Thread: Which battery are you guys running in your TF2's?
Old 01-10-2018, 07:33 PM   #1
Default Which battery are you guys running in your TF2's?
I just made the mistake of ordering this battery, doesn't fit :( way too big.
https://hobbyking.com/en_us/turnigy-...ack-xt-60.html
Digital is offline   Reply With Quote
Old 01-10-2018, 10:32 PM   #2
Default Re: Which battery are you guys running in your TF2's?
Most of the good online store offer return policy, you can try to contact hobby King and arrange with them?
Teng is offline   Reply With Quote
Old 01-11-2018, 08:18 AM   #3
Hey Teng, yeah they'll take them back luckily but I had to pay for shipping. I need to check the size of these batteries more carefully before I order them apparently.
Sent from my Tin Can using Tapatalk
Old 01-11-2018, 10:12 PM   #4
I'm gonna give this guy a try, the measurements look right for the tf2 and I like how the wire terminals are facing upwards instead of up against the body - http://a.co/e7hZM9f
Old 06-18-2018, 02:27 PM   #5
Anyone know if the newer Traxxas 5800 2S lipo batteries (the one with Traxxas's "ID" plug) will fit the in the TF2? At the moment all my batteries are these Traxxas 2S lipos and would like to keep it that way.
joeR6 is offline   Reply With Quote
Old 06-19-2018, 02:21 PM   #6
Natedog's Avatar
JoeR6 that’s a huge battery, Id run something smaller and lighter. It’s easier to fit physically and less weight up high, truck will crawl much better.
I’m going to use Protek 3600mah 3s lihv with battery tray flipped so battery forward. Don’t think it will fit rear positions under the bed due to thickness.
Edit, truck balances better with battery tray towards the rear, now my Protek batteries are too thick Looking for good 3S lipo to fit.
Old 06-19-2018, 02:55 PM   #7
I also had a hard time finding a battery that would fit. I have venom 4000 3s batteries that have treated me good. One of the lhs guys hooked me up with them. Got with no problems.
Levi is offline   Reply With Quote
Old 06-19-2018, 05:07 PM   #8
i had a dynamite 5000mah 2s hardcase in mine with a full interior tight fit but doable when i switched to the blazer body a 2s 4000mah dynamite shorty pack was biggest i could fit without interference keep in mind this was a single speed trans rtr
scalemadness is offline   Reply With Quote
Old 06-19-2018, 10:00 PM   #9
snapon boy's Avatar
I have the rtr lwb and want to add the interror and run a 3s 2200. Dose anyone know if it will fit
149 r/c worx/scalerfab/team brood.
snapon boy is offline   Reply With Quote
Old 06-20-2018, 07:35 AM   #10
Moderator
JatoTheRipper's Avatar
I run this 2S 4200mAh stick pack battery in mine.
https://hobbyking.com/en_us/turnigy-...tick-pack.html
Old 06-20-2018, 11:43 AM   #11
The dimensions on that turnigy battery (138x47x23mm) isn't too far off from the Traxxas 5800 2cell lipo (135x45x25mm)
Old 06-20-2018, 11:46 AM   #12
Moderator
I'm sure mine is much cheaper than the Traxxas battery and has a higher C-rating to boot.
Old 06-20-2018, 09:47 PM   #13
snapon boy's Avatar
Those fit with the rc4wd interror?
Old 06-21-2018, 06:41 AM   #14
Moderator
I'm only using the RC4WD stock dash and the optional RC4WD seat with driver and this battery works no problem. I don't have the full right-hand-drive interior from the LWB in mine.
Old 06-26-2018, 06:27 AM   #15
Iam running a florion 3s 4500 mah
Sent from my LGLS991 using Tapatalk
bent_hinge_pin is offline   Reply With Quote
Old 06-26-2018, 06:43 AM   #16
snapon boy's Avatar
With the interror?
Old 06-26-2018, 06:45 AM   #17
With the interror?
With the twin hammers interior dont know if ill get the rc4wd one may just make my own to accommodate the batt
Old 06-26-2018, 06:53 AM   #18
snapon boy's Avatar
OK. Yeah. I bought the rc4wd interror it hasn't arrived yet but I set the rig up for 3s like all my other stuff. Hopefully It works
Old 06-26-2018, 06:55 AM   #19
Please update here when yougetinstalled may sway which way i got
Old 06-26-2018, 07:02 AM   #20
snapon boy's Avatar
OK will do. One of my friends is going to paint some of the details for me so it might be a week or so.
Which battery are you guys running in your TF2's? - Similar Threads
What motor and battery after you guys running? nate94gt Vaterra Ascender 6 10-07-2017 06:15 PM
Where's all the S.E. WI guys running at? Mopardude Wisconsin 12 11-20-2015 05:03 AM
RX/Tx? What are you guys running? molina Axial Yeti 18 03-07-2015 09:14 PM
TF2's Running 2.2's? Paul97 RC4WD Trail Finder 2 6 02-01-2013 02:36 PM
Guys running VP SLW's crash RC4WD Bully 13 10-15-2009 03:43 AM
