08-01-2009, 10:00 PM | #41 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
can you make a video showing us how the 454's do on this rig? please? my dad has some 7t cobalt's on his killer krawler...it just plain RIPS!!!! it's a power house for sure! nice smooth, slow start-ups...but will ride a wheelie if you punch it...amazing motors! it's making me think some 454's like what you have would really really be nice on a 2.2? I'm really liking your build..nice job. |
08-01-2009, 10:09 PM | #42 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
So I headed for my favorite local spot--a place I have spent countless hours with my shafty. So this gave me something to guage the rig on. Well I was indeed impressed--but its going to take some getting used to with the clod stall. But I was able to make every line I had with my shafty, granted a couple I had to work harder--but that might have been because I do indeed have too much weight in my wheels.. I will have to say I am impressed with the wheel speed I am getting with the 2 cell lipos I am running.. Now one thing I did notice and I am not 100% sure this is normal. But when you are in dig--you don't have the power you do when in 4 wheel drive.. Well I had to quit when I found one screw missing from my knuckle and put a slight kink in my servo horn and also the bolt that holds the tire rod/draglink on. But I did shoot some video and will try and get something thrown together. |
08-01-2009, 10:15 PM | #43 | |
08-01-2009, 10:23 PM | #44 |
How warm did they get Mike?
08-01-2009, 10:32 PM | #45 |
08-01-2009, 10:38 PM | #46 | |
Getting used to the stall is gonna be fun, after being used to having all 4 pulling until you engage dig for so long. But, I'm sure you'll figure out how to use it to your advantage soon enough.... | |
08-01-2009, 10:45 PM | #47 |
| After watching you drive yours--I am sure I can learn --granted your a hard act to follow |
08-02-2009, 01:45 AM | #48 |
08-02-2009, 06:47 AM | #49 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
Definately, lose some weight in the wheels. I'm running VP Pro Comps with no weights in the rear and 4 bullet weights in each front. So far this weight balance has give me the best results. As for the knuckle bolt coming loose, thread lock is your friend. Did you locktite everything before assembling the rig? If not, I highly recommend taking the axles completely apart and thread lock every screw. The knuckles need particular attention. I used blue for everything, but I still check the knuckle screwes after every run, applying thread lock if they are loose at all. You may even want to use red locktite on the knuckle screws. |
08-02-2009, 08:34 AM | #50 | |
| Quote: I wanna hear those motors...not soft hits from the 80's..... thanks | |
08-02-2009, 03:10 PM | #51 |
Rock Crawler Join Date: May 2007 Location: Norwich
Wondering what the wheel speed is with those motors? Could be just the ticket.
08-02-2009, 05:35 PM | #52 |
ok ok--how about I make a video with some wheelo speed |
08-02-2009, 10:46 PM | #53 |
Rock Crawler Join Date: Mar 2009 Location: AZ
08-03-2009, 02:32 PM | #54 |
I have gotten a bunch of requests for how much wheel speed you can get out of these motors. 2 cell lipo, front pinion 13t and rear 11t http://www.youtube.com/watch?v=3ssD7TEPXUQ |
08-03-2009, 02:55 PM | #55 |
Ok so I am still tweeking it. I knew I had too much weight in my wheels. Here is how much I pulled out of all 4. 11.7 oz The rears are now at 7.8oz The fronts are now at 11.4oz |
08-03-2009, 03:03 PM | #56 |
So one thing I wanted to do was give some motor protection. Well I looked at lonewolfs axle shield--but I just don't feel you need to have a full skid on the axle--plus you loose ground clearance and I have seen these axles just slide over rocks anyways.... So I had gotten a few ideas from RCC. Well the wife came home with a new container and I was sitting here looking at the lid--well I got a ll ninja like and swiped it,lol Well the material feels perfect.... Now came the hard part--making it round and of course I aint got no heat gun. But I do have a torch nozzel for sweating copper pipe. So I cut it into 2" wide strips and 3" long. So all I did was start out with a larger diameter piece of tube than the motor dia and started heating it and closing the zip ties. |
08-03-2009, 03:08 PM | #57 |
So it started to take some shape.. So next step was to repeat the process on a piece of 1" dia tube. Here is what I finally came up with. I decided to drill holes and loop small zip ties thru the holes to hold it into place. Will see how well this holds up. But here is the end result |
08-03-2009, 06:21 PM | #58 |
That's an interesting idea with the motor sheilds. Keep an eye on the motor temps, and report back whether they stay cool or get hot. (I'm curious)
08-03-2009, 06:23 PM | #59 |
| I ran pack on my course and I could still touch the motors. Heading out in a few to meet a buddy and do some more testing |
08-04-2009, 03:52 AM | #60 |
Thanks for the vid. Those little motors can get up and go!
