12-22-2014, 05:59 PM | #1 |
Pebble Pounder Join Date: Nov 2013 Location: Toronto, Ontario, Canada
| Just starting my build and...
Just started my build and I'm wondering 1) I purchased the soft red leafs , should they be used? Are they better for articulation ? 2) went with the all metal punisher driveshafts as I always wanna go bulletproof from the get go.
12-22-2014, 06:33 PM | #2 | |
Rock Crawler Join Date: Oct 2009 Location: Columbia, SC
| Re: Just starting my build and... Quote:
12-22-2014, 10:35 PM | #3 |
So far so good. Frame is pretty much done, just gettin to the leaf springs now. Gonna use the reds. |
12-22-2014, 11:41 PM | #4 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
I started out with the reds and found that they bent very easily on the rocks. I ended up going back the blacks but adding shooters and T-boxes front and rear. That plus longer shocks (90mm up front using the top hole on Gelande 2 shock hoops and 100mm in the rear) made the biggest difference among the things I've tried. I've now had quite a bit of run time with it (probably close to 10 hours) and am really happy with the setup. Here's the link to my thread: TF2 = time to push my scale envelope Good luck - these rigs are a blast! |
12-28-2014, 09:33 PM | #5 |
Chassis and suspension is pretty much done. Just setting up the steering linkages. Now on to the 2nd stage ... prepping and painting the body! |
12-29-2014, 11:15 AM | #6 |
Rock Crawler Join Date: Sep 2013 Location: New Orleans
| Re: Just starting my build and... |
12-29-2014, 11:35 AM | #7 |
Just kinda goes with that year of truck I guess.
12-29-2014, 11:36 AM | #8 |
12-29-2014, 11:44 AM | #9 |
| Re: Just starting my build and... Agreed, I try to choose the colors of that particular year when I build things like that. tokdl2's second TF2 build. Last edited by tokdl; 12-29-2014 at 11:52 AM. |
12-29-2014, 11:48 AM | #10 |
12-29-2014, 11:53 AM | #11 |
12-29-2014, 11:57 AM | #12 |
12-29-2014, 12:16 PM | #13 |
Pebble Pounder Join Date: Dec 2014 Location: Oshawa
TF2 is great little truck to build up. I find the red leafs bend to easy as well. CREEPINKINGs little front setup looks neat i will have to try that out on mine. |
12-29-2014, 07:34 PM | #14 |
12-29-2014, 11:01 PM | #15 |
On Trails the reds were fine. But rock crawling and getting a tire stuck ended up in S twisted leaf. I have a neat pic flexing leaf spring into a S bend |
12-30-2014, 02:14 AM | #16 |
Quarry Creeper Join Date: Oct 2011 Location: Anchorage
| Re: Just starting my build and... Ouch xS... For me the stock black leads flexes plenty... I've even added the medium helper on the bottom of mine just to increase ride height because the black ones too soft and droopy
Just starting my build and... - Similar Threads | ||||
looking at starting a build. need help. | Pgambardella | Axial SCX-10 | 10 | 03-12-2013 09:19 PM |
Starting a build | rangair94 | 1.9 Scale Rigs | 15 | 08-30-2012 09:51 AM |
Starting my build | DeaDShorT | Tamiya Clod Buster | 55 | 02-18-2007 07:17 PM |
Starting my first build | CRUSHER1 | Tamiya Clod Buster | 72 | 09-08-2006 11:31 PM |
Starting A New Build!!!!! | truegaintfree | General Crawlers | 7 | 03-19-2006 10:34 AM |
