03-06-2015, 09:48 PM | #1 |
Newbie Join Date: Oct 2014 Location: canada
| pin drive wheels ?
How can i get my pin style drive wheels to work on my trailfinder 2. I tried but they are binding up as i tighten the wheel nuts. Any tips would be much appreciated.
03-06-2015, 10:22 PM | #2 | |
Pebble Pounder Join Date: Sep 2010 Location: SD
| Re: pin drive wheels ? Quote:
I have the pin style rc4wd 1 7 which don't use a hex and they bolted right up. | |
03-06-2015, 11:57 PM | #3 |
rc3wd has a bad reputation for making the depth of the pin slots too deep, sp that when you tighten up the wheel nut the wheel will bottom out against the knuckle or lock out. I've had this happen on every set of pin drive wheels that I've owned. I've always had to use a lathe and reduce the face that has the pin slot in it in order to make the wheels function correctly.
03-07-2015, 07:46 AM | #4 |
Pebble Pounder Join Date: Jan 2015 Location: Hopewell Jct
Worst case, you can get adapters to make the pin wheels into 12mm hexes. OEM Steel 1.9 Stock Beadlock Wheel Hexes |
03-07-2015, 08:38 AM | #5 |
Thanks very much. I will try to grind them down.
03-07-2015, 04:28 PM | #6 | |
Pebble Pounder Join Date: Jun 2011 Location: Rio Brisbanero Australia
03-11-2015, 12:59 PM | #7 |
Thanks for the help. Grinding them worked perfect. Only 2 out of the 4 needed grinding though.
pin drive wheels ? - Similar Threads | ||||
Wheel wideners with the pin drive? | DSchulten88 | Losi Micro-Rock Crawler | 10 | 10-15-2014 01:30 PM |
drive pin | 87silverado | Redcat Crawlers | 2 | 12-23-2010 03:29 AM |
Lost Pin from Drive Shaft | domer | Losi Mini-Rock Crawler | 13 | 11-13-2009 07:57 PM |
Drive pin replacements? | teamtom | Tamiya Clod Buster | 8 | 09-01-2007 12:26 PM |
