10-25-2012, 09:38 AM | #21 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
| Re: extreme steering mods? |
10-25-2012, 09:40 AM | #22 |
im 4 linked ;)
10-25-2012, 09:42 AM | #23 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
I recon they already stick out too far, plus then you're increasing the throw of the tyre which'll probably cause it to hit the shell instead.
10-25-2012, 09:42 AM | #24 |
doh scarp that then sorry.
11-18-2012, 08:23 AM | #25 |
ok i tore the truck down and split the axles to try to get some more steering. turned out to be a waste of time first i thought the ball part of the knuckle was hitting the straight axle housing tube limiting steering angle. so i ground about an 1/8" off the knuckles using a 1/2" drum. then i realized that wasnt the problem, it was the XVD stub axle hitting the axle housing tube "ball" on the end. so i ground that down. once those two were done, i could see the real problem. the xvd was limiting itself. the XVD stub axle hits the ring that goes around the ball joint. you can see it in this pic, just to the left of the ball joint, and just right of the silver and green. if you look on the stub shaft you can actually see where its been rubbing. (silver no grease) so with that actually limiting the trhow im not sure what to do. all the other grinding did no good. maybe 1 degree extra if anything any ideas? Last edited by STANG KILLA SS; 11-18-2012 at 10:43 AM. |
11-18-2012, 09:03 AM | #26 |
Enlarge the diameter of the bore so the ring has some place to go? IDK, I'm just tossing out the thought.
11-18-2012, 01:01 PM | #27 |
Beg rc4wd,VP,sds to make a cvd or universals.
11-18-2012, 01:30 PM | #28 |
im actually thinking about going back to the dogbones if i can get my hands on a stub shaft. i have everything else but 1 of my stub shafts is bent. im wondering if i could actually get more angle out of them. |
11-19-2012, 02:05 PM | #29 |
I was just looking another possible option for those interested in finding an overdrive for the front on the tf2 rigs. If you run a K-44 front axle and a Yota rear axle you will essentially have the same exact gear reduction as an axial using the offset ring and pinions. Plus the k44's have more steering than the tf2 stock axle to begin with. The k44 axle may require some kind of wheel spacer to match the width of the yoda axle as they are slightly narrower. I'll give it a shot and see how it works..... Last edited by TURBOFEST; 11-19-2012 at 02:08 PM. |
11-19-2012, 02:13 PM | #30 | |
| Re: extreme steering mods? Quote:
11-19-2012, 02:17 PM | #31 |
Fine! LOL How did you underdrive your rear? T-case mod? |
11-19-2012, 02:22 PM | #32 |
| Re: extreme steering mods? remember my axles arent in a TF2 and yes to answer your question. a little birdy definatly "in the know" PMed me and said that the XVDs max out at 35* so im going to try going back to dogbones. stock and then moded, to see what i can get. |
extreme steering mods? - Similar Threads | ||||
anything mods to get more steering angle? | champ198 | Tamiya TLT Crawlers | 9 | 11-02-2011 02:42 PM |
are steering mods necessary to not fry servo | bikerj08 | Axial XR10 | 13 | 03-20-2011 09:58 PM |
Steering Knuckle Mods | dirttrackdemon93 | Tamiya CR-01 | 1 | 07-10-2009 02:21 AM |
TXT steering mods... | j0e | Tamiya Txt-1 and Juggernaut | 18 | 12-20-2007 10:10 PM |
steering mods | z71er1c | General Crawlers | 1 | 01-15-2007 03:29 PM |
