Thread: Tf2 suspension question
Old 08-05-2017, 09:54 PM   #1
Default Tf2 suspension question
I received a blazer body in the mail today and this will be my second blazer. It's obvious that being top heavy is one of the biggest obstacles. Curiously trying something I mounted the springs (under)the axle instead of the spring being on top to try and gain a lower COG. It's going to be a while before I get this thing rolling I was just curious if anyone has done this before and possibly have any info / advice on running the springs under the axle or if there's any benefit to it whatsoever.
Thanks,
High Angle Five is offline   Reply With Quote
Old 08-06-2017, 06:26 PM   #2
Default Re: Tf2 suspension question
I know it's been done before, but I don't recall off the top of my head who's done it. The simplest way to do it would be to use u-bolts to attach the leafs to the axles. You'll probably need to move a couple of things around between the chassis rails to get everything to clear, but it's certainly doable.
new2rocks is offline   Reply With Quote
Old 08-06-2017, 07:17 PM   #3
I saw a thread on this the other day.
IVIaarten builds a rustless TF2 LWB with LC70
Aehle is offline   Reply With Quote
Old 08-07-2017, 01:37 AM   #4
Yep, I've been playing around with this on my build (link in the post above). If you have any specific questions, feel free to ask.
IVIaarten is offline   Reply With Quote
Old 08-07-2017, 06:38 AM   #5
Awesome Thread IVIaarten, tons of great ideas. I've got several things id like to try on mine. ill certainly be in touch.
Old 08-07-2017, 06:40 AM   #6
Thank you for the help! just so happens the creator of this thread found my post as well.
Old 08-12-2017, 10:50 PM   #7
Your welcome, I just built my first tf2 so I've spent a lot of time reading lately and he has a great looking build.
Tf2 suspension question - Similar Threads
TF2 suspension mod Desmo RC4WD Trail Finder 2 8 01-15-2018 02:30 PM
new to tf2, wheelbase too long and suspension sags ? fleetside RC4WD Trail Finder 2 5 03-13-2016 03:03 PM
TF2 Leaf sprung suspension set up info thread Bananaclip RC4WD Trail Finder 2 3 08-01-2015 12:09 PM
Another TF2 Build with homemade suspension lift Hobine RC4WD Trail Finder 2 18 10-20-2012 04:57 PM
Suspension question. Tourettic1 Axial SCX-10 0 10-03-2012 11:35 AM
