yellow around the grill area and continue the Red from the Flames to the lower valence. Can a Paint pro or somebody tell me the safe way to remove the paint I'll shoot some video and post it I thought I had Street pics, guess not Thanks Last edited by toy4crawlin; 06-06-2009 at 08:50 AM. |
02-26-2009, 10:30 PM | #84 |
I was wondering what happened to this...thought maybe you gave up. Or it ran you over. Good to see it up and running though! |
03-16-2009, 10:23 AM | #85 | ||||
I'm back I dropped in my Mamba max and 12 cells ! I'd say it maybe goes 22 mph with locked 4wd so Shopping for a ESC Mamba monster = only 6s lipo , possible 50 mph with Two 3s lipo 5000 MGM = 10 S lipo max , speeds over 70 mph maybe 80+ Car Weight 7.5 lbs with Motor no battery 9 lbs Loaded with 12 Nimh cells 12 lbs Work To Do: Motor needs to be lowered onto chassis Bigger Shocks Neu motor, not sure which one, maybe 1515 Needs Front Differential or a Xray Trans diff ESC options: MMonster or
other high power ESC's 100-250 amp | ||||
03-16-2009, 11:58 AM | #86 |
Something you might want to consider, and an issue I had with my Revo to Slayer conversion, is transmission gearing. Since the tire radius dropped considerably, I had tons of torque but not alot of top speed. I could either swap out the primary gears, or go with a whole new transmission. Gears were $10, the whole trans was $35. I went with a trans. Speed is now back to a respectable level, with enough torque to still allow it to launch on its bumper. |
03-21-2009, 01:26 PM | #87 | |
but with 5mm motor shaft I have limited gear options. I am aiming for a Xray center diff tranny--> direct drive. It's all about money and time and I lost my $70k job this will take a long time. Plans are 6S to 10S lipo Nue 1512 Brushless or similar Tekin XC8 or MMM or MGM ESC CF chassis Xray or OFNA Drivetrain | |
03-22-2009, 07:10 PM | #88 |
Super Torque ! Wheel spin launches :-P I did some gear changing 21 pinion 58 Spur 3s 2250 30C lipo 28mph ! I'm, thinking of going 48 Spur All 4 wheels spin and even at 10 mph it launches All this on old rough Asphalt Cant wait for 6S or 8S Lipo Last edited by toy4crawlin; 06-06-2009 at 08:51 AM. |
04-09-2009, 08:27 PM | #89 |
Been busy on ebay selling off my RC stuff and anything I could find to fund this CAR Ok some new parts arrived :-P Losi aftershock 1/8 Diff centers Losi HD Diff housings Losi 2.0 truggy 16mm shocks FG wheels in the mail from United Kingdom machine up some adapters Ordering two Neuenergy 5s1p 3200 25c lipo's = 5s 160 amps 6400 mah $150. Speeds expected in the 55+mph ! Ordering Mamba Monster and CC 2200 motor Emaxx diff bulks/suspension cage can be modified to fit the Losi 1/8 aftershock diff centers. Since the Emaxx t-maxx revo diffs are very weak. Been getting on my info on RC-monster.com pics not fitting, have to edit |
04-09-2009, 08:58 PM | #90 |
great to see you working on this project again. have you tried fine design rc or kershaw designs for your pinions, from what ive seen they have a pretty good selection for 5mm. be sure to get some vid when you have the time. |
04-10-2009, 12:16 AM | #91 |
Rock Crawler Join Date: Dec 2008 Location: Appleton, Wi
Where did you get those lipos from? Its always good to know where you can get a giant brick of tire ripping power for cheap. |
06-05-2009, 05:20 PM | #92 |
UPDATES ! New shocks ! All new drivetrain ! Machined some delrin and aluminum blocks for the diffs to lock them up machined some adaptor rings to use losi centers with emaxx bulk heads cut/ modified traxxas stub axles to use as diff outputs for the losi diff to connect to revo shafts, last pic LOSI 8ight, Diffs and LOSI 8 E Center 49/14 total ratio to start with 11:1 Original emaxx tranny ratio was 15:1 and with 3s lipo and cheapo Feigao8xl 2183kv motor the wheels peeled out . it was a blast to drive Last edited by toy4crawlin; 06-05-2009 at 05:36 PM. |
06-05-2009, 05:49 PM | #93 |
NEw used FG 1/5 wheels been a machining nightmare making bolt adaptors to get these on, so no luck yet. made a new tranny/motor mount out of delrin, just need to square up/ drill and bolt it up new Castle monster combo 2200motor programmed my old faithful Airtronics radio (with the BRAKE BUTTON ! ) Working with my mamba max the brake was awesome, a castle tech help me program it but for some reason when I got my Monster I could not get it working on brake button so I called castle again and only got a ignorant guy telling me there system is not design for brake and the button is a " back button" after trying to tell him numerous times it works on my max and him still not acknowledging it I gave up and just tweaked on it for a while my self and got it working Been shopping for a 5s or 6s lipo and found a shortly used 6s Polyquest enerand cells 6000mah 25c for only $150. from Australia and so excited to get it I just found out the guy cant ship because of new mail restrictions, big fat bummer Any body got a nice lipo for sale ? Speeds will be in 50-65mph ! Last edited by toy4crawlin; 06-05-2009 at 05:51 PM. |
06-06-2009, 08:53 AM | #94 | |
the lipos were on a clearance sale but they went so fast that they only had one left so I'm still looking for a 5s or 6s setup where are all the good places to shop for Lipo's ( with Enerland cells) ? | |
06-06-2009, 11:15 PM | #95 |
RCC Addict Join Date: Jun 2008 Location: Fresno
yeah!!! finally an update!!! this is the first time i have ever thought the mamba monster max and neu motor looked small |
06-08-2009, 09:55 AM | #96 |
06-08-2009, 12:37 PM | #97 |
Goodbie Crap Green ! I picked up some high heat engine paint (500*) but the yellow was super light so I used regular Enamel that withstands 200 degrees I masked off the fins so I wouldn't have the tedious task of taking the paint off but I ran out of tape half way. painted it then used razor blade to crap off the fins that were painted came out really nice |
06-08-2009, 01:40 PM | #98 |
Quarry Creeper Join Date: Feb 2008 Location: New Rochelle
go to hobbycity.com and buy batterys from them. I would suggest a 5 or 6 cell 5000mah flightmax. http://www.hobbycity.com/hobbycity/s...idProduct=8590 thats the 6 cell http://www.hobbycity.com/hobbycity/s...idProduct=8589 thats the 5 cell. I have that and i am going to use it in my truggy conversion with a mmm 2200. |
06-08-2009, 02:02 PM | #99 | |
you get what you pay for . Any idea what cells are used in those packs ? I'll do some searching and see how people are liking them. I'm looking for Enerland cells, Flight power, and I think Thunder power using them, best stuff and will last. | |
06-08-2009, 04:57 PM | #100 |
I have the 5 cell version 30c and my freind has 4 of the 3 cell versions. He thinks they are the best lipos he has ever used. They also have a warranty on them. Also they sell a 1/5 and 1/8 esc. I dont know much about it but its only 150$. worth a try. The thunderpower and those brands will cost 350$ for the same 5000mah battery. It is worth trying this. you can get three for less. I liked mine atleast.
