12-05-2016, 11:53 AM | #21 |
Rock Stacker Join Date: Nov 2016 Location: North Jersey
| Re: rs10 vs everest 10
how did you wire them together? Cut and splice? or is there some sort of connector to make things easier?
12-06-2016, 07:05 AM | #22 |
Rock Stacker Join Date: Jan 2016 Location: farmington
| Re: rs10 vs everest 10 |
12-06-2016, 08:37 AM | #23 | |
Newbie Join Date: Sep 2016 Location: Chicago
| Re: rs10 vs everest 10 Quote:
https://www.amazon.com/Helicopter-Sp...servo+y-cables | |
12-06-2016, 09:00 AM | #24 |
that would work. Looks like even if its wired wrong you can cut it where the heat shrink is and swap them. thanks for the link!
12-07-2016, 06:48 AM | #25 |
Newbie Join Date: Sep 2015 Location: west boylston
I bared my wires with a exacto knife. And put the same color wires together and a little solder after I made sure I had the connection right. Then a little electrical tape. I'll take a pic for you later Sent from my SM-G930V using Tapatalk |
12-07-2016, 06:49 AM | #26 |
If you are capable of cutting the splice thing just cut and splice your own wires for free ? At the cost of some solder or even electrical tape Sent from my SM-G930V using Tapatalk |
12-07-2016, 07:07 AM | #27 |
Of course cutting and splicing is easy and free. But i feel that if i can get a $4 splice connector so i dont have to hack into the servo wires and connectors then its worth it. Incase i want to use the servo for future builds.
12-13-2016, 12:33 PM | #28 |
So i finally got around to doing the 4 wheel steering last night. It is very easy but there is one thing to note. The Y connector wont work, it will make the car crab instead of turn. You either need to get a reversing Y splitter or you have to do a little soldering inside the servo. Its pretty simple to solder the servo in reverse. It has to be done though to achieve steering instead crabbing.
12-19-2016, 10:35 AM | #29 |
Or you could have saved money and time and soldered the two servos together Sent from my SM-G930V using Tapatalk |
12-20-2016, 06:44 AM | #30 |
| Re: rs10 vs everest 10 Yes, that would work too but you still have to internally reverse the rear servo which is no big deal. I just wanted to leave the servo pigtail intact.
12-21-2016, 02:31 PM | #31 |
I'll show you a pic of mine I literally just put the pigtails together no servo reversing or anything Sent from my SM-G930V using Tapatalk |
12-22-2016, 06:56 AM | #32 |
Interesting. I was under the impression that the truck would crab instead of turn if you just hooked 2 together. I reversed mine and it turns like it should. Unless i messed up, which is entirely possible.
01-06-2017, 02:17 PM | #33 |
Newbie Join Date: Jan 2017 Location: North Alabama
What is different about the ES10 and the RS10 beside four wheel steering? ES says waterproof and RS doesn't
01-06-2017, 03:18 PM | #34 |
RCC Addict Join Date: May 2011 Location: at home
rolltideram do you mean besides one being a shaft drive driven vehicle with one motor and the other one is a motor on axle with 2 motors? |
01-06-2017, 03:25 PM | #35 |
Rock Crawler Join Date: Jan 2014 Location: Granite Falls, WA
| Re: rs10 vs everest 10 Well, the main difference is that the RS10 is MOA (motor-on-axle), with a separate motor on each axle, while the E10 is a shafty (shaft-driven from a single center transmission). The E10, and pretty much any other shafty scale/crawler, can be upgraded to 4WS, which makes the type of drivetrain (MOA vs shaft) the main difference.
01-09-2017, 12:54 AM | #36 |
Those are the answers I was looking for. I did not notice looking at pics about the RS having two motors. Sorry the new guy dumb question.
rs10 vs everest 10 - Similar Threads | ||||
Everest-10 | rodney m | Redcat Crawlers | 1 | 08-13-2015 07:17 AM |
how to make strong RS10 axles? or everest 10? | dirtman71 | Redcat Crawlers | 12 | 07-22-2015 09:01 PM |
Project: Smooth Operator (RS10 EVEREST) | tony91723 | Redcat Crawlers | 25 | 06-24-2015 12:00 AM |
