08-05-2009, 10:42 AM | #61 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
SO just a little update. I have been playing with this thing every chance I get. I did find my servo fix didn't do the job 100%--so I upped it one more step and this seems to be doing the job--took a good hard smack Now thats some beef and holond up quite well now. I am however still concerned with hitting the servo horn hard enough to damage the servo--so I am still looking at other options.. I found I was having a glitch when I would run the servo back/forth pretty fast. I ended up pulling the BEC power from the reciever and going directly to the servo and using the ESC power for the reciever and dig switch--that seems to have fixed it. I am still tweeking the ESC and getting it better tuned to my needs--but I am still unsure if my clod stall is "more" than I want. I went and swapped the front pionion for a 12t so running a 12/11 combo and I think it helped a tad. But I am still concerned my voltage is just too low and causing more stall. I also pondering the idea of maybe the link geometry is causing some... |
08-05-2009, 10:57 AM | #62 |
Quarry Creeper Join Date: Oct 2005 Location: MD
I have my BEC powering my 7955 servo only, and it works well.
08-05-2009, 11:02 AM | #63 |
08-05-2009, 11:45 AM | #64 |
I consider my Servo horns disposable or to be a fuse.... I think you might be in for some serious damage if that rig takes a nosedive and hits hard on the horn. |
08-05-2009, 12:08 PM | #65 |
| And thats my fear--I am looking at things at a different angle too--will see if I can come up with something...
08-06-2009, 09:54 AM | #66 |
Ok so I looked at the steering again and re-evaluted it. I came up with the conclusion that having the servo horn up where it was--was just asking for trouble on hard flips and tumbles. I didn't want to risk damaging the servo so I pulled the mount off and redid it.Here is what I came up with. I am still unsure of the tie rod placement. If the tie rod goes below the arms then its lower and more likely to get hung up--but it will protect the servo horn. If I run it on top--I retain the clearance I had but the horn is there to be hit. |
08-06-2009, 09:36 PM | #67 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
very nice build i like that wheelspeed on that.
08-07-2009, 03:49 PM | #68 |
Well here is how the steering turned out. I am pretty sure I will redo it again but for now it works pretty good and still higher than my tlt was. So I took it out at lunch today at my local play area near work. Lines I know my tlt would get stuck due to steering--I didn't have any issue I could not drive thru.. |
08-07-2009, 03:49 PM | #69 |
08-07-2009, 04:02 PM | #70 |
Rock Stacker Join Date: Aug 2008 Location: Grand Junction, Colorado
wow, I really like how you made damn near everything.
08-08-2009, 04:56 PM | #71 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
LOVE your steering set-up.... you should run the links like this for a little more clearance??? xirtic's rig.. great build!! |
08-08-2009, 07:03 PM | #72 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
As you can see from 53 Willy's post above, I have also been chasing the inverted steering servo setup. I was going thru a servo horn every few days, and I was not happy thinking that it was chewing up my servo hit-by-hit. Here are a few things that I have found helpful: 1. Use a 4mm based steering linkage system with REVO ends. My links are NOT hollow delrin. I push a 4mm threaded rod thru the entire length of the delrin steering links. This gives me a VERY strong link, and also makes them slick....without getting overly bulky. 2. I have had NO negative impacts raising the links and reversing them as shown in the picture. Give it a try. I will be hitting the rocks again tomorrow with this setup for a local Comp. My build, and more photos of my setups are located at: Bully Build - Take Two |
08-09-2009, 11:11 AM | #73 | |
Rock Crawler Join Date: May 2007 Location: Norwich
Seems like the battery isn't up to the task. The first few minutes are great but after 4-5minutes she starts losing punch. Was thinking a larger 2C or maybe, fingers crossed, 3C? | |
08-09-2009, 02:14 PM | #74 |
I had really sat there and looked at doing the draglink/tie rod above the arms. But I kept coming back to the servo arm right there in the bash zone--in the area where you are constantly hitting. Along with that and the rolling mass you get from these bully's--it just added up to bad. Plus here we comp on rip/rap rock way more that monolithic--so the hitting of the tie rod is alot more. I might try it and see how it goes. But after our GTG yesterday--ran 3 10 gate courses (6 of us) I was able to win all 3--and my tie rod never seemed to be an issue. I also tried a 3s lipo and I did not notice a single difference except the wheel speed and that was not a concern.. So after some time with the rig--I figure the motors broke in because the clodstall is alot better now. Also the motors did not get very hot--hell my servo got hotter But I am very happy and looking forward to the club comp next sunday on mono rock |
08-09-2009, 02:19 PM | #75 |
Oh and on e thing to add--what 4mm rod ends are you guys running?
08-09-2009, 02:31 PM | #76 |
08-14-2009, 10:15 AM | #77 |
One thing that really interests me. So on my shafty I was running a novak brushless 18.5 turn motor goat system with the same lipo's. So with my dual motor setup and a servo that gobbles more power--I am getting longer run times with the same battery packs. I just thought it was interesting--and hoping my new G3 3 cell lipos show up today for this weekends comp..
08-15-2009, 02:30 PM | #78 |
08-15-2009, 03:36 PM | #79 |
Tra5347
08-15-2009, 06:38 PM | #80 |
