Thread: Setting shift servo?
Old 07-13-2014, 09:32 AM   #1
Default Setting shift servo?
I hate to show my ignorance but I have burned up one shift servo all ready trying to set the EPA on it. I now have a second servo on the truck and am worried I'm gonna burn it up also. I'm almost to the point of just leaving it in low gear and running it like that. Any tips on setting it would be great. Thanks...
Crutch is offline   Reply With Quote
Old 07-13-2014, 05:41 PM   #2
Using a servo saver on your shift servo is a good idea. The trans doesn't always switch gears immediately so while it's in the process of shifting the servo saver will keep the servo from burning up
gcm2006 is offline   Reply With Quote
Old 07-14-2014, 07:00 AM   #3
Default Re: Setting shift servo?
Try to only shift when it's rolling. Also when you do shift, after it locks into gear listen to the servo and see if it's still making noise. If it is dial it back some.
Tgreer is offline   Reply With Quote
Old 07-14-2014, 08:15 PM   #4
Thanks for the tips. I may try a servo saver to try and take a little pressure off the servo.
Setting shift servo? - Similar Threads
shift servo Be Nice Vaterra Twin Hammers 4 06-10-2014 02:27 PM
Shift servo eric113 RC4WD Trail Finder 2 19 09-05-2013 09:22 PM
best shift servo ax10newguy Vaterra Twin Hammers 4 07-24-2013 02:49 PM
Shift servo? 09 Screw Electronics 5 03-01-2011 07:12 PM
shift servo 4-linkedWK Electronics 3 04-12-2008 09:06 PM
